NRF24 communication problem
Hi!
Ive been working on this arduino based RC controller for my Graduation project and Im having problem with communication. Ive had a succesful try once that I ve controlled servos. Now communication doesnt seem to be working. TX and RX circuit diagram are below and Ive checked the connections multiple times so Im sure that connections are okey. The supply of servos is ESC's BEC output 5v 1A I know that 1A cannot deal with 4 servos but even if one servo is connected its not working. I thougth that may be the NRF24 module is broken and Ive bought a new pair bıt Its still a fail. The code that Im using is below aswell. Can you help or inform me abot the issues that I am dealing with?
TRANSMİTTER
RECEİVER
// 8 Channel Transmitter (No Trim) | 8 Kanal Verici (Trim Yok)
// Input pin A5
  #include <SPI.h>
  #include <nRF24L01.h>
  #include <RF24.h>
  const uint64_t pipeOut = 000322;         // NOTE: The same as in the receiver 000322 | Alıcı kodundaki adres ile aynı olmalı
  RF24 radio(9, 10);                       // select CE,CSN pin | CE ve CSN pinlerin seçimi
  struct Signal {
  byte throttle;
  byte pitch;
  byte roll;
  byte yaw;
  byte aux1;
  byte aux2;
  byte aux3;
  byte aux4;
  Signal data;
  void ResetData()
  data.throttle = 0;
  data.pitch = 127;
  data.roll = 127;
  data.yaw = 127;
  data.aux1 = 0;                       // Signal lost position | Sinyal kesildiğindeki pozisyon
  data.aux2 = 0;
  data.aux3 = 0;
  data.aux4 = 0;
                                       //Configure the NRF24 module  | NRF24 modül konfigürasyonu
  radio.begin();
  radio.openWritingPipe(pipeOut);
  radio.setAutoAck(false);
  radio.setDataRate(RF24_250KBPS);    // The lowest data rate value for more stable communication  | Daha kararlı iletişim için en düşük veri hızı.
  radio.setPALevel(RF24_PA_MAX);      // Output power is set for maximum |  Çıkış gücü maksimum için ayarlanıyor.
  radio.stopListening();              // Start the radio comunication for Transmitter | Verici için sinyal iletişimini başlatır.
  ResetData();
                                      // Joystick center and its borders | Joystick merkez ve sınırları
  int Border_Map(int val, int lower, int middle, int upper, bool reverse)
  val = constrain(val, lower, upper);
  if ( val < middle )
  val = map(val, lower, middle, 0, 128);
  val = map(val, middle, upper, 128, 255);
  return ( reverse ? 255 - val : val );
                                     // Control Stick Calibration for channels  |  Her bir kanal için kumanda Kol Kalibrasyonları
  data.roll = Border_Map( analogRead(A3), 0, 512, 1023, true );        // "true" or "false" for signal direction | "true" veya "false" sinyal yönünü belirler
  data.pitch = Border_Map( analogRead(A2), 0, 512, 1023, true );
  data.throttle = Border_Map( analogRead(A1),570, 800, 1023, false );  // For Single side ESC | Tek yönlü ESC için
  // data.throttle = Border_Map( analogRead(A1),0, 512, 1023, false ); // For Bidirectional ESC | Çift yönlü ESC için
  data.yaw = Border_Map( analogRead(A0), 0, 512, 1023, true );
  data.aux1 = Border_Map( analogRead(A4), 0, 512, 1023, true );        // "true" or "false" for change signal direction | "true" veya "false" sinyal yönünü değiştirir.
  data.aux2 = Border_Map( analogRead(A5), 0, 512, 1023, true );        // "true" or "false" for change signal direction | "true" veya "false" sinyal yönünü değiştirir.
  data.aux3 = digitalRead(7);
  data.aux4 = digitalRead(8);
  radio.write(&data, sizeof(Signal));
//  8 Channel Receiver | 8 Kanal Alıcı
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
int ch_width_1 = 0;
int ch_width_2 = 0;
int ch_width_3 = 0;
int ch_width_4 = 0;
int ch_width_5 = 0;
int ch_width_6 = 0;
int ch_width_7 = 0;
int ch_width_8 = 0;
Servo ch1;
Servo ch2;
Servo ch3;
Servo ch4;
Servo ch5;
Servo ch6;
Servo ch7;
Servo ch8;
struct Signal {
byte throttle;
byte pitch;
byte roll;
byte yaw;
byte aux1;
byte aux2;
byte aux3;
byte aux4;
Signal data;
const uint64_t pipeIn = 000322;
RF24 radio(9, 10);
void ResetData()
data.throttle = 0;
data.roll = 127;
data.pitch = 127;
data.yaw = 127;
data.aux1 = 0;                                              // Define the inicial value of each data input. | Veri girişlerinin başlangıç değerleri
data.aux2 = 0;
data.aux3 = 0;
data.aux4 = 0;
                                                           // Set the pins for each PWM signal | Her bir PWM sinyal için pinler belirleniyor.
  ch1.attach(0);
  ch2.attach(2);
  ch3.attach(3);
  ch4.attach(4);
  ch5.attach(5);
  ch6.attach(6);
  ch7.attach(7);
  ch8.attach(8);
  ResetData();                                             // Configure the NRF24 module  | NRF24 Modül konfigürasyonu
  radio.begin();
  radio.openReadingPipe(1,pipeIn);
  radio.startListening();                                   // Start the radio comunication for receiver | Alıcı için sinyal iletişimini başlatır.
unsigned long lastRecvTime = 0;
void recvData()
while ( radio.available() ) {
radio.read(&data, sizeof(Signal));
lastRecvTime = millis();                                    // Receive the data | Data alınıyor
recvData();
unsigned long now = millis();
if ( now - lastRecvTime > 1000 ) {
ResetData();                                                // Signal lost.. Reset data | Sinyal kayıpsa data resetleniyor
ch_width_1 = map(data.roll, 0, 255, 1000, 2000);
ch_width_2 = map(data.pitch, 0, 255, 1000, 2000);
ch_width_3 = map(data.throttle, 0, 255, 1000, 2000);
ch_width_4 = map(data.yaw, 0, 255, 1000, 2000);
ch_width_5 = map(data.aux1, 0, 255, 1000, 2000);
ch_width_6 = map(data.aux2, 0, 255, 1000, 2000);
ch_width_7 = map(data.aux3, 0, 1, 1000, 2000);
ch_width_8 = map(data.aux4, 0, 1, 1000, 2000);
ch1.writeMicroseconds(ch_width_1);                          // Write the PWM signal | PWM sinyaller çıkışlara gönderiliyor
ch2.writeMicroseconds(ch_width_2);
ch3.writeMicroseconds(ch_width_3);
ch4.writeMicroseconds(ch_width_4);
ch5.writeMicroseconds(ch_width_5);
ch6.writeMicroseconds(ch_width_6);
ch7.writeMicroseconds(ch_width_7);
ch8.writeMicroseconds(ch_width_8);
How far apart are the radios when you are testing? They may not communicate if too close together. Move them a few meters apart. For testing, reduce the power.
radio.setPALevel(RF24_PA_MIN);
Ive treid what you have said but still fails.
Btw receiver is an arduino nano and its rx led blinks but transmitter is an arduino uno and its tx led does not blink
You probably have fried the modules, they require an Operating voltage 1.9 – 3.6V, your frizzy the best I can figure out is 5V. Nice pictures but not very readable. An annotated schematic as you wired it is much better. Schematic is the language of electronics, wiring diagrams and pictures are not.
RX and TX LEDs are for hardware serial only. They have nothing to do with the RF24 modules.
I suggest that you run the CheckConnection.ino sketch that can be founnd in Robin2's simple rf24 tutorial reply #30 on each radio. The sketch will test the connection between the RF24 radio modules and their connected Arduino board. Also try the sample code that is in the tutorial. That code has been proven good many times.
@gilshultz , it appears that the OP is using some of the power adapters that take 5V and have a regulator to drop that to 3.3V for the radios. I use similar adapters with good success. I await confirmation from the OP.
I ve run the CheckConnection.ino and one of the adaptors seems to be problem details are mostly 0s. But Ive a question about it. So with the other adaptor output of the CheckConnection.ino looks ok. But does that mean also the nrf modules are okey?Btw ım using adaptors that you said.
If a rf24 module fails when connected to one power adapter, but the same rf24 module passes when connected to a different power adapter, I would say that it points to a defective power adapter.
So nrf modules might be working right?
I suppose. Do you have a DMM (Digital MultiMeter)?
Yes Ive . And Ive changed the connections of broken adaptor now CheckConnection.ino's output seems okey. And I tried the Robin2's ack payload example first it was a fail but when ı pressed the transmitter adaptors SPI cables communication was succesful. I think I must design a robust connection between them.
hi I dont know if we are having the same problem but ive tried this simple code then had to add ' radio.setAutoAck(false); ' to this
* Arduino Wireless Communication Tutorial
*     Example 1 - Transmitter Code
* by Dejan Nedelkovski, www.HowToMechatronics.com
* Library: TMRh20/RF24, https://github.com/tmrh20/RF24/
#include <SPI.h>
#include <RF24.h>
RF24 radio(7, 8); // CE, CSN
const byte address[6] = "00001";
  radio.begin();
  radio.openWritingPipe(address);
  const char text[] = "Hello World";
  radio.write(&text, sizeof(text));
otherwise it wouldn't send data but I then tried this code for my project
#include <SPI.h>
#include <RF24.h>
// Max size of this struct is 32 bytes - NRF24L01 buffer limit
struct Data_Package {
  byte a = 0;
  byte b = 125;
  byte c = 255;
  int d = 1024;
  float e = 3.141592;
  String f = "Test";
Data_Package data; // Create a variable with the above structure
  radio.begin();
  // Send the whole data from the structure to the receiver
  radio.write(&data, sizeof(Data_Package));
and
        Example 1 - Receiver Code
#include <SPI.h>
#include <RF24.h>
  byte a = 0;
  byte b = 125;
  byte c = 255;
  int d = 1024;
  float e = 3.141592;
  String f = "Test";
Data_Package data; //Create a variable with the above structure
  radio.begin();
  radio.openReadingPipe(0, address);
  // Check whether there is data to be received
  if (radio.available()) {
    radio.read(&data, sizeof(Data_Package)); // Read the whole data and store it into the 'data' structure
  Serial.print("a: ");
  Serial.print(data.a);
  Serial.print(" b: ");
  Serial.print(data.b);
  Serial.print(" c: ");
  Serial.print(data.c);
  Serial.print(" d: ");
  Serial.print(data.d);
  Serial.print(" e: ");
  Serial.print(data.e);
  Serial.print(" f: ");
  Serial.println(data.f);
but it wont work and im not sure why
I think our problem is somewhere in the data package
