Hello friends.
How to access a local host globally from anywhere in the world.
For example, live streaming of esp32 cam movies from all over the world.
Thank you for your help ![]()
How much do you know about routers and firewalls ?
And how much do you know about satellite internet links ?
And have you looked at the ESP32CAM demo code that does streaming to see how that part is done?
I do not know much. I was able to set up a regional web server.
And a global web server with (NGROk).
I want to do this without (ngrok). Because to use (ngrok), a Windows or Linux system must be connected to the board.
Yes. I know how to set up a local server. I just want to present my local server on the Internet. To be able to access it from anywhere
satellite Internet ??Can you explain more?
I have several ESP32CAM's that send their images, FTP, to a local RPI (Raspberry Pi). The RPi is running a program in Python to send the images to my website.
Here is the ESP32CAM code.
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include "certs.h"
#include "esp_camera.h"
#include "soc/soc.h" // Disable brownout problems
#include "soc/rtc_cntl_reg.h" // Disable brownout problems
#include "driver/rtc_io.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include "ESP32_FTPClient.h"
#include <PubSubClient.h>
#include <ESP32Time.h>
WiFiClient wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32_FTPClient ftp (ftp_server, ftp_user, ftp_pass, 5000, 2);
ESP32Time rtc;
//#define evtDoMQTTParse ( 1 << 0 ) // declare an event
//EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 300;
struct stu_message
char payload [payloadSize] = {'\0'};
String topic ;
} x_message;
int mqttOK = 0;
bool TimeSet = false;
bool FlashMode = false;
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
log_i("Connected to WiFi access point");
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
// clear locations
memset( x_message.payload, '\0', payloadSize );
x_message.topic = ""; //clear string buffer
x_message.topic.concat( topic );
int i = 0;
for ( i; i < length; i++)
x_message.payload[i] = ((char)payload[i]);
x_message.payload[i] = '\0';
xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
pinMode( GPIO_NUM_4, OUTPUT);
digitalWrite( GPIO_NUM_4, LOW);
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
//eg = xEventGroupCreate(); // get an event group handle
x_message.topic.reserve( payloadSize );
xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
sema_mqttOK = xSemaphoreCreateBinary();
xSemaphoreGive( sema_mqttOK );
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 7000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 9000, NULL, 4, NULL, 1 ); // assign all to core 1, WiFi in use.
xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
if ( configInitCamera() )
log_i(" start camera task" );
xTaskCreatePinnedToCore( capturePhoto_sendFTP, "capturePhoto_sendFTP", 60000, NULL, 6, NULL, 1 );
log_i( " camera failed to initilize, rebooting in 5." );
vTaskDelay( 2000 );
ESP.restart();
} // void setup()
void capturePhoto_sendFTP( void *pvParameters )
TickType_t xLastWakeTime = xTaskGetTickCount();
const TickType_t xFrequency = 1000 * 5; //delay for mS
//!!!!!Must wait for MQTT connection and proper setup of the sema_MQTT_KeepAlive!!!!
while ( !MQTTclient.connected() )
vTaskDelay( 500 );
for (;;)
log_i( "tick");
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
camera_fb_t * fb = NULL; // pointer
fb = esp_camera_fb_get();
if (!fb)
log_i( "Camera capture failed" );
esp_camera_fb_return(fb);
} else
ftp.OpenConnection(); // try open FTP
if ( ftp.isConnected() )
//try send file ftp
ftp.ChangeWorkDir( ftp_path );
ftp.DeleteFile( ftp_file_name );
ftp.InitFile( ftp_file_type ); //"Type I"
ftp.NewFile( ftp_file_name );
ftp.WriteData( (unsigned char *)fb->buf, fb->len );
ftp.CloseFile();
ftp.CloseConnection();
esp_camera_fb_return(fb); //return the frame buffer back to the driver for reuse
xSemaphoreGive( sema_MQTT_KeepAlive );
vTaskDelayUntil( &xLastWakeTime, xFrequency );
vTaskDelete( NULL );
} //void capturePhoto_sendFTP( void *pvParameters )
void configureCameraSettings_grpE( int _lenC, int _Hmirror, int _Vflip, int _dcw, int _colorbar )
sensor_t * s = esp_camera_sensor_get();
s->set_lenc(s, _lenC); // 0 = disable , 1 = enable
s->set_hmirror(s, _Hmirror); // 0 = disable , 1 = enable
s->set_vflip(s, _Vflip); // 0 = disable , 1 = enable
s->set_dcw(s, _dcw); // 0 = disable , 1 = enable
////s->set_colorbar(s, _colorbar); // 0 = disable , 1 = enable
void configureCameraSettings_grpD( int _gc, int _agc, int _celing, int _bpc, int _wpc, int _gma )
s->set_gain_ctrl(s, _gc); // 0 = disable , 1 = enable
s->set_agc_gain(s, _agc); // 0 to 30
s->set_gainceiling(s, (gainceiling_t)_celing); // 0 to 6
s->set_bpc(s, _bpc); // 0 = disable , 1 = enable
s->set_wpc(s, _wpc); // 0 = disable , 1 = enable
s->set_raw_gma(s, _gma); // 0 = disable , 1 = enable
void configureCameraSettings_grpC( int _exctl, int _aec2, int _ae, int _aec )
s->set_exposure_ctrl(s, _exctl); // 0 = disable , 1 = enable
s->set_aec2(s, _aec2); // 0 = disable , 1 = enable
s->set_ae_level(s, _ae); // -2 to 2
////s->set_aec_value(s, _aec); // 0 to 1200 CAUSES BLACK IMAGE????
void configureCameraSettings_grpB( int se, int wb, int awb, int wbmode )
s->set_special_effect(s, se); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
s->set_whitebal(s, wb); // 0 = disable , 1 = enable
s->set_awb_gain(s, awb); // 0 = disable , 1 = enable
s->set_wb_mode(s, wbmode); // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
void configureCameraSettings_grpA(int brightness, int contrast, int saturation )
if ( ((brightness > -3) && (brightness < 3)) && ((contrast > -3) && (contrast < 3)) && ((saturation > -3) && (saturation < 3)) )
s->set_brightness( s, brightness ); // -2 to 2
s->set_contrast( s, contrast ); // -2 to 2
s->set_saturation( s, saturation ); // -2 to 2
} //void configureCameraSettings()
sensor_t * s = esp_camera_sensor_get(); //see certs.h for more info
s->set_brightness(s, -1); // -2 to 2 **************************
s->set_contrast(s, 0); // -2 to 2
s->set_saturation(s, 0); // -2 to 2
s->set_special_effect(s, 0); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
s->set_whitebal(s, 1); // 0 = disable , 1 = enable
s->set_awb_gain(s, 1); // 0 = disable , 1 = enable
s->set_wb_mode(s, 0); // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
s->set_exposure_ctrl(s, 1); // 0 = disable , 1 = enable
s->set_aec2(s, 0); // 0 = disable , 1 = enable
s->set_ae_level(s, 0); // -2 to 2
s->set_aec_value(s, 300); // 0 to 1200
s->set_gain_ctrl(s, 1); // 0 = disable , 1 = enable
s->set_agc_gain(s, 0); // 0 to 30
s->set_gainceiling(s, (gainceiling_t)0); // 0 to 6
s->set_bpc(s, 0); // 0 = disable , 1 = enable
s->set_wpc(s, 1); // 0 = disable , 1 = enable
s->set_raw_gma(s, 1); // 0 = disable , 1 = enable
s->set_lenc(s, 1); // 0 = disable , 1 = enable
s->set_hmirror(s, 0); // 0 = disable , 1 = enable
s->set_vflip(s, 0); // 0 = disable , 1 = enable
s->set_dcw(s, 1); // 0 = disable , 1 = enable
s->set_colorbar(s, 0); // 0 = disable , 1 = enable
bool configInitCamera()
camera_config_t config = {}; // Stores the camera configuration parameters
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = GPIO_NUM_5; //Y2
config.pin_d1 = GPIO_NUM_18; //Y3
config.pin_d2 = GPIO_NUM_19; //Y4
config.pin_d3 = GPIO_NUM_21; //Y5
config.pin_d4 = GPIO_NUM_36; //Y6
config.pin_d5 = GPIO_NUM_39; //Y7
config.pin_d6 = GPIO_NUM_34; //Y8
config.pin_d7 = GPIO_NUM_35; // Y9
config.pin_xclk = GPIO_NUM_0; //XCLK
config.pin_pclk = GPIO_NUM_22; //PCLK
config.pin_vsync = GPIO_NUM_25; //VSSYNC
config.pin_href = GPIO_NUM_23; // HREF
config.pin_sscb_sda = GPIO_NUM_26; //SIOD
config.pin_sscb_scl = GPIO_NUM_27; //SIOC
config.pin_pwdn = GPIO_NUM_32; //PWDN
config.pin_reset = -1; //RESET
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG; ////YUV422,GRAYSCALE,RGB565,JPEG
config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
FRAMESIZE_UXGA (1600 x 1200)
FRAMESIZE_QVGA (320 x 240)
FRAMESIZE_CIF (352 x 288)
FRAMESIZE_VGA (640 x 480)
FRAMESIZE_SVGA (800 x 600)
FRAMESIZE_XGA (1024 x 768)
FRAMESIZE_SXGA (1280 x 1024)
config.jpeg_quality = 10; //0-63 lower number means higher quality
* The image quality (jpeg_quality) can be a number between 0 and 63.
* A lower number means a higher quality.
* However, very low numbers for image quality,
* specially at higher resolution can make the ESP32-CAM to crash or it may not be able to take the photos properly.
* So, if you notice that the images taken with the ESP32-CAM are cut in half, or with strange colors,
* that’s probably a sign that you need to lower the quality (select a higher number).
config.fb_count = 2;
// Initialize the Camera
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
log_i("Camera init failed with error %d", err );
return false;
configureCameraSettings();
return true;
} //void configInitCamera()
void connectToWiFi()
int TryCount = 0;
while ( WiFi.status() != WL_CONNECTED )
TryCount++;
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
vTaskDelay( 2500 );
if ( TryCount == 10 )
ESP.restart();
WiFi.onEvent( WiFiEvent );
void MQTTkeepalive( void *pvParameters )
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
const TickType_t xFrequency = 250; //delay for ms
for (;;)
//check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // !!!!!whiles MQTTlient.loop() is running no other mqtt operations should be in process!!!!!
MQTTclient.loop();
else {
if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
vTaskDelete ( NULL );
void connectToMQTT()
byte mac[5]; // create client ID from mac address
WiFi.macAddress(mac); // get mac address
String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
vTaskDelay( 250 );
MQTTclient.setCallback( mqttCallback );
MQTTclient.subscribe( topicOK );
MQTTclient.subscribe( topicGrpA );
MQTTclient.subscribe( topicGrpB );
MQTTclient.subscribe( topicGrpC );
MQTTclient.subscribe( topicGrpD );
MQTTclient.subscribe( topicGrpE );
MQTTclient.subscribe( topicFlash );
} //void connectToMQTT()
void fmqttWatchDog( void * paramater )
int UpdateImeTrigger = 86400; //seconds in a day
int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
int maxNonMQTTresponse = 3;
const TickType_t xFrequency = 60000; //delay for mS
for (;;)
xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
mqttOK++;
if ( mqttOK >= maxNonMQTTresponse )
log_i( "mqtt watchdog rest" );
vTaskDelay( 200 );
ESP.restart();
UpdateTimeInterval++; // trigger new time get
if ( UpdateTimeInterval >= UpdateImeTrigger )
TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fparseMQTT( void *pvParameters )
struct stu_message px_message;
for (;;)
if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
mqttOK = 0;
if ( !TimeSet)
if ( String(px_message.topic) == topicOK )
String temp = "";
temp = px_message.payload[0];
temp += px_message.payload[1];
temp += px_message.payload[2];
temp += px_message.payload[3];
int year = temp.toInt();
temp = "";
temp = px_message.payload[5];
temp += px_message.payload[6];
int month = temp.toInt();
temp = "";
temp = px_message.payload[8];
temp += px_message.payload[9];
int day = temp.toInt();
temp = "";
temp = px_message.payload[11];
temp += px_message.payload[12];
int hour = temp.toInt();
temp = "";
temp = px_message.payload[14];
temp += px_message.payload[15];
int min = temp.toInt();
rtc.setTime( 0, min, hour, day, month, year );
log_i( "%s rtc %s ", px_message.payload, rtc.getTime() );
TimeSet = true;
if ( String(px_message.topic) == topicGrpA )
//finding first letter
String sTmp = String( px_message.payload );
int commaIndex = sTmp.indexOf(',');
if ( sTmp.substring(0, commaIndex) == "a" );
int brt = (sTmp.substring(0, commaIndex)).toInt();
sTmp.remove( 0, (commaIndex + 1) );
int ctrast = (sTmp.substring(0, commaIndex)).toInt();
sTmp.remove( 0, (commaIndex + 1) ); // chop off begining of message
int sat = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpA( brt, ctrast, sat );
if ( String(px_message.topic) == topicGrpB )
if ( sTmp.substring(0, commaIndex) == "b" );
int se = (sTmp.substring(0, commaIndex)).toInt();
int wbb = (sTmp.substring(0, commaIndex)).toInt();
int wba = (sTmp.substring(0, commaIndex)).toInt();
int wbm = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpB( se, wbb, wba, wbm );
if ( String(px_message.topic) == topicGrpC )
if ( sTmp.substring(0, commaIndex) == "c" );
int ex = (sTmp.substring(0, commaIndex)).toInt();
int aec2 = (sTmp.substring(0, commaIndex)).toInt();
int ae = (sTmp.substring(0, commaIndex)).toInt();
int aec = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpC( ex, aec2, ae, aec );
if ( String(px_message.topic) == topicGrpD )
if ( sTmp.substring(0, commaIndex) == "d" );
int gc = (sTmp.substring(0, commaIndex)).toInt();
int agc = (sTmp.substring(0, commaIndex)).toInt();
int celing = (sTmp.substring(0, commaIndex)).toInt();
int bpc = (sTmp.substring(0, commaIndex)).toInt();
int wpc = (sTmp.substring(0, commaIndex)).toInt();
int gma = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpD( gc, agc, celing, bpc, wpc, gma );
if ( String(px_message.topic) == topicGrpE )
if ( sTmp.substring(0, commaIndex) == "e" );
int lenC = (sTmp.substring(0, commaIndex)).toInt();
int Hmirror = (sTmp.substring(0, commaIndex)).toInt();
int Vflip = (sTmp.substring(0, commaIndex)).toInt();
int dcw = (sTmp.substring(0, commaIndex)).toInt();
int colorbar = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpE( lenC, Hmirror, Vflip, dcw, colorbar );
if ( String(px_message.topic) == topicFlash )
FlashMode = bool(px_message.payload);
} //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
} //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
To FTP an image to a location.
Thank you so much. ![]()
Sorry, I do not have access to (Raspberry Pi). Is it possible for me to send information to a host? And from there I do this operation. To be able to access my own board from anywhere
You said from 'all over the World' so for the many many locations where there is no handy Internet connection you would need to use some form of Satellite link.
No. Satellite internet is very expensive. ![]()
I just want to transfer my board data to a host and from there I can access the internet wherever I can. Have access to my own board.
ESP32 CAM with Arduino IDE | Tutorial - [Part.2] World Wide Access to ESP32CAM (feat. GCP)
In this video, he taught me how to do this, but I was in a country where I could not create a Google Cloud account due to sanctions.
Can someone help me or introduce another method?
Set up Port Forwarding on your Internet router to allow global access to your local server. See: https://portforward.com/
To make your network easier to access, you may want to set up a Dynamic DNS name to map to your home IP address: https://www.makeuseof.com/tag/5-best-dynamic-dns-providers-can-lookup-free-today/
Thank you so much. I'm checking now
The point is, a Raspberry Pi - running Linux of course - would do this with commensurate ease. ![]()
Windoze? Are you absolutely kidding? ![]()
Hi, I want to do this without using the operating system, that is, I put the information directly on the Internet, and I can access it from anywhere, Raspberry Pi board is very expensive in our area, about three times the original price. That, unfortunately🤐
Can't deny that, but it will work. ![]()
Pi Zero?
This can be done with the Blynk Dashboard IoT. But it costs money. I'm looking for a free way to stream live
bir yolunu bulabildinizmi ???
As @johnwasser has said. You need to either use Dynamic DNS, or have a static IP address assigned by you ISP. That will enable the world to connect to your router... from there you just need to port forward the required ports to your hosted local web server.
This is not really specific to any ESP hosted content, but any local application that you want to expose on the Internet.
