NRF24L01 + PA + LNA modules not working
Hello,
I have been trying to get 2 nrf24l01 modules working with 2 arduino nanos for a while now. I just can't do it. I have tried a lot of tutorial videos and programs but nothing works. I am currently using the NRFLite library. It contains an rx and a tx test, with the rx test I only get
250KBPS bitrate
Starting sync
in my serial monitor and with the tx test I get
250KBPS bitrate
Starting sync
Retrying in 4 seconds
and I can't get any further.
Does anyone know how I can solve this so that it will work?
Thanks in advance!
Please read and follow this link: How to get the best out of this forum - Development Tools / IDE 1.x - Arduino Forum
what do you mean?
Lots of important information is missing. Please read and use the link.
Possibly but without knowing exactly what you have it will be extremely difficult. Your problem is not unexpected, and your wiring may be the root cause. Since hardware is involved, it’s crucial to provide an accurate, annotated schematic of your circuit as it is currently wired. Please note that Fritzing diagrams are not considered proper schematics; they are wiring diagrams and are often not helpful for troubleshooting.
What to Include:
  1. Annotated Schematic: Show all connections, including power, ground, and power sources. This helps us understand how your circuit is set up and identify any potential issues.
  2. Technical Information Links: Provide links to technical documentation for each hardware device used in your setup. Avoid links to sales sites like Amazon, as they usually lack the necessary technical details. We need complete specifications to help you effectively.
  3. Additional Information Needed: If the above details are incorrect, more information is required. Tell us what hardware and software you are using, the format of any data (like map data), and how your system determines its position. For example, if your project involves a robot, describe how it navigates and what computers are involved.
  4. Code Without code we cannot see the interrelationship between the code and hardware.
Why This Matters:
We have no way of knowing the specifics of your setup unless you provide that information. Clear and detailed descriptions enable us to offer the most accurate help possible. Without these details, it’s difficult to diagnose and solve the issues you're experiencing. You should check this link: How to get the best out of this forum
== > How to Get the Right Help Faster:
You can spend weeks spinning your wheels, or you might get lucky and solve your problem quickly. To avoid unnecessary delays, it’s crucial to provide an annotated schematic of your circuit as you have it wired, showing all connections, including power, ground, and supplies.
Why Detailed Information Matters:
  • Annotated Schematics: These are essential because they show exactly how your circuit is set up. Without them, it's difficult for anyone to understand what you’ve done, which makes troubleshooting nearly impossible. Fritzing diagrams or unclear pictures are not enough.
  • Technical Information: Many modules look similar and may even have the same name, but they can function differently. This is why we always ask for links to detailed technical information—not just sales pages like those on Amazon, which often lack the specifics we need.
  • Show All Connections: It’s important to include every connection, especially power and ground, in your schematic. Missing these details makes it hard to determine if a setup issue might be causing your problem.
My Process:
When I see a question, I spend a moment assessing it. If it’s missing critical information, I might ask for it. However, if it's repeatedly lacking important details, I may assume the questioner is not serious and move on to another query.
What You Need to Consider:
We don’t know your skill level or what resources you have available. If you’re missing key technical details or seem unprepared, it may indicate that you need to spend more time learning the basics before starting your project.
Providing the right information upfront will help you get the best possible assistance and avoid the frustration of running into dead ends. Let us help you by sharing what you have clearly and completely!
Try reading this: How to get the best out of this forum
