I have developed a program for object detection, blocking detection and calibration of up to 8 VL53L4CD sensors.
I am not a programming expert, but I hope that others can use my program or be inspired by the method.
Suggestions for improvements etc. are welcome Arduino@jorgen-madsen.dk
Youtube short videos:
Train detection and blocking detection with VL53L4CD laser sensor:
https://youtu.be/Fls3YJwM_Pg
How to mount cover glass on VL53L4CD laser: https://youtu.be/iU56pOXOom8
Reagards
Jorgen
VL53L4CD I2C Time of Flight Micro Distance Sensor and close-up sensor blocking detection
Fast ranging 10 ms loop robust and error-correcting functionality with detailed error descriptions
The program is coded with a focus on simplicity, ease of understanding and self-explanatory
REMEMBER! disconnet power briefly to all sensors and Arduino MCU for correct reset!
Please read the accompanying detailed documentation
Jørgen Bo Madsen - august 2024 - Arduino@jorgen-madsen.dk
#include <Arduino.h>
#include <Wire.h>
#include <vl53l4cd_class.h>
// Visual Studio code debug
//#include "avr8-stub.h"
//#include "app_api.h"
#define SerialPort true // true: test and debug monitor information - false: production
// Sensor configuration --------------------------------------------------------------------
const bool YES = true, NO = false; // Easy understanding
const bool VL53L4CD_Laser_I2C_ON[8] = // Wired and connected to Nano
// sensor 0 1 2 3 4 5 6 7
{ YES, NO, NO, NO, NO, NO, YES, NO };
const word VL53L4CD_Min_Distance_MM[8] = // Min distance = 20 mm
{ 25, 25, 25, 25, 25, 25, 25, 25 };
const word VL53L4CD_Max_Distance_MM[8] = // Max distance = 800 mm.
{ 800, 800, 800, 800, 800, 800, 800, 800 };
// Show range, status, warning and error messages
const bool I2C_wire_Debug_Enabled = YES; // List I2C Wire connected devices and other I2C debug information
const bool VL53L4CD_Print_Object_Detect = NO; // Print distance and min-max zone, when object is detected:
const bool VL53L4CD_Print_Range_Status = NO; // Print status information. Se www.ST.com UM2931 manual.
const bool VL53L4CD_Debug_Enabled[8] = // Print ranging and error messages
{ NO, NO, NO, NO, NO, NO, NO, NO };
// Close-up Blocking detection distance configuration --------------------------------------
const bool VL53L4CD_Blocking_Detect[8] =
{ YES, YES, YES, YES, YES, YES, YES, YES };
// Optimized to 1,0 mm air gap and 0,35 mm 9H photo lens cover glass (1,35 mm distance in total)
// Close-up total sensor blocking: Matte black = 10 mm, Matte gray = 4 mm, Light yellow = 16 mm, Shiny white = 13 mm
// To lower blocing distance to 15 mm, increase air gap to 2 mm (2,35 mm distance in total)
const word VL53L4CD_Max_BLock_Dist_MM = 19; // Starting from top of cover glass (1,35 mm from senesor)
const word VL53L4CD_Max_Block_Count = 600; // Number of loops to calculate average
// Using InterMeasurement (set to 0) will increase the blocking distance
// Sensor calibration ----------------------------------------------------------------------
// Advanced configuration. Read first www.ST.com UM2931 manual.
const bool VL53L4CD_Offset_Calibrate = NO; // (YES / NO) Activate calibration mode
const short VL53L4CD_Offset_Dist_MM[8] = // Subtract from / add to range result
{ -8, -8, -8, -8, -8, -8, -8, -8 };
const short VL53L4CD_Xtalk_Distance_MM = 1000; // Maximum measured raging distance without under-ranging
const bool VL53L4CD_Xtalk_Calibrate = NO; // (YES / NO) Activate calibration mode
const word VL53L4CD_Xtalk_KCPS[8] = // Depends on Cover Glass type or no cover glass
{ 0, 0, 0, 0, 0, 0, 0, 0 };
// Address and ID ---------------------------------------------------------------------------
const byte VL53L4CD_I2C_Address = 0x29; // Adafruit and others 0x29 HEX / ST 0x52 HEX
const long VL53L4CD_Sensor_ID = 0xEBAA; // Sensor ID HEX
// Error correction thresholds -------------------------------------------------------------
// Read www.ST.com AN4907 Application note document DM00326504
const word VL53L4CD_Max_Sigma_MM = 6; // Default 15
const word VL53L4CD_Min_Signal_KPCS = 2048;
// Ambien light. Too much ambient light may will entail incorrect mauserments.
const word VL53L4CD_Max_Ambient_KCPS = 8000; // Maximum ambient light
const word VL53L4CD_Max_Ambient_Count = 600; // Number of loops to calculate average
// MUX configuration -----------------------------------------------------------------------
// TCA9548A 8-Channel I2C Multiplexer / PCA9548A - sensor channel 0 - 7 [8]
// TCA9546A 4-Channel I2C Multiplexer / PCA9546A - sensor channel 0 - 3 [4]
const bool TCA_PCA_9548A = true, TCA_PCA_9546A = false;
const bool TCA_PCA_I2C_Model = TCA_PCA_9548A;
// YES: I2C MUX connecte to Nano. NO: first VL53L4CD directly connected to Nano.
const bool TCA_PCA_I2C_MUX_ON = NO; // If MUX is off, Only sensor 0 is useable
const byte TCA_PCA_I2C_Address = 0x70; // Defalt I2C address 0x70 HEX
// Buzzer error sound ----------------------------------------------------------------------
const byte Buzzer_Pin = 8; // D4 - Passive buzzer 1.000 - 5.000 Hz
const byte Buzzer_Silent_Mode = LOW; // Buzzer YL-44 is Silent on HIGH! KY-006 on LOW!
// 1.000 - 5.000 Hertz. 0 = no sound. Duration in milliseconds.
const byte Error_Sound_Max_Step = 6; // number og tone / not tone steps
const word Error_Sound_Pitch_Hz[Error_Sound_Max_Step] = { 3500, 0, 4250, 0, 3500, 0 };
const word Error_Sound_Duration_MS[Error_Sound_Max_Step] = { 500, 500, 2000, 500, 500, 3000 };
// Global variables and structures ---------------------------------------------------------
const bool OK = true, Error = false; // Easy understanding
bool TCA_PCA_I2C_MUX_Status = OK; // MUX start status OK
bool VL53L4CD_Error_Status[8]; // I2C & range error handling
// Ambient light check
long VL53L4CD_Average_Ambient_KCPS[8]; // Average ambient light level KCPS
word VL53L4CD_Average_Ambient_Count[8]; // Average ambient count
// Blocking detection
long VL53L4CD_Average_Block_MM[8]; // Average blocking distance
word VL53L4CD_Average_Block_Count[8]; // Average blocking count
// General
byte VL53L4CD_Status = 0; // General function return result
word Loop_Delay_Time = 10; // Main loop for parallel processing
word Offset_Delay_Time = 0; // I2C communication delay compensation
// Buzzer
byte Error_Sound_Count = 0; // Number of repeatede sound loops
byte Buzzer_Step_Count = 0; // Buzzer sound process
bool Error_Sound_ON = NO; // Sound process loop
bool Buzzer_Start_Step = YES; // Sound process loop step start
unsigned long Buzzer_Start_Time = 0;// Buzzer sound process
// Sensor processing
byte VL53L4CD_Max_Count = 0; // Max number of lasers to process
byte VL53L4CD_Active_Sensor = 0; // Currently active laser [0-7]
byte VL53L4CD_Max_ON_Index = 0; // Max number of activated (ON) lasers
byte VL53L4CD_Loop_ON_Index = 0; // Round-Robin laser ON reference Index
byte VL53L4CD_Laser_ON_List[8]; // Activated (ON) laser reference list
VL53L4CD_Result_t VL53L4CD_Result;// Measured data
// Sensor structures
VL53L4CD VL53l4CD_0(&Wire, 0); // xhut = 0 => no pin used
VL53L4CD VL53l4CD_1(&Wire, 0); // xhut = 0 => no pin used
VL53L4CD VL53l4CD_2(&Wire, 0); // xhut = 0 => no pin used
VL53L4CD VL53l4CD_3(&Wire, 0); // xhut = 0 => no pin used
VL53L4CD VL53l4CD_4(&Wire, 0); // xhut = 0 => no pin used
VL53L4CD VL53l4CD_5(&Wire, 0); // xhut = 0 => no pin used
VL53L4CD VL53l4CD_6(&Wire, 0); // xhut = 0 => no pin used
VL53L4CD VL53l4CD_7(&Wire, 0); // xhut = 0 => no pin used
// Laser pointer array
VL53L4CD* VL53L4CD_Lasers_List[8] = { &VL53l4CD_0, &VL53l4CD_1, &VL53l4CD_2, &VL53l4CD_3, \
&VL53l4CD_4, &VL53l4CD_5, &VL53l4CD_6, &VL53l4CD_7 };
// Serial print slow down execution significantly and affects all functions that use time control.
#if SerialPort == true
// Test
#define PortPrint(x) Serial.print(x)
#define PortPrintln(x) Serial.println(x)
#else
// Production
#endif
// Setup -----------------------------------------------------------------------------------
// Initialize serial for output.
Serial.begin(250000);
Serial.println("Starting...");
pinMode(Buzzer_Pin, OUTPUT);
Initialize_I2C_bus();
VL53L4CD_Calculate_Max_Lasers();
VL53L4CD_Initialize_Error_check();
VL53L4CD_Initialize_Read_Data();
VL53L4CD_Check_I2C_Connected();
VL53L4CD_Initialize_Lasers();
VL53L4CD_Check_Parameters();
} // setup
// Main loop -------------------------------------------------------------------------------
// Read laser number 0
// bool Status = VL53L4CD_Read_One_Sensors(0);
//Read all enabled lasers. Round-Robin process
bool Status = VL53L4CD_Read_Sensors_Sequentially();
if (Status == true) {
Serial.print(millis()); Serial.print(F(" Laser no ["));
Serial.print(VL53L4CD_Active_Sensor); Serial.println(F("] Object detected"));
delay((unsigned long)(Loop_Delay_Time - Offset_Delay_Time)); // Defaul 10 milliseconds
Error_Alarm_Sound();
// Execute non blocking code ...
// Global sensor reading data (vl53l4cd_api.h)
Serial.print(F("range_status = ")); Serial.println(VL53L4CD_Result.range_status);
Serial.print(F("distance_mm = ")); Serial.println(VL53L4CD_Result.distance_mm);
Serial.print(F("ambient_rate_kcps = ")); Serial.println(VL53L4CD_Result.ambient_rate_kcps);
Serial.print(F("ambient_per_spad_kcps = ")); Serial.println(VL53L4CD_Result.ambient_per_spad_kcps);
Serial.print(F("signal_rate_kcps = ")); Serial.println(VL53L4CD_Result.signal_rate_kcps);
Serial.print(F("signal_per_spad_kcps = ")); Serial.println(VL53L4CD_Result.signal_per_spad_kcps);
Serial.print(F("number_of_spad = ")); Serial.println(VL53L4CD_Result.number_of_spad);
Serial.print(F("sigma_mm = ")); Serial.println(VL53L4CD_Result.sigma_mm);
// I2C laser setup ------------------------------------------------------------------
void Initialize_I2C_bus() {
char Hex_To_Char[5];
Wire.begin();
if (I2C_wire_Debug_Enabled == YES) {
for (byte index = 0; index < 83; index++) { PortPrint(F("-")); } PortPrintln();
PortPrintln(F("REMEMBER! disconnet power briefly to all sensors and Arduino MCU for correct reset!"));
snprintf(Hex_To_Char, sizeof(Hex_To_Char), "0x%02X", VL53L4CD_I2C_Address);
PortPrint(F("VL53L4CD_I2C_Address [HEX]: ")); PortPrintln(Hex_To_Char);
snprintf(Hex_To_Char, sizeof(Hex_To_Char), "0x%02X", TCA_PCA_I2C_Address);
PortPrint(F("TCA_PCA_I2C_Address [HEX]: ")); PortPrintln(Hex_To_Char);
I2C_Detect();
Check_CA_PCA_I2C_MUX();
Wire.end();
Wire.begin();
} // Initialize_I2C_bus
void Check_CA_PCA_I2C_MUX() {
if (TCA_PCA_I2C_MUX_ON == YES) {
Wire.beginTransmission(TCA_PCA_I2C_Address);
Wire.write(0); // Close all TCA_PCA channels
if (Wire.endTransmission() == 0) {
else {
TCA_PCA_I2C_MUX_Status = Error;
Set_Error_Sound_Count(1);
Error_Sound_Count = 1;
PortPrintln(F("ERROR: TCA_PCA_I2C_MUX_ON = YES - but no MUX is I2C connected!"));
} // Check_CA_PCA_I2C_MUX(
void VL53L4CD_Calculate_Max_Lasers() {
if (TCA_PCA_I2C_MUX_ON == YES && TCA_PCA_I2C_MUX_Status == OK) {
if (TCA_PCA_I2C_Model == TCA_PCA_9548A) {
VL53L4CD_Max_Count = 8;
else { // TCA_PCA_9546A
VL53L4CD_Max_Count = 4;
else { // First sensor
VL53L4CD_Max_Count = 1;
for (byte Index = 0; Index < VL53L4CD_Max_Count; Index ++) {
if (VL53L4CD_Laser_I2C_ON[Index] == YES) {
VL53L4CD_Laser_ON_List[VL53L4CD_Max_ON_Index] = Index;
VL53L4CD_Max_ON_Index++;
else {
VL53L4CD_Laser_ON_List[VL53L4CD_Max_ON_Index] = 0;
} // Calculate_Max_Lasers
void VL53L4CD_Initialize_Error_check() {
// Clear data!
for (byte Init_Laser_No = 0; Init_Laser_No < VL53L4CD_Max_Count; Init_Laser_No++) {
VL53L4CD_Error_Status[Init_Laser_No] = OK;
VL53L4CD_Average_Block_MM[Init_Laser_No] = 0;
VL53L4CD_Average_Block_Count[Init_Laser_No] = 0;
VL53L4CD_Average_Ambient_KCPS[Init_Laser_No] = 0;
VL53L4CD_Average_Ambient_Count[Init_Laser_No]= 0;
} // Initialize_Error_check
void VL53L4CD_Initialize_Read_Data() {
// Global sensor reading data (vl53l4cd_api.h) */
VL53L4CD_Result.range_status = 0;
VL53L4CD_Result.distance_mm = 0;
VL53L4CD_Result.ambient_rate_kcps = 0;
VL53L4CD_Result.ambient_per_spad_kcps = 0;
VL53L4CD_Result.signal_rate_kcps = 0;
VL53L4CD_Result.signal_per_spad_kcps = 0;
VL53L4CD_Result.number_of_spad = 0;
VL53L4CD_Result.sigma_mm = 0;
} // VL53L4CD_Initialize_Read_Data
void I2C_Detect() {
byte I2C_status, I2C_address;
short nDevices;
PortPrintln(F("Scanning I2C address range HEX: 0x01 - 0x77"));
nDevices = 0;
for(I2C_address = 1; I2C_address < 127; I2C_address++ ) {
// Did the device acknowledge to the address?
Wire.beginTransmission(I2C_address);
I2C_status = Wire.endTransmission();
snprintf(Hex_To_Char, sizeof(Hex_To_Char), "0x%02X", I2C_address);
if (I2C_status == 0)
PortPrint(F(" I2C device found at address [HEX]: "));
nDevices++;
else if (I2C_status == 4) {
PortPrint(F("Unknown error at address 0x / not connected / Pull up resistor missing"));
if (nDevices == 0) {
PortPrintln(F(" No I2C devices found!"));
PortPrintln(F("Done I2C scanning"));
} // I2C_Detect
void VL53L4CD_Check_I2C_Connected() {
byte I2C_Check_Status = 0;
byte Check_Laser_No = 0;
for (byte Index = 0; Index < VL53L4CD_Max_ON_Index; Index++) {
Check_Laser_No = VL53L4CD_Laser_ON_List[Index];
TCA_PCA_Select_Channel(Check_Laser_No);
if (VL53L4CD_Error_Status[Check_Laser_No] == OK) {
Wire.beginTransmission(VL53L4CD_I2C_Address);
I2C_Check_Status = Wire.endTransmission();
VL53L4CD_Print_Error(I2C_Check_Status, Check_Laser_No, 1);
if (I2C_Check_Status == 0 && VL53L4CD_Debug_Enabled[Check_Laser_No] == YES) {
VL53L4CD_Print_Header(Check_Laser_No); PortPrintln(F("I2C Connected OK"));
} // for
} // VL53L4CD_Check_I2C_Connected
void VL53L4CD_Initialize_Lasers() {
Init_Laser_No = VL53L4CD_Laser_ON_List[Index];
if (VL53L4CD_Error_Status[Init_Laser_No] == OK) {
TCA_PCA_Select_Channel(Init_Laser_No);
VL53L4CD_Set_I2C_Adresse(Init_Laser_No);
VL53L4CD_Check_Sensor_ID(Init_Laser_No);
VL53L4CD_Setup_And_Initialize_Sensor(Init_Laser_No);
VL53L4CD_Calibrate_Sensor(); // Alle enabled lasers
VL53L4CD_Setup_And_Start_Continuous_Ranging(Init_Laser_No);
delay (10); // Stability
} // VL53L4CD_Initialize_Lasers
void VL53L4CD_Set_I2C_Adresse(const byte Set_Laser_No) {
// Set the samer address for all sensors (Adafruit = 0x29 / TS = 0x52)
if (VL53L4CD_Error_Status[Set_Laser_No] == OK) {
VL53L4CD_Status = VL53L4CD_Lasers_List[Set_Laser_No]->VL53L4CD_SetI2CAddress(VL53L4CD_I2C_Address);
VL53L4CD_Print_Error(VL53L4CD_Status, Set_Laser_No, 2);
} // VL53L4CD_Set_I2C_Adresse
void VL53L4CD_Check_Sensor_ID(const byte ID_Laser_No) {
char Hex_To_Char[7];
uint16_t VL53L4CD_ID = 0;
if (VL53L4CD_Error_Status[ID_Laser_No] == OK) {
VL53L4CD_Status = VL53L4CD_Lasers_List[ID_Laser_No]->VL53L4CD_GetSensorId(&VL53L4CD_ID);
if (VL53L4CD_Debug_Enabled[ID_Laser_No] == YES) {
snprintf(Hex_To_Char, sizeof(Hex_To_Char), "0x%04X", VL53L4CD_ID);
VL53L4CD_Print_Header(ID_Laser_No); PortPrint(F("Sensor ID: ")); PortPrintln(Hex_To_Char);
if (VL53L4CD_ID != VL53L4CD_Sensor_ID) {
VL53L4CD_Print_Error(250, ID_Laser_No, 3);
} // VL53L4CD_Check_Sensor_ID
void VL53L4CD_Setup_And_Initialize_Sensor(const byte Set_Laser_No) {
// Initialize and setup sensor
VL53L4CD_Status = VL53L4CD_Lasers_List[Set_Laser_No]->VL53L4CD_SensorInit(); // NOT InitSensor!
VL53L4CD_Print_Error(VL53L4CD_Status, Set_Laser_No, 4);
// Set offset distance mm.
VL53L4CD_Status = VL53L4CD_Lasers_List[Set_Laser_No]->VL53L4CD_SetOffset(VL53L4CD_Offset_Dist_MM[Set_Laser_No]);
VL53L4CD_Print_Error(VL53L4CD_Status, Set_Laser_No, 5);
// Set crosstalk KCPS
VL53L4CD_Status = VL53L4CD_Lasers_List[Set_Laser_No]->VL53L4CD_SetXtalk(VL53L4CD_Xtalk_KCPS[Set_Laser_No]);
VL53L4CD_Print_Error(VL53L4CD_Status, Set_Laser_No, 6);
} // VL53L4CD_Setup_And_Initialize_Sensor
// I2C laser calibration ------------------------------------------------------------------------------
void VL53L4CD_Calibrate_Sensor() {
// Calibrate Distance first (1)
if(VL53L4CD_Offset_Calibrate == YES) {
VL53L4DC_Calibrate_Offset_Distance(); // Loop all active Lasers
// Calibrate Xtalk next (2)
if(VL53L4CD_Xtalk_Calibrate == YES) {
VL53L4DC_Calibrate_Xtalk_Distance(); // Loop all active Lasers
} // VL53L4CD_Calibrate_Sensor
void VL53L4DC_Calibrate_Offset_Distance() {
const int16_t Target_Distance_MM = 100; // ST recommandation
const int16_t Number_Of_Samples = 20; // ST recommandation
int16_t Target_Measured_Offset_MM = 0; // +/- mm
byte Offset_Laser_No = 0;
Offset_Laser_No = VL53L4CD_Laser_ON_List[Index];
if (VL53L4CD_Error_Status[Offset_Laser_No] == OK) {
PortPrintln();
for (byte index = 0; index < 81; index++) { PortPrint(F("-")); } PortPrintln();
VL53L4CD_Print_Header(Offset_Laser_No); PortPrintln(F("Calibrating sensor distance procedure."));
PortPrintln(F("Use GRAY cardboard / paper as reflektion object and indoor low light environment."));
PortPrint (F("Target distance must be [mm]: ")); PortPrintln(Target_Distance_MM);
VL53L4CD_Status = VL53L4CD_Lasers_List[Offset_Laser_No]->VL53L4CD_GetOffset(&Target_Measured_Offset_MM);
PortPrint (F("Current offset distance [mm]: ")); PortPrintln(Target_Measured_Offset_MM);
VL53L4CD_Print_Error(VL53L4CD_Status, Offset_Laser_No, 8);
VL53L4CD_Status = VL53L4CD_Lasers_List[Offset_Laser_No]->VL53L4CD_CalibrateOffset( \
Target_Distance_MM, &Target_Measured_Offset_MM, Number_Of_Samples);
PortPrint (F("NEW calibration offset [mm]: ")); PortPrintln(Target_Measured_Offset_MM);
VL53L4CD_Print_Error(VL53L4CD_Status, Offset_Laser_No, 9);
PortPrint (F("Remember to type in new value: VL53L4CD_Offset_Dist_MM[")); PortPrint(Offset_Laser_No); PortPrintln(F("]"));
delay(10000);
} // VL53L4DC_Calibrate_Offset_Distance
void VL53L4DC_Calibrate_Xtalk_Distance() {
const uint16_t Number_Of_Samples = 20; // ST recommandation
uint16_t Measured_Xtalk_KCPS = 0;
byte Xtalk_Laser_No = 0;
Xtalk_Laser_No = VL53L4CD_Laser_ON_List[Index];
if (VL53L4CD_Laser_I2C_ON[Xtalk_Laser_No] == YES && VL53L4CD_Error_Status[Xtalk_Laser_No] == OK) {
PortPrintln();
VL53L4CD_Print_Header(Xtalk_Laser_No); PortPrintln(F("Calibrating sensor Crosstalk procedure."));
PortPrint (F("Maximum measured ranging distance without under-ranging [mm]: ")); PortPrintln(VL53L4CD_Xtalk_Distance_MM);
VL53L4CD_Status = VL53L4CD_Lasers_List[Xtalk_Laser_No]->VL53L4CD_GetXtalk(&Measured_Xtalk_KCPS);
PortPrint (F("Current crosstalk compensation [KPCS]: ")); PortPrintln(Measured_Xtalk_KCPS);
VL53L4CD_Print_Error(VL53L4CD_Status, Xtalk_Laser_No, 10);
VL53L4CD_Status = VL53L4CD_Lasers_List[Xtalk_Laser_No]->VL53L4CD_CalibrateXtalk( \
VL53L4CD_Xtalk_Distance_MM, &Measured_Xtalk_KCPS, Number_Of_Samples);
PortPrint (F("NEW crosstalk compensation [KCPS]: ")); PortPrintln(Measured_Xtalk_KCPS);
VL53L4CD_Print_Error(VL53L4CD_Status, Xtalk_Laser_No, 11);
PortPrint (F("Remember to type in new value: VL53L4CD_Xtalk_KCPS[")); PortPrint(Xtalk_Laser_No); PortPrintln(F("]"));
delay(10000);
} // VL53L4DC_Calibrate_Xtalk_Distance
// I2C laser processing ---------------------------------------------------------------------
void TCA_PCA_Select_Channel(const byte TCA_PCA_Channel_No) {
// 4 or 8 channel I2C Multiplexer
if (VL53L4CD_Error_Status[TCA_PCA_Channel_No] == OK) {
byte End_Status = 0;
Wire.write(1 << TCA_PCA_Channel_No); // BANNED left one bit
End_Status = Wire.endTransmission();
if (End_Status > 0) {
VL53L4CD_Error_Status[TCA_PCA_Channel_No] = Error;
PortPrint(F("TCA_PCA channel [")); PortPrint(TCA_PCA_Channel_No); PortPrint(F("] ERROR! "));
VL53L4CD_Print_Error_Text (End_Status);
} // TCA_PCA_Select_Channel
void VL53L4CD_Setup_And_Start_Continuous_Ranging(const byte Start_Laser_No) {
// Program the fastest speed. Do not change.
const word Time_Budget_MS = 10; // 10 Milliseconds
const word Inter_Measure_MS = 0; // 0 Milliseconds
if (VL53L4CD_Error_Status[Start_Laser_No] == OK) {
VL53L4CD_Status = VL53L4CD_Lasers_List[Start_Laser_No]->VL53L4CD_SetRangeTiming(Time_Budget_MS, Inter_Measure_MS);
VL53L4CD_Print_Error(VL53L4CD_Status, Start_Laser_No, 12);
// Start Measurements
VL53L4CD_Status = VL53L4CD_Lasers_List[Start_Laser_No]->VL53L4CD_StartRanging();
VL53L4CD_Print_Error(VL53L4CD_Status, Start_Laser_No, 13);
} // VL53L4CD_Set_And_Start_Continuous_Ranging
bool VL53L4CD_Read_Sensors_Sequentially() {
if (VL53L4CD_Loop_ON_Index >= VL53L4CD_Max_ON_Index) {
VL53L4CD_Active_Sensor = VL53L4CD_Laser_ON_List[VL53L4CD_Loop_ON_Index];
VL53L4CD_Loop_ON_Index++;
return VL53L4CD_Read_One_Sensors(VL53L4CD_Active_Sensor);
} // VL53L4CD_Read_Sensors_Sequentially
bool VL53L4CD_Read_One_Sensors (const byte Read_One_Laser) {
if (VL53L4CD_Laser_I2C_ON[Read_One_Laser] == YES && VL53L4CD_Error_Status[Read_One_Laser] == OK) {
VL53L4CD_Active_Sensor = Read_One_Laser;
TCA_PCA_Select_Channel(Read_One_Laser);
if (VL53L4CD_Error_Status[Read_One_Laser] == OK) {
return VL53L4CD_Read_And_Check(Read_One_Laser);
return false;
} // VL53L4CD_Read_One_Sensors
bool VL53L4CD_Read_And_Check(const byte Read_Laser_No) {
bool Return_Status = false;
unsigned long Start_Time_MS;
byte New_Data_Ready = 0;
Start_Time_MS = millis();
VL53L4CD_Status = VL53L4CD_Lasers_List[Read_Laser_No]->VL53L4CD_CheckForDataReady(&New_Data_Ready); // 1,2 milliseconds
if ((!VL53L4CD_Status == OK) && (New_Data_Ready == YES)) {
// (Mandatory) Clear HW interrupt to restart measurements
VL53L4CD_Lasers_List[Read_Laser_No]->VL53L4CD_ClearInterrupt(); // 0,5 milliseconds
VL53L4CD_Lasers_List[Read_Laser_No]->VL53L4CD_GetResult(&VL53L4CD_Result); // 4,0 Milliseconds
VL53L4CD_Print_Debug_Info(Read_Laser_No);
VL53L4CD_check_Ambient_Light(Read_Laser_No);
if (VL53L4CD_Result.range_status == VL53L4CD_ERROR_NONE &&
VL53L4CD_Result.distance_mm > 0 &&
VL53L4CD_Result.sigma_mm <= VL53L4CD_Max_Sigma_MM &&
VL53L4CD_Result.signal_rate_kcps >= VL53L4CD_Min_Signal_KPCS) {
VL53L4CD_Blocking_Calculate_And_Check(Read_Laser_No);
Return_Status = VL53L4CD_Check_Min_And_Max_Distance(Read_Laser_No);
// millis(): The number will overflow (go back to zero), after approximately 50 days.
// https://www.gammon.com.au/millis
Offset_Delay_Time = (word)(millis() - Start_Time_MS);
if (Offset_Delay_Time >= Loop_Delay_Time) {
Offset_Delay_Time = Loop_Delay_Time; // Zero delay time
return Return_Status;
} //VL53L4CD_Read_And_Check
void VL53L4CD_check_Ambient_Light(const byte Ambient_Laser_No) {
word Average_Ambient_KCPS = 0;
VL53L4CD_Average_Ambient_KCPS[Ambient_Laser_No] = VL53L4CD_Average_Ambient_KCPS[Ambient_Laser_No] + (long)VL53L4CD_Result.ambient_rate_kcps;
if (VL53L4CD_Average_Ambient_Count[Ambient_Laser_No] == VL53L4CD_Max_Ambient_Count) {
Average_Ambient_KCPS = (word)(VL53L4CD_Average_Ambient_KCPS[Ambient_Laser_No] / VL53L4CD_Average_Ambient_Count[Ambient_Laser_No]);
if (Average_Ambient_KCPS > VL53L4CD_Max_Ambient_KCPS) {
VL53L4CD_Print_Header(Ambient_Laser_No);
PortPrint(F("ERROR! Ambient light is to high (KCPS): ")); PortPrintln(Average_Ambient_KCPS);
VL53L4CD_Average_Ambient_KCPS[Ambient_Laser_No] = 0;
VL53L4CD_Average_Ambient_Count[Ambient_Laser_No] = 0;
else {
VL53L4CD_Average_Ambient_Count[Ambient_Laser_No]++;
} // VL53L4CD_check_Ambient_Light
void VL53L4CD_Print_Debug_Info(const byte Info_Laser_No) {
char Print_Result[120];
if (VL53L4CD_Debug_Enabled[Info_Laser_No] == YES) {
snprintf(Print_Result, sizeof(Print_Result),
"Status = %2u, Distance = %4u mm, Signal rate= %5u kcps, Sigma = %3u, Ambient light = %5u",
VL53L4CD_Result.range_status, VL53L4CD_Result.distance_mm, VL53L4CD_Result.signal_rate_kcps,
VL53L4CD_Result.sigma_mm, VL53L4CD_Result.ambient_rate_kcps);
VL53L4CD_Print_Header(Info_Laser_No); PortPrintln(Print_Result);
if (VL53L4CD_Print_Range_Status == YES) {
VL53L4CD_Print_Ranging_Error(Info_Laser_No, VL53L4CD_Result.range_status);
} // VL53L4CD_Print_Debug_Info
bool VL53L4CD_Check_Min_And_Max_Distance(const byte Dist_Laser_No) {
if (VL53L4CD_Result.distance_mm >= VL53L4CD_Min_Distance_MM[Dist_Laser_No] && \
VL53L4CD_Result.distance_mm <= VL53L4CD_Max_Distance_MM[Dist_Laser_No]) {
if (VL53L4CD_Print_Object_Detect == YES) {
VL53L4CD_Print_Header(Dist_Laser_No); PortPrint(F("Object detected (mm): "));
PortPrint(VL53L4CD_Result.distance_mm); PortPrint(F(" Detection zone: "));
PortPrint(VL53L4CD_Min_Distance_MM[Dist_Laser_No]); PortPrint(F(" - "));
PortPrintln(VL53L4CD_Max_Distance_MM[Dist_Laser_No]);
return true;
return false;
} // Check_Min_And_Max_Distance
void VL53L4CD_Blocking_Calculate_And_Check(const byte Average_Laser_No) {
word Average_Distance_MM;
if (VL53L4CD_Blocking_Detect[Average_Laser_No] == YES) {
VL53L4CD_Average_Block_MM[Average_Laser_No] += (long)VL53L4CD_Result.distance_mm;
if (VL53L4CD_Average_Block_Count[Average_Laser_No] == VL53L4CD_Max_Block_Count) {
Average_Distance_MM = (word)(VL53L4CD_Average_Block_MM[Average_Laser_No] / VL53L4CD_Average_Block_Count[Average_Laser_No]);
VL53L4CD_Average_Block_MM[Average_Laser_No] = 0;
VL53L4CD_Average_Block_Count[Average_Laser_No] = 0;
VL53L4CD_Blocking_Check(Average_Laser_No, Average_Distance_MM);
else {
VL53L4CD_Average_Block_Count[Average_Laser_No]++;
} // VL53L4CD_Blocking_Calculate_And_Check
void VL53L4CD_Blocking_Check(const byte Check_Laser_No, const word Check_Average_Distance_MM) {
if (Check_Average_Distance_MM <= VL53L4CD_Max_BLock_Dist_MM) {
PortPrint(F("ERROR! Sensor beam blocked (mm): ")); PortPrint(Check_Average_Distance_MM);
PortPrint(F(" Blocking zone: 0 - ")); PortPrintln(VL53L4CD_Max_BLock_Dist_MM);
} // L53L4CD_Blocking_Check
// I2C laser error handling ------------------------------------------------------------------------
void VL53L4CD_Check_Parameters() {
byte Chek_Laser_No = 0;
Chek_Laser_No = VL53L4CD_Laser_ON_List[Index];
if (VL53L4CD_Min_Distance_MM[Chek_Laser_No] < 25) {
VL53L4CD_Print_Header(Chek_Laser_No);
PortPrint(F("Warning! VL53L4CD_Min_Distance_MM[")); PortPrint(Chek_Laser_No);
PortPrint(F("] = ")); PortPrint(VL53L4CD_Min_Distance_MM[Chek_Laser_No]);
PortPrintln(F(" Should be greater than or equal to 25 mm."));
if (VL53L4CD_Min_Distance_MM[Chek_Laser_No] <= VL53L4CD_Max_BLock_Dist_MM) {
PortPrint(F(" Should be greater than or equal to VL53L4CD_Max_BLock_Dist_MM = "));
if (VL53L4CD_Max_Distance_MM[Chek_Laser_No] > 800) {
PortPrint(F("Warning! VL53L4CD_Max_Distance_MM[")); PortPrint(Chek_Laser_No);
PortPrint(F("] = ")); PortPrint(VL53L4CD_Max_Distance_MM[Chek_Laser_No]);
PortPrintln(F(" Should be less than or equal to 800 mm."));
if (VL53L4CD_Min_Distance_MM[Chek_Laser_No] >=VL53L4CD_Max_Distance_MM[Chek_Laser_No]) {
PortPrint (F("ERROR! VL53L4CD_Max_Distance_MM must be greater than VL53L4CD_Min_Distance_MM"));
if (TCA_PCA_I2C_MUX_ON == YES && TCA_PCA_I2C_MUX_Status == OK && VL53L4CD_Max_ON_Index == 0) {
PortPrintln(F("Warning! TCA_PCA_I2C_MUX_ON = YES - but no lasers [0-7] are enabled!"));
} // Check_VL53L4CD_Parameters
void VL53L4CD_Print_Error(const byte Print_Error_Status, const byte Print_Laser_No, const byte Function_Numer) {
if (Print_Error_Status != 0) {
VL53L4CD_Error_Status[Print_Laser_No] = Error;
VL53L4CD_Print_Header(Print_Laser_No);
switch (Function_Numer) {
case 1: PortPrint(F("Check_I2C_Connected")); break;
case 2: PortPrint(F("Set_I2C_Adresse")); break;
case 3: PortPrint(F("GetSensorID")); break;
case 4: PortPrint(F("SensorInit")); break;
case 5: PortPrint(F("SetOffset")); break;
case 6: PortPrint(F("SetXtalk")); break;
case 7: PortPrint(F("SetDetectionThresholds")); break;
case 8: PortPrint(F("GetOffset")); break;
case 9: PortPrint(F("CalibrateOffset")); break;
case 10: PortPrint(F("GetXtalk")); break;
case 11: PortPrint(F("CalibrateXtalk")); break;
case 12: PortPrint(F("SetRangeTiming")); break;
case 13: PortPrint(F("StartRanging")); break;
default:
PortPrintln(F("Unknown function!"));
PortPrint(F(" - ERROR! "));
VL53L4CD_Print_Error_Text (Print_Error_Status);
void VL53L4CD_Print_Error_Text(const byte Print_Error_Status) {
switch (Print_Error_Status) {
case 0: break; // VL53L4CD_ERROR_NONE
case 1: PortPrintln(F("Data too long to fit in transmit buffer.")); break;
case 2: PortPrintln(F("Received NACK on transmit of address.")); break;
case 3: PortPrintln(F("Received NACK on transmit of data.")); break;
case 4: PortPrintln(F("Other error.")); break;
case 5: PortPrintln(F("Timeout")); break;
case 250: PortPrintln(F("Wrong sensor ID.")); break;
case 253: PortPrintln(F("VL53L4CD_ERROR_XTALK_FAILED.")); break;
case 254: PortPrintln(F("VL53L4CD_ERROR_INVALID_ARGUMENT.")); break;
case 255: PortPrintln(F("VL53L4CD_ERROR_TIMEOUT.")); break;
default:
PortPrintln(F("Unknown error!"));
} // L53L4CD_Print_Error_Text
void VL53L4CD_Print_Ranging_Error(const byte Range_Laser_No, const byte Print_Ranging_Error) {
// Some error occurred, print it out!
if (Print_Ranging_Error != 0) {
VL53L4CD_Print_Header(Range_Laser_No);
switch (Print_Ranging_Error) {
case 0: break; // Returned distance is valid
case 1: PortPrintln(F("WARNING! Sigma is above the defined threshold.")); break;
case 2: PortPrintln(F("WARNING! Signal is below the defined threshold.")); break;
case 3: PortPrintln(F("ERROR! Measured distance is below detection threshold.")); break;
case 4: PortPrintln(F("ERROR! Phase out of valid limit (max 1.200 mm).")); break;
case 5: PortPrintln(F("ERROR! Hardware fail.")); break;
case 6: PortPrintln(F("WARNING! Phase valid but no wrap around check performed.")); break;
case 7: PortPrintln(F("ERROR! Wrapped target, phase does not match.")); break;
case 8: PortPrintln(F("ERROR! Processing fail.")); break;
case 9: PortPrintln(F("ERROR! Crosstalk signal fail.")); break;
case 10: PortPrintln(F("ERROR! Interrupt error.")); break;
case 11: PortPrintln(F("ERROR! Merged target.")); break;
case 12: PortPrintln(F("ERROR! Signal is too low.")); break;
case 255: PortPrintln(F("ERROR! Other error (e.g boot).")); break;
default:
PortPrintln(F("UNKNOWN error!"));
} // VL53L4CD_Print_Ranging_Error
void VL53L4CD_Print_Header(const byte Header_Laser_No) {
// General header info
PortPrint(F("VL53L4CD [")); PortPrint(Header_Laser_No); PortPrint(F("] "));
void Set_Error_Sound_Count(byte Set_Error_Count) {
if (Set_Error_Count > Error_Sound_Count) {
Error_Sound_Count = Set_Error_Count;
} // Set_Error_Sound_Count
void Error_Alarm_Sound() {
if (Error_Sound_Count > 0) {
if (Error_Sound_ON == NO) {
// analogWrite(LED_Red_Pin, LED_Red_ON);
Error_Sound_ON = YES;
if (Buzzer_Sound_Process() == true) { // Sound process ended
Error_Sound_Count--; // Next sound process (if any)
if (Error_Sound_Count == 0) {
// analogWrite(LED_Red_Pin, LED_Red_OFF);
} // Error_Alarm_Sound
bool Buzzer_Sound_Process() {
if (Buzzer_Start_Step == YES) {
Buzzer_Start_Step = NO;
Buzzer_Start_Time = millis();
if (Error_Sound_Pitch_Hz[Buzzer_Step_Count] == 0) {
Buzzer_Off();
else {
tone(Buzzer_Pin, Error_Sound_Pitch_Hz[Buzzer_Step_Count]);
else {
if (word(millis() - Buzzer_Start_Time) >= Error_Sound_Duration_MS[Buzzer_Step_Count]) {
Buzzer_Step_Count++;
if (Buzzer_Step_Count > Error_Sound_Max_Step) {
Buzzer_Off();
return true; // End of sound process
return false; // Continue sound process
} // Buzzer_Sound_Process
void Buzzer_Off() {
noTone(Buzzer_Pin);
// Buzzer YL-44 is active on LOW! KY-006 on HIGH!
digitalWrite(Buzzer_Pin, Buzzer_Silent_Mode);
} // Buzzer_Off
// end of program
