Hello all i did a very simple circuit and try allready with 3 arduino nano and get always same problem, when i drive the pinout HIGH, the tension over the resistance 220 ohms is aroud 25mV and i don't understand why ? I just use the brown and white cable to mesure the tension. The current should be 18mA
Bonjour , j'ai réalisé le simple montage suivant et fait l'essais avec 3 Arduino nano different, et quand je met la sortie à HIGH, j'ai une tension de 25mV au borne de la résistance. Je ne comprend pas pourquoi ?
take a piece of paper, a pencil and a ruler, draw the circuit with your components (with references - is the black IC an optocoupler?) and show us where you performed the measure.
please use only English in the general forum. If you want to post in French, go to the French section - but don't double post. Pick one sub forum and stick to it.
I also moved your question to the General Electronics forum as it's not an installation issue
Ha ok i understand, so i make a quick drawing and yes it's an optocoupler. For easier understanding i take it out for the moment because the problem is only with the resistor. So the mesurement is done at the both side of the resistor and i have 24mV. What can be the problem ?
