I´m new here and tried to read all WS2812B strip issues, but can´t find my answer.
My problem/question is how to connect two parallel led strips WS2812B to one power source?
While both are working fine separetely (show below), when I just slighly touch the GND from second one to connect GND, the first strip start to act weird, power off or changing colors or each time different strange behavior
@stevemj is correct
However the 5V 3A power bank will not supply enough curent for 2 strips.
For reliable operation, your supply for the LEDs should be capable of supplying 8A or more
Yes your strips are 61 LEDs long.
At 60mA maximum per LED that gives you a maximum potential current of 3.66 Amps. Your code is probably not using that much but that is the maximum.
With two strips your maximum current is 7.32 Amps.
That latest diagram is hard to follow but it looks like the ground of the external supply is not connected to the ground of the Arduino.
Stop trying to get 3.66 Amps from your Arduino power supply and power them both from your external power supply, even though that does not supply enough current. And don't forget to connect the ground of your supply to the ground of the Arduino.
Thank you for suggestion, much appreciated. I tried with Laboratory Power supply like below. When powered on (working with one single strip with all 61 on) it has 1.152A consumption.
oh, yes than it make sense I use only blue colour.
Top answer your question, yes the GND are connected to LAB supply, LED strips and Arduino, and same for LAB supply +5V to Led Strips, and Arduino Uno R3 pin 5V (next to the two GND).
But still the same not lighting up at all. Thanks for help.
You could possibly have burned out the first LED of a strip when you fed a signal into it without having any power applied. You also have not got a series resistor in series with the data signals that would have helped protect that first LED.
Each LED in a strip regenerates the signal and passes it on to the next LED. Therefore if any LED is burned out then all the LEDs further into the strip will not work.
From the UNO documentation:
5V.This pin outputs a regulated 5V from the regulator on the board. The board can be supplied with power either from the DC power jack (7 - 12V), the USB connector (5V), or the VIN pin of the board (7-12V). Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and can damage your board. We don't advise it.
I tried reorganizing the connection and wiring like this, but I still see the same behavior as with the power bank. While a single strip works fine both are in conflict. I am attaching photos to explain more details.
Thanks for help, suggestion.
Laco
Sorry but this is not clear. The first image looks like it is a video but is actually only a still image.
The last image shows a nano with the only two connections going somewhere, I assume this to be the data lines to the LED strips.
There is no indication of a common ground between the nano and any external supply because nothing else is soldered to the nano. There is no image of the external power supply and how this is connected to the strip.
To post a video simply copy and paste the link to the video on what ever player you are choosing.
