Need help with OLED NewHavenDisplay NHD-3.12-25664UCB2 try to connect to Arduino MEGA 2560. upload drivers from the Github and from NHD web library. Not working blank.
Tried to connect SPI 4 wires connection. Tried 3.3volts and 5 volts.
Im not a programmer just need to use small display on my project. Thank you.
Although the example refers to the MEGA, the display datasheet indicates that it is a device with 3.3V logic. You may have to put resistive voltage dividers (5V/3v3) on the SPI lines: MISO, MOSI, SCK and CS or try a 3v3 MCU
Thank you will try 3.3volt
I run display with the 3.3volts and also with the 5volts. It won't work. I bought that board couple of years ago? it is old version of the Display, I saw that on the Forum anyway my version old. I uncomment the line according my HW version. Connect all pins to the board. Still blank not even a light on display.
Please share some photos of your fix, as well as the code you're using; With this we could have a clearer idea of what is happening to your arrangement and perhaps some user has the same arrangement or sheds some light to resolve the error
Ther is an example code for this display :https://support.newhavendisplay.com/hc/en-us/articles/4413877836311-NHD-3-12-25664UC-with-Arduino
Post your blogs! Wiring connected according to this post. I will try to upload the diagram, enable my controller line. File compile no errors. And I run it but nothing happened maybe dead? Hopefully is there any simple way to test display just make sure it is working? I bought few years ago but never have chance to do my project. thanks for trying to help.
I uncomment that line for my controller in the file!!!
I WILL POST FEW MORE PICS. THE POST IS TOO BIG NOW.
SW: Arduino IDE 2.0.1
HelloWorld.ino
Universal 8bit Graphics Library (GitHub - olikraus/u8g2: U8glib library for monochrome displays, version 2)
Copyright (c) 2016, olikraus@gmail.com
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
- Redistributions of source code must retain the above copyright notice, this list
of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice, this
list of conditions and the following disclaimer in the documentation and/or other
materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
U8g2lib Example Overview:
Frame Buffer Examples: clearBuffer/sendBuffer. Fast, but may not work with all Arduino boards because of RAM consumption
Page Buffer Examples: firstPage/nextPage. Less RAM usage, should work with all Arduino boards.
U8x8 Text Only Example: No RAM usage, direct communication with display controller. No graphics, 8x8 Text only.
// Please UNCOMMENT one of the contructor lines below
// U8g2 Contructor List (Frame Buffer)
// The complete list is available here: u8g2setupcpp · olikraus/u8g2 Wiki · GitHub
// Please update the pin numbers according to your setup. Use U8X8_PIN_NONE if the reset pin is not connected
//U8G2_NULL u8g2(U8G2_R0); // null device, a 8x8 pixel display which does nothing
//U8G2_SSD1306_128X64_NONAME_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 12, / dc=/ 4, / reset=*/ 6); // Arduboy (Production, Kickstarter Edition)
//U8G2_SSD1306_128X64_NONAME_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_F_3W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_F_3W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1306_128X64_ALT0_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // same as the NONAME variant, but may solve the "every 2nd line skipped" problem
//U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /* clock=/ SCL, / data=/ SDA, / reset=*/ U8X8_PIN_NONE); // All Boards without Reset of the Display
//U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /* clock=/ 16, / data=/ 17, / reset=*/ U8X8_PIN_NONE); // ESP32 Thing, pure SW emulated I2C
//U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=/ U8X8_PIN_NONE, / clock=/ 16, / data=*/ 17); // ESP32 Thing, HW I2C with pin remapping
//U8G2_SSD1306_128X64_NONAME_F_6800 u8g2(U8G2_R0, 13, 11, 2, 3, 4, 5, 6, A4, /enable=/ 7, /cs=/ 10, /dc=/ 9, /reset=/ 8);
//U8G2_SSD1306_128X64_NONAME_F_8080 u8g2(U8G2_R0, 13, 11, 2, 3, 4, 5, 6, A4, /enable=/ 7, /cs=/ 10, /dc=/ 9, /reset=/ 8);
//U8G2_SSD1306_128X64_VCOMH0_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // same as the NONAME variant, but maximizes setContrast() range
//U8G2_SSD1306_128X64_ALT0_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // same as the NONAME variant, but may solve the "every 2nd line skipped" problem
//U8G2_SSD1306_102X64_EA_OLEDS102_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // same as the NONAME variant, but may solve the "every 2nd line skipped" problem
//U8G2_SSD1312_128X64_NONAME_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1312_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /* clock=/ SCL, / data=/ SDA, / reset=*/ 8);
//U8G2_SSD1312_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8);
//U8G2_SH1106_128X64_NONAME_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SH1106_128X64_VCOMH0_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // same as the NONAME variant, but maximizes setContrast() range
//U8G2_SH1106_128X64_WINSTAR_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // same as the NONAME variant, but uses updated SH1106 init sequence
//U8G2_SH1106_128X32_VISIONOX_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SH1106_128X32_VISIONOX_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SH1106_72X40_WISE_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SH1107_64X128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SH1107_128X128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SH1107_128X128_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8);
//U8G2_SH1107_128X80_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8);
//U8G2_SH1107_PIMORONI_128X128_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8);
//U8G2_SH1107_SEEED_128X128_F_SW_I2C u8g2(U8G2_R0, /* clock=/ SCL, / data=/ SDA, / reset=*/ U8X8_PIN_NONE);
//U8G2_SH1107_SEEED_128X128_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SH1107_SEEED_96X96_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SH1108_160X160_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SH1122_256X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8G2_16BIT in u8g2.h
//U8G2_SH1122_256X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8G2_16BIT in u8g2.h
//U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R0, /* clock=/ 21, / data=/ 20, / reset=*/ U8X8_PIN_NONE); // Adafruit Feather M0 Basic Proto + FeatherWing OLED
//U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R0, /* clock=/ SCL, / data=/ SDA, / reset=*/ U8X8_PIN_NONE); // Adafruit Feather ESP8266/32u4 Boards + FeatherWing OLED
//U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // Adafruit ESP8266/32u4/ARM Boards + FeatherWing OLED
//U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0, /* reset=/ U8X8_PIN_NONE, / clock=/ SCL, / data=*/ SDA); // pin remapping with ESP8266 HW I2C
//U8G2_SSD1306_128X32_WINSTAR_F_HW_I2C u8g2(U8G2_R0, /* reset=/ U8X8_PIN_NONE, / clock=/ SCL, / data=*/ SDA); // pin remapping with ESP8266 HW I2C
//U8G2_SSD1306_64X48_ER_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // EastRising 0.66" OLED breakout board, Uno: A4=SDA, A5=SCL, 5V powered
//U8G2_SSD1306_48X64_WINSTAR_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1306_64X32_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1306_64X32_1F_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1306_96X16_ER_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // EastRising 0.69" OLED
//U8G2_SSD1306_72X40_ER_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // EastRising 0.42" OLED
//U8G2_SSD1306_96X40_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // EastRising 0.42" OLED
//U8G2_SSD1320_160X132_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1320_160X132_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1322_NHD_256X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8G2_16BIT in u8g2.h
//U8G2_SSD1322_NHD_256X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8G2_16BIT in u8g2.h
//U8G2_SSD1322_NHD_128X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1322_NHD_128X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
U8G2_SSD1325_NHD_128X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1325_NHD_128X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD0323_OS128064_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD0323_OS128064_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1326_ER_256X32_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // experimental driver for ER-OLED018-1
//U8G2_SSD1327_SEEED_96X96_F_SW_I2C u8g2(U8G2_R0, /* clock=/ SCL, / data=/ SDA, / reset=*/ U8X8_PIN_NONE); // Seeedstudio Grove OLED 96x96
//U8G2_SSD1327_SEEED_96X96_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // Seeedstudio Grove OLED 96x96
//U8G2_SSD1327_EA_W128128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1327_EA_W128128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1327_EA_W128128_F_SW_I2C u8g2(U8G2_R0, /* clock=/ 5, / data=/ 4, / reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1327_EA_W128128_F_HW_I2C u8g2(U8G2_R0, /* reset=/ U8X8_PIN_NONE); / Uno: A4=SDA, A5=SCL, add "u8g2.setBusClock(400000);" into setup() for speedup if possible */
//U8G2_SSD1327_MIDAS_128X128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1327_MIDAS_128X128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1327_MIDAS_128X128_F_HW_I2C u8g2(U8G2_R0, /* reset=/ U8X8_PIN_NONE); / Uno: A4=SDA, A5=SCL, add "u8g2.setBusClock(400000);" into setup() for speedup if possible */
//U8G2_SSD1327_WS_128X128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1327_WS_128X128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1327_VISIONOX_128X96_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1327_VISIONOX_128X96_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1329_128X96_NONAME_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1329_128X96_NONAME_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1329_96X96_NONAME_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1329_96X96_NONAME_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1329_96X96_NONAME_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ A4, / dc=/ A2, / reset=*/ U8X8_PIN_NONE); // Adafruit Feather 32u4 Basic Proto
//U8G2_SSD1305_128X32_NONAME_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1305_128X32_NONAME_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1305_128X32_ADAFRUIT_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1305_128X32_ADAFRUIT_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1305_128X64_ADAFRUIT_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1305_128X64_ADAFRUIT_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1305_128X64_RAYSTAR_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1305_128X64_RAYSTAR_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1309_128X64_NONAME0_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1309_128X64_NONAME0_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1309_128X64_NONAME2_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1309_128X64_NONAME2_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1316_128X32_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1316_128X32_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1317_96X96_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // not tested, not confirmed
//U8G2_SSD1317_96X96_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // not tested, not confirmed
//U8G2_SSD1318_128X96_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_SSD1318_128X96_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_LD7032_60X32_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 11, / data=/ 12, / cs=/ 9, / dc=/ 10, / reset=*/ 8); // SW SPI Nano Board
//U8G2_LD7032_60X32_F_4W_SW_I2C u8g2(U8G2_R0, /* clock=/ 11, / data=/ 12, / reset=*/ U8X8_PIN_NONE); // NOT TESTED!
//U8G2_LD7032_60X32_ALT_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 11, / data=/ 12, / cs=/ 9, / dc=/ 10, / reset=*/ 8); // SW SPI Nano Board
//U8G2_LD7032_60X32_ALT_F_4W_SW_I2C u8g2(U8G2_R0, /* clock=/ 11, / data=/ 12, / reset=*/ U8X8_PIN_NONE); // NOT TESTED!
//U8G2_UC1701_EA_DOGS102_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1701_EA_DOGS102_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_PCD8544_84X48_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Nokia 5110 Display
//U8G2_PCD8544_84X48_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Nokia 5110 Display
//U8G2_PCF8812_96X65_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Could be also PCF8814
//U8G2_PCF8812_96X65_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Could be also PCF8814
//U8G2_HX1230_96X68_F_3W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / reset=*/ 8);
//U8G2_HX1230_96X68_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_KS0108_128X64_F u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /dc=/ 17, /cs0=/ 14, /cs1=/ 15, /cs2=/ U8X8_PIN_NONE, /* reset=*/ U8X8_PIN_NONE); // Set R/W to low!
//U8G2_KS0108_ERM19264_F u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /dc=/ 17, /cs0=/ 14, /cs1=/ 15, /cs2=/ 16, /* reset=*/ U8X8_PIN_NONE); // Set R/W to low!
//U8G2_HD44102_100X64_F u8g2(U8G2_R0, 4, 5, 6, 7, 8, 9, 10, 11, /enable=/ 2, /dc=/ 3, /cs0=/ A0, /cs1=/ A1, /cs2=/ A2, /* reset=*/ U8X8_PIN_NONE); // Set R/W to low!
//U8G2_T7932_150X32_F u8g2(U8G2_R0, 4, 5, 6, 7, 8, 9, 10, 11, /enable=/ 2, /dc=/ 3, /cs0=/ A0, /cs1=/ A1, /cs2=/ A2, /* reset=*/ U8X8_PIN_NONE); // Set R/W to low!
//U8G2_ST7920_256X32_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /cs=/ U8X8_PIN_NONE, /dc=/ 17, /reset=/ U8X8_PIN_NONE);
//U8G2_ST7920_256X32_F_SW_SPI u8g2(U8G2_R0, /* clock=/ 18 / A4 / , / data=/ 16 / A2 /, / CS=/ 17 / A3 /, / reset=*/ U8X8_PIN_NONE);
//U8G2_ST7920_192X32_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /cs=/ U8X8_PIN_NONE, /dc=/ 17, /reset=/ U8X8_PIN_NONE);
//U8G2_ST7920_192X32_F_SW_SPI u8g2(U8G2_R0, /* clock=/ 18 / A4 / , / data=/ 16 / A2 /, / CS=/ 17 / A3 /, / reset=*/ U8X8_PIN_NONE);
//U8G2_ST7920_128X64_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18 /* A4 /, /cs=/ U8X8_PIN_NONE, /dc/rs=/ 17 / A3 /, /reset=/ 15 / A1 */); // Remember to set R/W to 0
//U8G2_ST7920_128X64_F_SW_SPI u8g2(U8G2_R0, /* clock=/ 18 / A4 / , / data=/ 16 / A2 /, / CS=/ 17 / A3 /, / reset=*/ U8X8_PIN_NONE);
//U8G2_ST7920_128X64_F_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / CS=/ 10, / reset=*/ 8);
//U8G2_ST7920_128X64_F_SW_SPI u8g2(U8G2_R0, /* clock=/ 14, / data=/ 13, / CS=/ 15, / reset=*/ 16); // Feather HUZZAH ESP8266, E=clock=14, RW=data=13, RS=CS
//U8G2_ST7920_128X64_F_HW_SPI u8g2(U8G2_R0, /* CS=/ 10, / reset=*/ 8);
//U8G2_ST7920_128X64_F_HW_SPI u8g2(U8G2_R0, /* CS=/ 15, / reset=*/ 16); // Feather HUZZAH ESP8266, E=clock=14, RW=data=13, RS=CS
//U8G2_ST7528_ERC16064_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7528_ERC16064_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_EA_DOGM128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_EA_DOGM128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_64128N_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_64128N_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_EA_DOGM132_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ U8X8_PIN_NONE); // DOGM132 Shield
//U8G2_ST7565_EA_DOGM132_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ U8X8_PIN_NONE); // DOGM132 Shield
//U8G2_ST7565_ZOLEN_128X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_ZOLEN_128X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_LM6059_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Adafruit ST7565 GLCD
//U8G2_ST7565_LM6059_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Adafruit ST7565 GLCD
//U8G2_ST7565_KS0713_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // KS0713 controller
//U8G2_ST7565_KS0713_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // KS0713 controller
//U8G2_ST7565_LX12864_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_LX12864_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_ERC12864_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_ERC12864_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_ERC12864_ALT_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // contrast improved version for ERC12864
//U8G2_ST7565_ERC12864_ALT_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // contrast improved version for ERC12864
//U8G2_ST7565_NHD_C12832_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_NHD_C12832_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_NHD_C12864_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_NHD_C12864_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_JLX12864_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7565_JLX12864_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_PI_132X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 7, / dc=/ 9, / reset=*/ 8); // Pax Instruments Shield, LCD_BL=6
//U8G2_ST7567_PI_132X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 7, / dc=/ 9, / reset=*/ 8); // Pax Instruments Shield, LCD_BL=6
//U8G2_ST7567_JLX12864_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 7, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_JLX12864_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 7, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_122X32_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 7, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_122X32_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 7, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_OS12864_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 7, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_OS12864_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 7, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_ENH_DG128064_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_ENH_DG128064_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_ENH_DG128064I_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_ENH_DG128064I_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7567_64X32_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_ST7567_HEM6432_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_ST7571_128X128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7571_128X128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7571_128X96_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7571_128X96_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7586S_ERC240160_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7586S_YMC240160_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST75160_JM16096_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST75160_JM16096_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST75256_JLX172104_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST75256_JLX172104_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST75256_JLX19296_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST75256_JLX19296_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST75256_JLX256128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_WO256X128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_WO256X128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 9, / data=/ 8, / cs=/ 7, / dc=/ 6, / reset=*/ 5); // MKR Zero, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 7, / dc=/ 6, / reset=*/ 5); // MKR Zero, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160M_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160M_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160_ALT_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160_ALT_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX240160_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST75256_JLX240160_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST75256_JLX25664_F_2ND_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8); // Due, 2nd I2C, enable U8g2 16 bit mode for this display
//U8G2_ST75320_JLX320240_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_ST75320_JLX320240_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16 bit mode for this display
//U8G2_NT7534_TG12864R_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_NT7534_TG12864R_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_ST7588_JLX12864_F_SW_I2C u8g2(U8G2_R0, /* clock=/ SCL, / data=/ SDA, / reset=*/ 5);
//U8G2_ST7588_JLX12864_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ 5);
//U8G2_IST3020_ERC19264_F_6800 u8g2(U8G2_R0, 44, 43, 42, 41, 40, 39, 38, 37, /enable=/ 28, /cs=/ 32, /dc=/ 30, /reset=/ 31); // Connect WR pin with GND
//U8G2_IST3020_ERC19264_F_8080 u8g2(U8G2_R0, 44, 43, 42, 41, 40, 39, 38, 37, /enable=/ 29, /cs=/ 32, /dc=/ 30, /reset=/ 31); // Connect RD pin with 3.3V
//U8G2_IST3020_ERC19264_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_IST7920_128X128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Round display
//U8G2_IST7920_128X128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Round display
//U8G2_LC7981_160X80_F_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /cs=/ 14, /dc=/ 15, /reset=/ 16); // Connect RW with GND
//U8G2_LC7981_160X160_F_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /cs=/ 14, /dc=/ 15, /reset=/ 16); // Connect RW with GND
//U8G2_LC7981_240X128_F_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /cs=/ 14, /dc=/ 15, /reset=/ 16); // Connect RW with GND
//U8G2_LC7981_240X64_F_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /cs=/ 14, /dc=/ 15, /reset=/ 16); // Connect RW with GND
//U8G2_SED1520_122X32_F u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /dc=/ A0, /e1=/ A3, /e2=/ A2, /* reset=*/ A4); // Set R/W to low!
//U8G2_T6963_240X128_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable/wr=/ 17, /cs/ce=/ 14, /dc=/ 15, /reset=/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_T6963_256X64_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable/wr=/ 17, /cs/ce=/ 14, /dc=/ 15, /reset=/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_T6963_160X80_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable/wr=/ 17, /cs/ce=/ 14, /dc=/ 15, /reset=/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_T6963_128X64_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable/wr=/ 17, /cs/ce=/ 14, /dc=/ 15, /reset=/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_T6963_128X64_ALT_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable/wr=/ 17, /cs/ce=/ 14, /dc=/ 15, /reset=/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_SED1330_240X128_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 17, /cs=/ 14, /dc=/ 15, /reset=/ 16); // Connect RD with +5V, FG with GND
//U8G2_SED1330_240X128_F_6800 u8g2(U8G2_R0, 13, 11, 2, 3, 4, 5, 6, A4, /enable=/ 7, /cs=/ 10, /dc=/ 9, /reset=/ 8); // A0 is dc pin!
//U8G2_RA8835_NHD_240X128_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 17, /cs=/ 14, /dc=/ 15, /reset=/ 16); // Connect /RD = E with +5V, enable is /WR = RW, FG with GND, 14=Uno Pin A0
//U8G2_RA8835_NHD_240X128_F_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 17, /cs=/ 14, /dc=/ 15, /reset=/ 16); // A0 is dc pin, /WR = RW = GND, enable is /RD = E
//U8G2_UC1601_128X32_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1601_128X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1604_JLX19264_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1604_JLX19264_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1609_SLG19264_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1609_SLG19264_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1608_ERC24064_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // SW SPI, Due ERC24064-1 Test Setup
//U8G2_UC1608_DEM240064_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // SW SPI, Due ERC24064-1 Test Setup
//U8G2_UC1608_ERC240120_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1608_240X128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // SW SPI, Due ERC24064-1 Test Setup
//U8G2_UC1610_EA_DOGXL160_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ U8X8_PIN_NONE);
//U8G2_UC1610_EA_DOGXL160_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ U8X8_PIN_NONE);
//U8G2_UC1611_EA_DOGM240_F_2ND_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8); // Due, 2nd I2C, DOGM240 Test Board
//U8G2_UC1611_EA_DOGM240_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Due, SW SPI, DOGXL240 Test Board
//U8G2_UC1611_EA_DOGXL240_F_2ND_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8); // Due, 2nd I2C, DOGXL240 Test Board
//U8G2_UC1611_EA_DOGXL240_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Due, SW SPI, DOGXL240 Test Board
//U8G2_UC1611_EW50850_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /cs=/ 3, /dc=/ 16, /reset=/ 17); // 240x160, Connect RD/WR1 pin with 3.3V, CS is aktive high
//U8G2_UC1611_CG160160_F_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /enable=/ 18, /cs=/ 3, /dc=/ 16, /reset=/ 17); // Connect WR1 and CD1 pin with 3.3V, connect CS0 with cs, WR0 with enable, CD with dc
//U8G2_UC1611_IDS4073_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16Bit Mode
//U8G2_UC1611_IDS4073_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8g2 16Bit Mode
//U8G2_UC1617_JLX128128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1617_JLX128128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1638_192X96_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1638_192X96_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_UC1638_192X96_F_SW_I2C u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / reset=*/ 8); // u8g2 test board: I2C clock/data is same as SPI, , I2C default address is 0x78
//U8G2_SSD1606_172X72_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // eInk/ePaper Display
//U8G2_SSD1607_200X200_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // eInk/ePaper Display, original LUT from embedded artists
//U8G2_SSD1607_GD_200X200_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Good Display
//U8G2_SSD1607_WS_200X200_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Waveshare
//U8G2_IL3820_296X128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // WaveShare 2.9 inch eInk/ePaper Display, enable 16 bit mode for this display!
//U8G2_IL3820_V2_296X128_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // ePaper Display, lesser flickering and faster speed, enable 16 bit mode for this display!
//U8G2_MAX7219_64X8_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 11, / data=/ 12, / cs=/ 10, / dc=/ U8X8_PIN_NONE, / reset=*/ U8X8_PIN_NONE);
//U8G2_MAX7219_32X8_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 11, / data=/ 12, / cs=/ 10, / dc=/ U8X8_PIN_NONE, / reset=*/ U8X8_PIN_NONE);
//U8G2_MAX7219_8X8_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 11, / data=/ 12, / cs=/ 10, / dc=/ U8X8_PIN_NONE, / reset=*/ U8X8_PIN_NONE);
//U8G2_LS013B7DH03_128X128_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ U8X8_PIN_NONE, / reset=*/ 8); // there is no DC line for this display
//U8G2_LS027B7DH01_400X240_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ U8X8_PIN_NONE, / reset=*/ 8); // there is no DC line for this display, SPI Mode 2
//U8G2_LS027B7DH01_M0_400X240_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ U8X8_PIN_NONE, / reset=*/ 8); // there is no DC line for this display, SPI Mode 0
//U8G2_LS013B7DH05_144X168_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ U8X8_PIN_NONE, / reset=*/ 8); // there is no DC line for this display
//U8G2_ST7511_AVD_320X240_F_8080 u8g2(U8G2_R0, 13, 11, 2, 3, 4, 5, 6, A4, /enable/WR=/ 7, /cs=/ 10, /dc=/ 9, /reset=/ 8); // Enable U8g2 16Bit Mode and connect RD pin with 3.3V/5V
//U8G2_S1D15721_240X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_S1D15721_240X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_GU800_128X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
//U8G2_GU800_128X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=/ 10, / dc=/ 9, / reset=*/ 8);
// End of constructor list
void setup(void) {
u8g2.begin();
void loop(void) {
u8g2.clearBuffer(); // clear the internal memory
u8g2.setFont(u8g2_font_ncenB08_tr); // choose a suitable font
u8g2.drawStr(0,10,"Hello World!"); // write something to the internal memory
u8g2.sendBuffer(); // transfer internal memory to the display
I tried it won't work. I post couple of pictures, maybe help a little. Thanks
?? did you NOT check the link I sent ?? if you had you would be aware of the correct pin connections !
#define OLED_DC 49 //Register Select signal
#define OLED_RESET 48 //Reset signal
#define OLED_CS 47 //Chip select signal
#define OLED_CLK 52 //Serial clock signal //PB1
#define OLED_MOSI 51 //Serial data signal //PB2
then copy their sample , and check the result . ![]()
I tried on the beginning but it wont work. I think it comes on New Haven Display website like official version. I will try tonight again maybe mistake on wiring. Thanks
I did copy the sample connect all pins to
#define OLED_DC 49 //Register Select signal to NHD pin4
#define OLED_RESET 48 //Reset signal to NHD pin15
#define OLED_CS 47 //Chip select signal to NHD pin 16
#define OLED_CLK 52 //Serial clock signal //PB1 to NHD pin 7
#define OLED_MOSI 51 //Serial data signal //PB2 to NHD pin 8
/ Program for writing to NHD-3.12-25664 OLED with SSD1322 controller with Serial Interface
/ This code is written for the Arduino Mega 2560 using Serial Interface
/ Newhaven Display invests time and resources providing this open source code,
/ Please support Newhaven Display by purchasing products from Newhaven Display!
- Copyright (c) 2019, Newhaven Display International
- This code is provided as an example only and without any warranty by Newhaven Display.
- Newhaven Display accepts no responsibility for any issues resulting from its use.
- The developer of the final application incorporating any parts of this
- sample code is responsible for ensuring its safe and correct operation
- and for any consequences resulting from its use.
- See the GNU General Public License for more details.
- Use Horizontal Orientation when converting BMP to hex code to display custom image using LCD assistant.
#include <Wire.h>
Hex Table for Image Pic *
unsigned char NHD_Logo [] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xEE, 0x60, 0xFC, 0x71, 0x8E, 0x31, 0x81, 0xC1, 0xC3,
0x8F, 0xE3, 0x8C, 0x00, 0xFE, 0x0C, 0x1F, 0xE3, 0xF8, 0x70, 0x07, 0x06, 0x18, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xEE, 0x61, 0xFC, 0x73, 0xCC, 0x31, 0x81, 0xE0, 0xC3,
0x1F, 0xE3, 0xCC, 0x00, 0xFF, 0x0C, 0x3F, 0xE3, 0xFC, 0x70, 0x07, 0x07, 0x38, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0xFC, 0x00, 0x0F, 0x61, 0x80, 0x33, 0xCC, 0x31, 0x81, 0x60, 0xC7,
0x18, 0x03, 0xCC, 0x00, 0xC3, 0x8C, 0x30, 0x03, 0x0C, 0x70, 0x0D, 0x83, 0x30, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x7F, 0xED, 0x61, 0xFC, 0x3B, 0x4C, 0x3F, 0x83, 0x30, 0x66,
0x1F, 0xE3, 0x6C, 0x00, 0xC1, 0x8C, 0x3F, 0xC3, 0x0C, 0x70, 0x0D, 0x81, 0xE0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0xED, 0xE1, 0xFC, 0x1A, 0x6C, 0x3F, 0x83, 0x30, 0x66,
0x1F, 0xE3, 0x6C, 0x00, 0xC1, 0x8C, 0x3F, 0xC3, 0xFC, 0x70, 0x18, 0xC0, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xF0, 0x03, 0xC0, 0x0D, 0xE1, 0x80, 0x1E, 0x78, 0x31, 0x87, 0xF0, 0x3C,
0x18, 0x03, 0x3C, 0x00, 0xC1, 0x8C, 0x00, 0xE3, 0xF8, 0x70, 0x1F, 0xC0, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xF8, 0x07, 0x80, 0x0C, 0xE1, 0xFC, 0x1E, 0x78, 0x31, 0x86, 0x18, 0x3C,
0x1F, 0xE3, 0x1C, 0x00, 0xC3, 0x8C, 0x00, 0xE3, 0x00, 0x70, 0x3F, 0xC0, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xF8, 0x0F, 0x3F, 0xEC, 0x60, 0xFC, 0x0E, 0x70, 0x31, 0x8E, 0x1C, 0x38,
0x0F, 0xE3, 0x1C, 0x00, 0xFF, 0x0C, 0x3F, 0xE3, 0x00, 0x7F, 0x30, 0x60, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xFF, 0xFC, 0x7F, 0xEC, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xFC, 0x0C, 0x1F, 0x83, 0x00, 0x3F, 0x30, 0x60, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xFF, 0xF8, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xF8, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xF1, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x01, 0xFC, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0xFC, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x01, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
Function Commands *
void data(unsigned char d) //Data Output Serial Interface
unsigned int n;
digitalWrite(OLED_CS, LOW);
digitalWrite(OLED_DC, HIGH);
for(n=0;n<8;n++){
if((d&0x80)==0x80)
PORTB |=(1<< PORTB2); //digitalWrite(OLED_MOSI, HIGH);
PORTB &= ~(1<<PORTB2); //digitalWrite(OLED_MOSI, LOW);
while(0);
d=(d<<1);
PORTB &= ~(1<<PORTB1); //digitalWrite(OLED_CLK, LOW);
while(0);
PORTB |=(1<< PORTB1); //digitalWrite(OLED_CLK, HIGH);
while(0);
digitalWrite(OLED_CS, HIGH);
void command(unsigned char d) //Command Output Serial Interface
unsigned int n;
digitalWrite(OLED_DC, LOW);
for(n=0;n<8;n++){
if((d&0x80)==0x80)
while(0);
d=(d<<1);
while(0);
while(0);
Display Commands *
void Set_Column_Address_25664(unsigned char a, unsigned char b)
command(0x15); // Set Column Address
data(a); // Default => 0x00
data(b); // Default => 0x77
void Set_Write_RAM_25664()
command(0x5C); // Enable MCU to Write DATA RAM
void Set_Read_RAM_25664()
command(0x5D); // Enable MCU to Write DATA RAM
void Set_Row_Address_25664(unsigned char a, unsigned char b)
command(0x75); // Set Row Start and End Address
data(b); // Default => 0x7F
void Set_Remap_25664(unsigned char a, unsigned char b)
command(0xA0); // Set Remap
data(b); // Default => 0x00
void Set_Display_Start_Line_25664(unsigned char a)
command(0xA1); // Set Display RAM Display Start Line
void Set_Display_Offset_25664(unsigned char a)
command(0xA2); // Set Verticle Shift
void Display_Mode_25664(unsigned char a)
command(a); // 0xA4 => Entire Display OFF
// 0xA5 => Entire Display ON, all pixels Grayscale level 15
// 0xA6 => Normal Display (Default)
// 0xA7 => Inverse Display
void Enable_Partial_Display_25664(unsigned char a, unsigned char b)
command(0xA8); // Turns ON partial mode
data(a); // Address of start row
data(b); // Address of end row.
void Exit_Partial_Display_25664()
command(0xA9); // Exit Partial Display Mode
void Function_Selection_25664(unsigned char a)
command(0xAB); // Function Selection
data(a); // Default => 0x01
void Set_Sleep_Mode_25664(unsigned char a)
command(a); // 0xAE => Sleep Mode ON
// 0xAF => Sleep Mode OFF
void Set_Phase_Length_25664(unsigned char a)
command(0xB1); // Set Phase Length
data(a); // Default => 0x97
void Set_Display_Clock__Oscillator_Frequency_25664(unsigned char a)
command(0xB3); // Set Osc Frequency
data(a); //
void Enable_External_VSL(unsigned char a, unsigned char b)
command(0xB4); // Enable External VSL
data(a); //
data(b); //
void Set_GPIO_25664(unsigned char a)
command(0xB5); // Set GPIO
data(a); //
void Set_Second_Precharge_Period_25664(unsigned char a)
command(0xB6); // Set Second Precharge Period
data(a); //
void Default_Grayscale_Command_25664()
command(0xB9); // Sets Default Grayscale
void Set_Precharge_Voltage_25664(unsigned char a)
command(0xBB); // Set Precharge Voltage Level
data(a); // Default => 0x17
void Set_VCOMH_Voltage_25664(unsigned char a)
command(0xBE); // Set Second Precharge Period
data(a); // Default => 0x04
void Set_Contrast_Control_25664(unsigned char a)
command(0xC1); // Set Contrast Control Level
data(a); // Default => 0x7F
void Master_Contrast_Control_25664(unsigned char a)
command(0xC7); // Master Contrast Control
data(a); // Default => 0x0F
void Set_Multiplex_Ratio_25664(unsigned char a)
command(0xCA); // Set MUX Ratio
void Display_Enhancement_25664(unsigned char a)
command(0xD1); // Display Enhancement
data(a); //
data(0x20); //
void Set_Command_Lock_25664(unsigned char a)
command(0xFD); // Set Lock/Unlock Commands
data(a); // Default => 0x12
// Show Blank (Clear Screen)
void ClearPixel_25664()
unsigned int i, j;
Set_Column_Address_25664(0x1C,0x5B);
Set_Row_Address_25664(0x00,0x3F);
Set_Write_RAM_25664();
for(i=0;i<64;i++) //Columns
for(j=0;j<128;j++) //Rows
data(0x00);
delayMicroseconds(100);
// Show Checkboard (Full Screen)
void FillPixel_25664()
unsigned int i, j;
Set_Column_Address_25664(0x1C,0x5B); //1C & 5B = DISPLAY Start & End address.
for(i=0;i<32;i++) //Columns
for(j=0;j<64;j++) //Rows
data(0xFF);
data(0x00);
data(0x00);
data(0xFF);
// Show Image (Full Screen)
// 4 bits (1 Nibble) = 1 Pixel
void ImageDisplay_25664(unsigned char *image)
unsigned int i, j, buff;
Set_Remap_25664(0x14,0x11);
//Set_Remap_25664(0x06,0x11); // To Flip Orientation 180 Degrees
for(j=0;j<32;j++) //Rows
buff = *image;
buff = ((buff >> 6) & 0x03);
if(buff == 0x03){data(0xFF);}
else if(buff == 0x02){data(0xF0);}
else if(buff == 0x01){data(0x0F);}
else data(0x00);
buff = *image;
buff = ((buff >> 4) & 0x03);
else data(0x00);
buff = *image;
buff = ((buff >> 2) & 0x03);
else data(0x00);
buff = *image;
buff = (buff & 0x03);
else data(0x00);
image++;
Initialization For controller *
void OLED_Init_25664()
Set_Command_Lock_25664(0x12); // Unlock commands for OLED
Set_Display_Clock__Oscillator_Frequency_25664(0xD1); // Set Display Clock / Oscillator Frequency
Set_Multiplex_Ratio_25664(0x3F); // Set Multiplex Ratio
Set_Display_Offset_25664(0x00); // Set Display Offset
Set_Display_Start_Line_25664(0x00); // Set Display Start Line
Set_Remap_25664(0x14,0x11); // Set Remap. (A[1]) & (A[4]) can be adjusted to flip display orientation
Set_GPIO_25664(0x00); // Set GPIO
Function_Selection_25664(0x00); // Function Selection
Enable_External_VSL(0xA0,0xB5); // Enable External VSL
Set_Contrast_Control_25664(0x9F); // Set Contrast Control
Master_Contrast_Control_25664(0x0F); // Master Contrast Control
Default_Grayscale_Command_25664(); // Default Linear Grayscale Table
Set_Phase_Length_25664(0x74); // Set Phase Length
Display_Enhancement_25664(0xA2); // Display Enhancement
Set_Precharge_Voltage_25664(0x17); // Set Precharge Voltage
Set_Second_Precharge_Period_25664(0x08); // Set Second Precharge Period
Set_VCOMH_Voltage_25664(0x07); // Set VCOMH Voltage
Display_Mode_25664(0xA6); // Set Normal Display
Exit_Partial_Display_25664(); // Exit Partial Display Mode
Set_Sleep_Mode_25664(0xAF); // Sleep Mode OFF
Setup Function, to run once *
DDRB |= (1<<DDB1); //Enable CLK as Output
DDRB |= (1<<DDB2); //Enable MOSI as Output
pinMode(OLED_DC, OUTPUT);
pinMode(OLED_RESET, OUTPUT);
pinMode(OLED_CS, OUTPUT);
digitalWrite(OLED_RESET, LOW);
delay(150);
digitalWrite(OLED_RESET, HIGH);
delay(150);
OLED_Init_25664(); //Initialization Sequence
delay(10);
Loop Function, to run repeatedly *
FillPixel_25664();
ClearPixel_25664();
ImageDisplay_25664(NHD_Logo);
ClearPixel_25664();
Connected working at least can see the display working. But distorted and the scrambled line?
Any idea Tried 5volts and 3.3v looks same.
