I'm new to the Arduino world and recently picked up a proMicro board.
The layout of the board is as follow:
https://learn.sparkfun.com/tutorials/pro-micro--fio-v3-hookup-guide#hardware-overview-pro-micro
I've looked up the spec sheet for the LCD that I have
http://www.gaw.ru/pdf/lcd/lcm/Optrex/char/51505ade.pdf
and wired it accordingly for the LCD Hello world:
With some modifications (inspired by https://www.sparkfun.com/products/709#comment-50c4c1a4ce395fc170000000)
V0 (Vee for me - Power Supply for LCD Drive) is hooked up to a 4.7k resistor then to ground.
Backlight +/- are just hooked up to the 5v/GND
Basically all pins are shifted by 2 due to the backlight +/- being the first pin on the LCD.
My code is as follow:
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(14, 16, 10, 5, 4, 3, 2);
// set up the LCD's number of columns and rows:
lcd.begin(20, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
The LCD does light up but I see no text displayed on the LCD. Do I need to pickup a potentiometer in order to 'adjust' the contrast to see the lettering?
I tried a few different setup with less backlight or smaller resistor with no luck. Anyone see anything wrong?
