Hi
I have a PCB ready to produce, this PCB uses a HX711.
JLCPCB dont have this chip for soldering.
LCSC on the other hand has this chip.
Do any of you know a PCB produser using components from LCSC?
M
Hi
M
JLCPCB uses components from LCSC
Getting some electronic parts has been an issue , that might be why they don’t have it ??
Farnell/RS/Mouser don’t sell it , only the breakout boards .
Reality check time.
The ONLY way a board house can afford to produce a single board or a few boards for you is because ALL the components have been paid for by a customer with hundreds of boards. You are getting excess, left-over components put on your board. If a board house does not have one of your required components, they are not going to order just one for your board. Send your order to different places until you find one that will do your build. Or have one built without your required chip and you add it later.
Good luck with your project.
That is not LCSC's website!
They will stock custom bits , but you have to buy in quantity and pay for storage .
You could get in touch with them ?
Anyhow did a search and JLCPCB do carry them
Contract manufacturer's usually offer two services -
"Turnkey" means the manufacturer takes care of everything including buying the parts. This is usually done for higher quantities and long-term contracts.
"Consignment" means the client supplies the parts, including the bare boards. This usually works-out better for smaller quantities because the client can take the inventory risk and buy in economical quantities.
With turnkey, if you don't have a long-term contract the manufacturer doesn't know if or when you're going to place another order and they don't want to get stuck with inventory.
Hi, I did not search, my PCB designer told me that they dont have it.... so no, i did not search, i searched everywhere else ![]()
Thanks, I will contact JLCPCB when order my 10 pcs PCB.
M
There a PCB design app that works with JLC , so as you design you can pick from their stock and reserve for your order .
As I said they have the hx711 in stock
