NRFL24L01 Ground issues
Hey guys,
I am in the process of building a project using the NRFL2401, however I seem to be coming across a very odd issue.
If i attach to the serial monitor and view the output of the device, I only ever get readable responses, if I physically hold the wire for either the + or the -.
I suspect its a grounding issue, but its driving me crazy!
Any ideas?
what your trying to do.
post your code and serial monitor window.
if tx and rx lines occupied for other interfaces,you cannot use Serial monitor
how to interface explained here properly
http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
hey there,
I am just using the getting started sketch, with a custom built arduino. All the other device attached to it work with my own sketch, but the getting started sketch is the one I am having issues with.
As soon as I touch either the positive or the negetive wire, it starts showing valid text...
you haven't shared sketch . which is having problem.
check it might loose connection. else solder it directly
