My problem is my OLED not function when i upload to my arduino mega 2560. My project is [Automatic AC Temperature Controller using Arduino, DHT11 and IR Blaster]. But the weird is when i upload using example ssd1306_128x64_spi, my OLED can function. Can someone help me fix my code because my code already type spi. Please help me, my code dont have error.
My code
* Automatic AC Temperature control using Arduino and TSOP
* Code by: Aswinth Raj B
* Dated: 25-10-2017
* Website: www.circuitdigest.com
S.No: Component Pin Arduino Pin
1 OLED – Vcc 5V
2 OLED – Gnd Gnd
3 OLED- SCK, D0,SCL,CLK 4
4 OLED- SDA, D1,MOSI, Data 3
5 OLED- RES, RST,RESET 7
6 OLED- DC, A0 5
7 OLED- CS, Chip Select 6
8 DHT11 – Vcc 5V
9 DHT11 – Gnd Gnd
10 DHT11 – Signal 13
11 TSOP – Vcc 5V
12 TSOP – Gnd Gnd
13 IR Led – Anode 9
14 IR Led – Cathode Gnd
#include <IRremote.h> //Lib for IT Blaster and TSOP
#include <SPI.h> // Inbuilt Lib
#include <Wire.h> //Inbuilt Lib
#include <Adafruit_GFX.h> //Lib for OLED
#include <Adafruit_SSD1306.h> //Lib for OLED
#include <dht.h> //Library for dht11 Temperature and Humidity sensor (Download from Link in article)
// Assign pins for OLED (Software config.)
#define OLED_MOSI 3
#define OLED_CLK 4
#define OLED_DC 5
#define OLED_CS 6
#define OLED_RESET 7
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
#define SSD1306_LCDHEIGHT 64 //Change if you are using a Different OLED
#define DHT11_PIN 13 //Sensor output pin is connected to pin 13
dht DHT; //Sensor object named as DHT
#define Desired_temperature 27 //The desired temperature is 27*C at any time
//Decoded Remote Signals For my AC ##CHANGE IT FOR YOUR REMOTE
unsigned int ACoff[] = {4600,2500, 400,400, 300,1000, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,450, 300,1000, 350,400, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,950, 350,950, 350,450, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,900, 400,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 300,450, 300,1000, 350,400, 300,450, 300,1000, 300,1000, 350};
unsigned int ACon[] = {4600,2500, 400,400, 350,950, 350,950, 350,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 300,450, 300,1000, 350,400, 300,450, 300,450, 300,400, 350,1000, 300,400, 350,400, 350,950, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 350,950, 350,400, 300,1000, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,450, 300,1000, 300,1000, 350};
unsigned int Temp23[] = {4600,2500, 400,400, 350,950, 350,1000, 300,400, 350,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,400, 350,400, 300,450, 300,450, 300,400, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 350,400, 300,1000, 350,950, 350};
unsigned int Temp24[] = {4550,2550, 350,450, 300,1000, 300,1000, 350,400, 350,950, 350,400, 350,400, 300,450, 300,450, 300,1000, 300,450, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,400, 350,950, 350,400, 300,1000, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 300,450, 300,450, 300,1000, 300,450, 300,400, 350,1000, 300,1000, 350,400, 300,450, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,1000, 300};
unsigned int Temp25[] = {4550,2550, 400,400, 300,1000, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,450, 300,1000, 350,400, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 350,400, 300,1000, 300,1000, 350};
unsigned int Temp26[] = {4550,2550, 400,400, 300,1000, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,400, 350,1000, 300,450, 300,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 350,400, 300,1000, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 350,950, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,450, 300,1000, 300,1000, 350};
unsigned int Temp27[] = {4600,2500, 350,450, 300,1000, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 350,400, 300,1000, 300,450, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 300,450, 300,1000, 350,950, 350};
unsigned int Temp28[] = {4550,2550, 350,450, 300,1000, 300,1000, 350,400, 300,1000, 350,400, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,950, 350,400, 350,950, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 350,400, 300,1000, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 300,1000, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,450, 300,1000, 300,1000, 300};
unsigned int Temp29[] = {4550,2550, 350,400, 350,1000, 300,1000, 300,450, 300,1000, 350,400, 350,400, 300,450, 300,400, 350,1000, 300,400, 350,400, 350,950, 350,400, 350,400, 350,400, 350,950, 350,950, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,1000, 300,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 350,400, 300,1000, 300,1000, 350};
unsigned int Temp30[] = {4600,2500, 400,400, 350,1000, 300,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,950, 350,950, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 300,1000, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,450, 300,1000, 300,1000, 350};
//Change it for your remote
IRsend irsend;
int Measured_temp;
int Measured_Humi;
int AC_Temp;
char temp_error = 2;
int Pev_value;
boolean AC = false;
int khz = 38; // 38kHz carrier frequency for the NEC protocol
display.begin(SSD1306_SWITCHCAPVCC);
display.clearDisplay();
DHT.read11(DHT11_PIN); //Read the Temp and Humidity
Measured_temp = DHT.temperature + temp_error;
Measured_Humi = DHT.humidity;
// text display tests
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.print("Temperature: "); display.print(Measured_temp);display.println("C");
display.setCursor(0,10);
display.print("Humidity: "); display.print(Measured_Humi);display.println("%");
display.setCursor(0,20);
display.print("AC Temp: "); display.print(AC_Temp);display.println("C");
display.display();
if ((Measured_temp <= (Desired_temperature-3)) && AC == true) //If AC is turned on and temperature is less than 3 degree of Desired value #24 turn off
irsend.sendRaw(ACoff, sizeof(ACoff) / sizeof(ACoff[0]), khz); delay(2000);//Send signal to Turn Off the AC
AC_Temp = 0; AC=false;
if ((Measured_temp >= Desired_temperature+4) && AC == false) //If AC is off and measured Temp is greater than Desired Temp
irsend.sendRaw(ACon, sizeof(ACon) / sizeof(ACon[0]), khz); delay(2000); //Send Signal to Turn On the AC
delay(2000);
irsend.sendRaw(Temp27, sizeof(Temp27) / sizeof(Temp27[0]), khz); //Send signal to set 27*C
AC_Temp = 27; AC=true;
if ( Measured_temp != Pev_value) //Change the temperature only if the measured voltage value changes
if (Measured_temp == Desired_temperature+3) //If AC is ON and measured temp is very very high than desired
irsend.sendRaw(Temp24, sizeof(Temp24) / sizeof(Temp24[0]), khz); delay(2000);//Send signal to set 24*C
AC_Temp = 24;
if (Measured_temp == Desired_temperature+2) //If AC is ON and measured temp is very high than desired
irsend.sendRaw(Temp25, sizeof(Temp25) / sizeof(Temp25[0]), khz); delay(2000);//Send signal to set 25*C
AC_Temp = 25;
if (Measured_temp == Desired_temperature+1) //If AC is ON and measured temp is very high than desired
irsend.sendRaw(Temp26, sizeof(Temp26) / sizeof(Temp26[0]), khz); delay(2000);//Send signal to set 26*C
AC_Temp = 26;
if (Measured_temp == 27 ) //If AC is ON and measured temp is desired value
AC_Temp = 27;
if (Measured_temp == Desired_temperature-1) //If AC is ON and measured temp is low than desired value
irsend.sendRaw(Temp28, sizeof(Temp28) / sizeof(Temp28[0]), khz); delay(2000);//Send signal to set 28*C
AC_Temp = 28;
if (Measured_temp == Desired_temperature-2 ) //If AC is ON and measured temp is very low than desired value
irsend.sendRaw(Temp29, sizeof(Temp29) / sizeof(Temp29[0]), khz); delay(2000);//Send signal to set 29*C
AC_Temp = 29;
if (Measured_temp == Desired_temperature-3 ) //If AC is ON and measured temp is very very low desired value
irsend.sendRaw(Temp30, sizeof(Temp30) / sizeof(Temp30[0]), khz); delay(2000);//Send signal to set 30*C
AC_Temp = 30;
Pev_value = Measured_temp;
This is my example ssd1306_128x64_spi
This is an example for our Monochrome OLEDs based on SSD1306 drivers
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/category/63_98
This example is for a 128x64 pixel display using SPI to communicate
4 or 5 pins are required to interface.
Adafruit invests time and resources providing this open
source code, please support Adafruit and open-source
hardware by purchasing products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries,
with contributions from the open source community.
BSD license, check license.txt for more information
All text above, and the splash screen below must be
included in any redistribution.
#include <SPI.h>
#include <Wire.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for SSD1306 display connected using software SPI (default case):
#define OLED_MOSI 9
#define OLED_CLK 10
#define OLED_DC 11
#define OLED_CS 12
#define OLED_RESET 13
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
/* Comment out above, uncomment this block to use hardware SPI
#define OLED_DC 6
#define OLED_CS 7
#define OLED_RESET 8
&SPI, OLED_DC, OLED_RESET, OLED_CS);
#define NUMFLAKES 10 // Number of snowflakes in the animation example
#define LOGO_HEIGHT 16
#define LOGO_WIDTH 16
static const unsigned char PROGMEM logo_bmp[] =
{ 0b00000000, 0b11000000,
0b00000001, 0b11000000,
0b00000011, 0b11100000,
0b11110011, 0b11100000,
0b11111110, 0b11111000,
0b01111110, 0b11111111,
0b00110011, 0b10011111,
0b00011111, 0b11111100,
0b00001101, 0b01110000,
0b00011011, 0b10100000,
0b00111111, 0b11100000,
0b00111111, 0b11110000,
0b01111100, 0b11110000,
0b01110000, 0b01110000,
0b00000000, 0b00110000 };
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
// Draw a single pixel in white
display.drawPixel(10, 10, SSD1306_WHITE);
// Show the display buffer on the screen. You MUST call display() after
// drawing commands to make them visible on screen!
display.display();
delay(2000);
// display.display() is NOT necessary after every single drawing command,
// unless that's what you want...rather, you can batch up a bunch of
// drawing operations and then update the screen all at once by calling
// display.display(). These examples demonstrate both approaches...
testdrawline(); // Draw many lines
testdrawrect(); // Draw rectangles (outlines)
testfillrect(); // Draw rectangles (filled)
testdrawcircle(); // Draw circles (outlines)
testfillcircle(); // Draw circles (filled)
testdrawroundrect(); // Draw rounded rectangles (outlines)
testfillroundrect(); // Draw rounded rectangles (filled)
testdrawtriangle(); // Draw triangles (outlines)
testfilltriangle(); // Draw triangles (filled)
testdrawchar(); // Draw characters of the default font
testdrawstyles(); // Draw 'stylized' characters
testscrolltext(); // Draw scrolling text
testdrawbitmap(); // Draw a small bitmap image
// Invert and restore display, pausing in-between
display.invertDisplay(true);
display.invertDisplay(false);
testanimate(logo_bmp, LOGO_WIDTH, LOGO_HEIGHT); // Animate bitmaps
void testdrawline() {
int16_t i;
display.clearDisplay(); // Clear display buffer
for(i=0; i<display.width(); i+=4) {
display.drawLine(0, 0, i, display.height()-1, SSD1306_WHITE);
display.display(); // Update screen with each newly-drawn line
delay(1);
for(i=0; i<display.height(); i+=4) {
display.drawLine(0, 0, display.width()-1, i, SSD1306_WHITE);
display.display();
delay(1);
delay(250);
display.drawLine(0, display.height()-1, i, 0, SSD1306_WHITE);
display.display();
delay(1);
for(i=display.height()-1; i>=0; i-=4) {
display.drawLine(0, display.height()-1, display.width()-1, i, SSD1306_WHITE);
display.display();
delay(1);
delay(250);
for(i=display.width()-1; i>=0; i-=4) {
display.drawLine(display.width()-1, display.height()-1, i, 0, SSD1306_WHITE);
display.display();
delay(1);
display.drawLine(display.width()-1, display.height()-1, 0, i, SSD1306_WHITE);
display.display();
delay(1);
delay(250);
display.drawLine(display.width()-1, 0, 0, i, SSD1306_WHITE);
display.display();
delay(1);
display.drawLine(display.width()-1, 0, i, display.height()-1, SSD1306_WHITE);
display.display();
delay(1);
void testdrawrect(void) {
for(int16_t i=0; i<display.height()/2; i+=2) {
display.drawRect(i, i, display.width()-2*i, display.height()-2*i, SSD1306_WHITE);
display.display(); // Update screen with each newly-drawn rectangle
delay(1);
delay(2000);
void testfillrect(void) {
for(int16_t i=0; i<display.height()/2; i+=3) {
// The INVERSE color is used so rectangles alternate white/black
display.fillRect(i, i, display.width()-i*2, display.height()-i*2, SSD1306_INVERSE);
delay(1);
delay(2000);
void testdrawcircle(void) {
for(int16_t i=0; i<max(display.width(),display.height())/2; i+=2) {
display.drawCircle(display.width()/2, display.height()/2, i, SSD1306_WHITE);
display.display();
delay(1);
delay(2000);
void testfillcircle(void) {
for(int16_t i=max(display.width(),display.height())/2; i>0; i-=3) {
// The INVERSE color is used so circles alternate white/black
display.fillCircle(display.width() / 2, display.height() / 2, i, SSD1306_INVERSE);
display.display(); // Update screen with each newly-drawn circle
delay(1);
delay(2000);
void testdrawroundrect(void) {
for(int16_t i=0; i<display.height()/2-2; i+=2) {
display.drawRoundRect(i, i, display.width()-2*i, display.height()-2*i,
display.height()/4, SSD1306_WHITE);
display.display();
delay(1);
delay(2000);
void testfillroundrect(void) {
// The INVERSE color is used so round-rects alternate white/black
display.fillRoundRect(i, i, display.width()-2*i, display.height()-2*i,
display.height()/4, SSD1306_INVERSE);
display.display();
delay(1);
delay(2000);
void testdrawtriangle(void) {
for(int16_t i=0; i<max(display.width(),display.height())/2; i+=5) {
display.drawTriangle(
display.width()/2 , display.height()/2-i,
display.width()/2-i, display.height()/2+i,
display.width()/2+i, display.height()/2+i, SSD1306_WHITE);
display.display();
delay(1);
delay(2000);
void testfilltriangle(void) {
for(int16_t i=max(display.width(),display.height())/2; i>0; i-=5) {
// The INVERSE color is used so triangles alternate white/black
display.fillTriangle(
display.width()/2+i, display.height()/2+i, SSD1306_INVERSE);
display.display();
delay(1);
delay(2000);
void testdrawchar(void) {
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0, 0); // Start at top-left corner
display.cp437(true); // Use full 256 char 'Code Page 437' font
// Not all the characters will fit on the display. This is normal.
// Library will draw what it can and the rest will be clipped.
for(int16_t i=0; i<256; i++) {
if(i == '\n') display.write(' ');
else display.write(i);
display.display();
delay(2000);
void testdrawstyles(void) {
display.setCursor(0,0); // Start at top-left corner
display.println(F("Hello, world!"));
display.setTextColor(SSD1306_BLACK, SSD1306_WHITE); // Draw 'inverse' text
display.println(3.141592);
display.setTextSize(2); // Draw 2X-scale text
display.print(F("0x")); display.println(0xDEADBEEF, HEX);
display.display();
delay(2000);
void testscrolltext(void) {
display.setCursor(10, 0);
display.println(F("scroll"));
display.display(); // Show initial text
delay(100);
// Scroll in various directions, pausing in-between:
display.startscrollright(0x00, 0x0F);
delay(2000);
display.stopscroll();
display.startscrollleft(0x00, 0x0F);
delay(2000);
display.startscrolldiagright(0x00, 0x07);
delay(2000);
display.startscrolldiagleft(0x00, 0x07);
delay(2000);
void testdrawbitmap(void) {
display.drawBitmap(
(display.width() - LOGO_WIDTH ) / 2,
(display.height() - LOGO_HEIGHT) / 2,
logo_bmp, LOGO_WIDTH, LOGO_HEIGHT, 1);
display.display();
#define XPOS 0 // Indexes into the 'icons' array in function below
#define YPOS 1
#define DELTAY 2
void testanimate(const uint8_t *bitmap, uint8_t w, uint8_t h) {
int8_t f, icons[NUMFLAKES][3];
// Initialize 'snowflake' positions
for(f=0; f< NUMFLAKES; f++) {
icons[f][XPOS] = random(1 - LOGO_WIDTH, display.width());
icons[f][YPOS] = -LOGO_HEIGHT;
icons[f][DELTAY] = random(1, 6);
Serial.print(F("x: "));
Serial.print(icons[f][XPOS], DEC);
Serial.print(F(" y: "));
Serial.print(icons[f][YPOS], DEC);
Serial.print(F(" dy: "));
Serial.println(icons[f][DELTAY], DEC);
for(;;) { // Loop forever...
display.clearDisplay(); // Clear the display buffer
// Draw each snowflake:
display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, SSD1306_WHITE);
display.display(); // Show the display buffer on the screen
delay(200); // Pause for 1/10 second
// Then update coordinates of each flake...
icons[f][YPOS] += icons[f][DELTAY];
// If snowflake is off the bottom of the screen...
if (icons[f][YPOS] >= display.height()) {
// Reinitialize to a random position, just off the top
Im new to arduino, please help me why my OLED cant function but when using example ssd1306_128x64_spi, my OLED can function.
