NRF24L01 Transceiver Not Working
I'm using 2 Arduino Mega 2560 boards for Receiving and Transferring data. I'm using 2 NRF24L01 Transceivers (1 on each).
  1. I've cross referenced the pinout to multiple websites to verify it, but if someone could tell me what the pinout is from what angle, that would be great
  2. I have the libraries included, and the code updates fine
  3. TX board keeps saying fail to transfer and RX board is spamming even when TX isn't sending when I use code from Simple nRF24L01+ 2.4GHz transceiver demo
Note: All these websites have different pinouts for 7 & 8 or 9 & 10 and i've switched between them based on what code they have. If someone has a pinout, please let me know where you got it from & what code I can include to make this work.
You need to read the pinned post re 'How to get the best from this forum'. That will instruct you re wiring diagrams and code posting.
Welcome! How to Get the Right Help Faster:
You can spend weeks spinning your wheels, or you might get lucky and solve your problem quickly. To avoid unnecessary delays, it’s crucial to provide an annotated schematic of your circuit as you have it wired, showing all connections, including power, ground, and supplies.
Why Detailed Information Matters:
  • Annotated Schematics: These are essential because they show exactly how your circuit is set up. Without them, it's difficult for anyone to understand what you’ve done, which makes troubleshooting nearly impossible. Fritzing diagrams or unclear pictures are not enough.
  • Technical Information: Many modules look similar and may even have the same name, but they can function differently. This is why we always ask for links to detailed technical information—not just sales pages like those on Amazon, which often lack the specifics we need.
  • Show All Connections: It’s important to include every connection, especially power and ground, in your schematic. Missing these details makes it hard to determine if a setup issue might be causing your problem.
My Process:
When I see a question, I spend a moment assessing it. If it’s missing critical information, I might ask for it. However, if it's repeatedly lacking important details, I may assume the questioner is not serious and move on to another query.
What You Need to Consider:
We don’t know your skill level or what resources you have available. If you’re missing key technical details or seem unprepared, it may indicate that you need to spend more time learning the basics before starting your project.
Providing the right information upfront will help you get the best possible assistance and avoid the frustration of running into dead ends. Let us help you by sharing what you have clearly and completely!
Try reading this: How to get the best out of this forum
Can we use that reply as a standard reply? Copy it, or put it in a pinned post? It's is the perfect response to 95% of the questions here.
It has been posted by me maybe 50 times or more over the last two years. Feel free to use it.
Thanks, I never noticed it before, but then my memory at 83 ain't what it used to be.
Darn you are two years older then I am, that makes you the 'OLD" man:-) Welcome to the Club.
I often am.
