Outputs issue of load sensor and HX711 amplifier module
I'm trying to create a scale using Load Cell Sensor 1kg and Module HX711 I saw a lot of video, but when I made the connection and ran the following code:
Example: HX711_ADC - Calibration
I have the following serial monitor output:
Starting...
Startup is complete
Start calibration:
Place the load cell an a level stable surface.
Remove any load applied to the load cell.
Send 't' from serial monitor to set the tare offset.
Tare complete
Now, place your known mass on the loadcell.
Then send the weight of this mass (i.e. 100.0) from serial monitor.
Known mass is: 185.00
New calibration value has been set to: 2845.06, use this as calibration value (calFactor) in your project sketch.
Save this value to EEPROM adress 0? y/n
Value 2845.06 saved to EEPROM address: 0
End calibration
To re-calibrate, send 'r' from serial monitor.
For manual edit of the calibration value, send 'c' from serial monitor.
Load_cell output val: 250.05
Load_cell output val: 65.77
Load_cell output val: 222.28
Load_cell output val: 221.56
Load_cell output val: 212.14
Load_cell output val: 55.63
Load_cell output val: -9.42
Load_cell output val: -66.04
Load_cell output val: -75.60
Load_cell output val: -99.40
Load_cell output val: -142.55
Load_cell output val: -59.96
Load_cell output val: -157.88
Load_cell output val: -91.70
Load_cell output val: -48.55
Load_cell output val: -1.04
Load_cell output val: -91.39
Load_cell output val: -91.63
Load_cell output val: 32.23
Load_cell output val: -2.26
Load_cell output val: 24.09
Load_cell output val: -11.12
Load_cell output val: -166.65
Load_cell output val: -139.86
Load_cell output val: -105.38
Load_cell output val: -70.99
Load_cell output val: 16.32
Load_cell output val: 51.60
Load_cell output val: 200.60
Load_cell output val: 174.26
Load_cell output val: 198.24
Load_cell output val: 161.26
Load_cell output val: 160.27
Load_cell output val: 130.84
Load_cell output val: 4.76
Load_cell output val: -30.51
Load_cell output val: -18.74
Load_cell output val: -51.96
Load_cell output val: -51.24
Load_cell output val: -41.28
Load_cell output val: -120.89
Load_cell output val: -235.34
Load_cell output val: -293.36
Load_cell output val: -317.12
Load_cell output val: -83.68
Load_cell output val: -95.45
Load_cell output val: 101.81
Load_cell output val: 135.04
Load_cell output val: 224.96
Load_cell output val: 191.02
Load_cell output val: 124.93
Load_cell output val: -2.75
Load_cell output val: 5.45
Load_cell output val: 116.10
Load_cell output val: 150.04
Load_cell output val: -5.34
Load_cell output val: 70.32
Load_cell output val: 221.02
Load_cell output val: 299.77
Load_cell output val: 264.59
Load_cell output val: 153.95
Load_cell output val: 190.60
Load_cell output val: 200.02
Load_cell output val: 189.87
Load_cell output val: 39.18
Load_cell output val: -30.69
Load_cell output val: 141.73
Load_cell output val: 131.84
Load_cell output val: 131.83
Load_cell output val: 119.06
Load_cell output val: 108.98
Load_cell output val: 119.12
Load_cell output val: 74.93
Load_cell output val: -6.35
Load_cell output val: -149.44
Load_cell output val: -122.53
Load_cell output val: 8.26
Load_cell output val: 42.65
Load_cell output val: 18.78
Load_cell output val: 48.58
Load_cell output val: 154.03
Load_cell output val: 226.67
Load_cell output val: 284.01
Load_cell output val: 113.74
Load_cell output val: 86.84
Load_cell output val: -28.41
Load_cell output val: -55.38
Load_cell output val: -89.68
Load_cell output val: -101.36
Load_cell output val: -119.49
Load_cell output val: -46.85
Load_cell output val: 37.65
Load_cell output val: -19.29
Load_cell output val: -91.93
Load_cell output val: -126.05
Load_cell output val: -83.47
Load_cell output val: -40.86
Load_cell output val: -75.35
Load_cell output val: -18.41
Load_cell output val: -51.82
Load_cell output val: -51.79
Load_cell output val: -17.49
Load_cell output val: -17.33
Load_cell output val: -50.55
Load_cell output val: -135.04
Load_cell output val: -7.36
Load_cell output val: -100.56
Load_cell output val: -100.92
Load_cell output val: 88.21
Load_cell output val: 121.62
Load_cell output val: 121.59
Load_cell output val: 306.20
Load_cell output val: 296.13
Load_cell output val: 168.45
Load_cell output val: 203.22
Load_cell output val: 193.33
Load_cell output val: 65.64
Load_cell output val: 38.67
Load_cell output val: 120.44
Load_cell output val: 86.50
Load_cell output val: 34.11
Load_cell output val: 44.19
Load_cell output val: 50.69
Load_cell output val: 16.38
Load_cell output val: 15.55
Load_cell output val: 25.44
Load_cell output val: 142.38
Load_cell output val: 60.61
Load_cell output val: 148.36
Load_cell output val: -33.27
Load_cell output val: 35.08
Load_cell output val: -113.99
Load_cell output val: -184.36
Load_cell output val: -122.18
Load_cell output val: -175.64
Load_cell output val: -26.57
Load_cell output val: -10.10
Load_cell output val: -182.18
Load_cell output val: -86.46
Load_cell output val: 27.99
Load_cell output val: 69.07
Load_cell output val: 156.93
Load_cell output val: 75.70
Load_cell output val: 48.73
Load_cell output val: 129.96
Load_cell output val: 95.25
Load_cell output val: 21.95
Load_cell output val: 212.36
Load_cell output val: 212.29
Load_cell output val: 195.15
Load_cell output val: 97.76
Load_cell output val: 179.71
Load_cell output val: 138.55
Load_cell output val: 97.24
Load_cell output val: 97.33
Load_cell output val: 155.41
Load_cell output val: 188.81
Load_cell output val: 164.94
Load_cell output val: 130.64
Load_cell output val: 96.70
Load_cell output val: 14.75
Load_cell output val: 14.70
Load_cell output val: 49.26
Load_cell output val: 49.10
Load_cell output val: 101.32
Load_cell output val: 135.62
Load_cell output val: 160.03
Load_cell output val: 159.42
Load_cell output val: 100.71
Load_cell output val: 56.39
Load_cell output val: 49.79
Load_cell output val: 250.98
Load_cell output val: 215.53
Load_cell output val: 16.56
Load_cell output val: 51.77
Load_cell output val: -75.54
Load_cell output val: -108.76
Load_cell output val: -129.90
Load_cell output val: -59.15
Load_cell output val: 35.98
Load_cell output val: 57.37
Load_cell output val: 76.49
Load_cell output val: 53.11
Load_cell output val: 109.71
Load_cell output val: -73.17
Load_cell output val: -142.48
Load_cell output val: -118.68
Load_cell output val: -137.80
Load_cell output val: 8.08
Load_cell output val: 8.20
Load_cell output val: 276.97
Load_cell output val: 258.93
Load_cell output val: 282.73
Load_cell output val: 174.43
Load_cell output val: 164.97
Load_cell output val: 164.85
Load_cell output val: 38.18
Load_cell output val: 224.00
Load_cell output val: 234.25
Load_cell output val: 190.42
Load_cell output val: 199.88
Load_cell output val: 133.88
Load_cell output val: 75.41
Load_cell output val: 51.57
Load_cell output val: -171.43
Load_cell output val: -195.07
Load_cell output val: -135.42
Load_cell output val: -154.43
Load_cell output val: -58.78
Load_cell output val: -58.01
Load_cell output val: -68.46
Load_cell output val: -2.46
Load_cell output val: -2.69
Load_cell output val: -15.20
Load_cell output val: -105.39
Load_cell output val: -13.36
Load_cell output val: -40.34
Load_cell output val: -40.31
Load_cell output val: -73.71
Load_cell output val: -74.49
Load_cell output val: -73.41
Load_cell output val: -97.25
Load_cell output val: 4.40
Load_cell output val: -24.42
Load_cell output val: -41.57
Load_cell output val: -8.20
Load_cell output val: 130.54
Load_cell output val: 60.67
Load_cell output val: 95.85
Load_cell output val: 95.88
Load_cell output val: 95.76
Load_cell output val: 188.97
Load_cell output val: 107.37
Load_cell output val: 71.74
Load_cell output val: 153.01
Load_cell output val: 83.32
Load_cell output val: 83.30
Load_cell output val: 146.48
Load_cell output val: -95.50
Load_cell output val: 53.57
Load_cell output val: 135.16
Load_cell output val: 101.40
Load_cell output val: 20.12
Load_cell output val: 61.93
Load_cell output val: -80.56
Load_cell output val: -80.63
Load_cell output val: -13.15
Load_cell output val: -29.59
Load_cell output val: -53.45
Load_cell output val: -125.05
Load_cell output val: -125.84
Load_cell output val: -36.71
Load_cell output val: -18.66
Load_cell output val: 16.78
Load_cell output val: 50.36
Load_cell output val: 26.63
Load_cell output val: 61.77
Load_cell output val: 50.21
Load_cell output val: 107.00
Load_cell output val: 202.45
Load_cell output val: 169.88
Load_cell output val: 169.10
Load_cell output val: 157.65
Load_cell output val: 102.38
Load_cell output val: 68.84
Load_cell output val: 33.70
Load_cell output val: 51.78
Load_cell output val: -43.67
Load_cell output val: -91.20
Load_cell output val: -46.11
Load_cell output val: -12.71
Load_cell output val: -78.17
Load_cell output val: -20.74
Load_cell output val: -81.24
Load_cell output val: -115.37
Load_cell output val: -151.86
Load_cell output val: -52.45
Load_cell output val: -75.53
Load_cell output val: -86.06
Load_cell output val: -43.52
Load_cell output val: -54.13
Load_cell output val: -20.23
Load_cell output val: -20.24
Load_cell output val: -85.69
Load_cell output val: -109.56
Load_cell output val: -75.96
Load_cell output val: -155.75
Load_cell output val: -121.38
Load_cell output val: 71.77
Load_cell output val: 170.42
Load_cell output val: 333.32
Load_cell output val: 390.02
Load_cell output val: 413.10
Load_cell output val: 148.20
Load_cell output val: 149.10
Load_cell output val: 50.45
Load_cell output val: 18.75
Load_cell output val: 214.41
Load_cell output val: 190.54
Load_cell output val: 190.56
Load_cell output val: 189.73
Load_cell output val: 221.86
Load_cell output val: 84.59
Load_cell output val: 15.58
Load_cell output val: 76.74
Load_cell output val: 53.12
Load_cell output val: 133.95
Load_cell output val: 8.58
Load_cell output val: -5.58
Load_cell output val: 6.10
Load_cell output val: 45.36
Load_cell output val: 71.86
Load_cell output val: 199.50
Load_cell output val: 172.64
Load_cell output val: 172.39
Load_cell output val: 138.81
Load_cell output val: 138.76
Load_cell output val: 11.12
Load_cell output val: 137.50
Load_cell output val: 116.00
Load_cell output val: 116.25
Load_cell output val: 89.75
Load_cell output val: 15.85
Load_cell output val: 123.63
Load_cell output val: 42.35
Load_cell output val: -124.77
Load_cell output val: -120.80
Load_cell output val: -144.80
Load_cell output val: -109.26
Load_cell output val: -109.91
Load_cell output val: -116.64
Load_cell output val: -119.04
Load_cell output val: 89.68
Load_cell output val: 146.27
Load_cell output val: 171.17
Load_cell output val: 296.17
Load_cell output val: 195.17
Load_cell output val: 70.61
Load_cell output val: 46.51
Load_cell output val: -13.14
Load_cell output val: -92.49
Load_cell output val: -56.25
Load_cell output val: -81.15
Load_cell output val: -36.40
Load_cell output val: -116.60
Load_cell output val: -51.14
Load_cell output val: -108.66
Load_cell output val: -66.26
Load_cell output val: -224.01
Load_cell output val: -78.43
Load_cell output val: -44.05
Load_cell output val: -54.67
Load_cell output val: -77.70
Load_cell output val: -43.47
Load_cell output val: -53.54
Load_cell output val: 3.98
Load_cell output val: 86.34
Load_cell output val: 50.99
Load_cell output val: 134.29
Load_cell output val: 110.42
Load_cell output val: 76.27
Load_cell output val: 15.21
Load_cell output val: 2.67
Load_cell output val: 14.98
Load_cell output val: 97.13
Load_cell output val: 13.04
Load_cell output val: 67.11
Load_cell output val: 149.07
Load_cell output val: 183.21
Load_cell output val: 148.73
Load_cell output val: 334.27
Load_cell output val: 294.24
Load_cell output val: 260.12
Load_cell output val: 247.81
Load_cell output val: 96.75
Load_cell output val: 56.34
Load_cell output val: -25.61
Load_cell output val: -60.09
Load_cell output val: -21.61
Load_cell output val: -96.47
Load_cell output val: -63.25
Load_cell output val: -97.57
Load_cell output val: -63.45
Load_cell output val: -97.03
Load_cell output val: -103.56
Load_cell output val: -107.56
Load_cell output val: -252.29
Load_cell output val: -227.92
Load_cell output val: -79.19
Load_cell output val: -55.44
Load_cell output val: -25.70
Load_cell output val: 9.44
Load_cell output val: -139.30
Load_cell output val: -105.71
Load_cell output val: 43.02
Load_cell output val: 17.57
Load_cell output val: 81.62
Load_cell output val: 134.18
Load_cell output val: 157.23
Load_cell output val: 181.10
Load_cell output val: 214.51
Load_cell output val: 116.37
Load_cell output val: 44.61
Load_cell output val: -13.03
Load_cell output val: 4.08
Load_cell output val: 102.86
Load_cell output val: 131.05
Load_cell output val: 107.18
Load_cell output val: 130.32
Load_cell output val: 106.46
Load_cell output val: 131.40
Load_cell output val: 68.26
Load_cell output val: 45.18
Load_cell output val: 16.27
Load_cell output val: 77.28
Load_cell output val: 53.41
Load_cell output val: 3.67
Load_cell output val: 38.15
Load_cell output val: 26.39
Load_cell output val: 2.52
Load_cell output val: 90.02
Load_cell output val: 71.82
Load_cell output val: 147.44
Load_cell output val: 201.59
Load_cell output val: 167.28
Load_cell output val: 223.54
Load_cell output val: 182.91
Load_cell output val: 100.53
Load_cell output val: 101.16
Load_cell output val: 88.49
Load_cell output val: 101.04
Load_cell output val: 188.84
Load_cell output val: 108.17
Load_cell output val: 90.65
Load_cell output val: 184.45
Load_cell output val: 218.13
Load_cell output val: 218.24
Load_cell output val: 112.16
Load_cell output val: -11.21
Load_cell output val: -63.81
Load_cell output val: -140.85
Loa
then I used the Example Read_1x_load_cell with the follows output:
when place the 185 gram on the load cell:
Starting...
Startup is complete
Load_cell output val: 0.00
Load_cell output val: -0.00
Load_cell output val: -0.01
Load_cell output val: -0.02
Load_cell output val: 0.01
Tare complete
Load_cell output val: 0.02
Load_cell output val: -0.03
Lo
it is seems that I do not have the correct value because the value that comes out is different from 185 gm or is nan or inf.
I don't know what I'm doing wrong, I'm using an Arduino UNO and this load cell with its module https://www.amazon.com/gp/product/B079FQNJJH/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I use the pin of the codes...
Please post that code here.
In many (maybe all?) green HX711, E- is not grounded, as it should be. May not be the source of your problem, but if yours is un-grounded, you should fix it anyway, by connecting E- to ground.
