Hello guys,
I'm a newbie, but I would like to build a robot that follows objects and persons with Arduino.
I know that the simplest way to do this should be with one servo and one ultrasonic sensor:
How can I do it?
There is a video that shows this project, but the author says that he lost the code....
If you can help me with this project, I will be glad to you.
Thank you very much
I did. The robot did NOT follow a person. It turned to face the nearest object.
It made NO attempt to maintain a constant distance from that object. It made no difference what that object was.
Extending the "face the nearest object at all times" capability to maintain a constant distance is MUCH harder. Extending the "face the nearest object at all times" capability to deal with a specific object is MUCH harder.
Following a specific object at a specific distance is harder still.
But, don't let that discourage you. You just might be the one that makes it actually work. Keep us posted.
PaulS:
So, if you did it, do you have the code for following only objects?
