Hello everyone.
I am new to the forum and starting my experience with Arduino.
I had the Arduino Uno test board in my office and I decided to see if I could use the Arduino board to create a simulation kit for our equipment.
In our office lab we get various controllers that we need to test with our BMS system. These controllers have all sort of inputs, from 0-10V to 4-20mA, from NTC to PT1000 for passive temperature sensors.
If we wanted to hang a controller like this to our BMS and simulate the sensors to see the controller "working", we could easily send a 0-10V or 4-20mA signal using our dedicated I/O controller and that would sort out these active inputs, but it is a lot more difficult to simulate a passive temperature sensor... We currently do that using a manual multi turn potentiometer, but with this solution we can't create any simulation automation (for example, the controller is running a heater and the temperature starts to increase).
The idea I had was to use an Arduino to do that.
Connecting the Arduino over Modbus 485 to our lab PC so we can send a modulating "temperature" value, transpated into steps for a digital potentiometer. The digital potentiometer driven then on SPI protocol by the Arduino.
I started the prototype to simulate an NTC 10Kohm sensor.
I've used a MAX485 integrated circuit to access the Arduino from our computer and dynamically change the desired resistor position.
I could have used only a 100K pot to have the full range of the NTC sensor, but to gain the desired resolution I've used 2 digipots, a 10K AD8400ARZ10 and a 100K AD8400ARZ100 with the wiper of the 100K going in series to the B connector of the 10K and the wiper of the 10K then being the resistor output.
On the Arduino I've coded so I step the 10K first, and every 10 steps on the 10K I provide a step on the 100K and restart using the 10K from 0.
I got the circuit working perfectly fine, using an external multimeter I can read the resistance value changing as I would expect and I can drive it correctly using Modscan from my lab computer, very exciting!
I then got a controller and connected one of its NTC input to the digipot (like I did before with the multimeter) to see what I would read from it... It didn't work, the resistance measured is not correct, it is floating and far off the value that I measure with the multimeter.
I've tried 2 different controllers and got 2 different situations, both wrong.
I read a bit over the internet, and it seems it might be related to a different ground issue, as the digipot is powered by the Arduino and the controller is powered by its own psu.
How can I solve the problem?
Sorry if I might have made some electronic beginner mistakes there, but I really would like to learn and get it to work, it seems so close...
thanks for the kind help!
