Please help me i die in all this errors😥
in this code are so much errorrs its a code from a website for the smart home from keyestudio and i don't know how to fix them all.
Code:
#include <Servo.h>
#include <Wire.h>
//Set the communication address of I2C to 0x27, display 16 characters every line, two lines in total
LiquidCrystal_I2C mylcd(0x27, 16, 2);
//set ports of two servos to digital 9 and 10
Servo servo_10;
Servo servo_9;
volatile int btn1_num;//set variable btn1_num
volatile int btn2_num;//set variable btn2_num
volatile int button1;//set variable button1
volatile int button2;//set variable button2
String fans_char;//string type variable fans_char
volatile int fans_val;//set variable fans_char
volatile int flag;//set variable flag
volatile int flag2;//set variable flag2
volatile int flag3;//set variable flag3
volatile int gas;//set variable gas
volatile int infrar;//set variable infrar
String led2;//string type variable led2
volatile int light;//set variable light
String pass;//string type variable pass
String passwd;//string type variable passwd
String servo1;//string type variable servo1
volatile int servo1_angle;//set variable light
String servo2;//string type variable servo2
volatile int servo2_angle;//set variable servo2_angle
volatile int soil;//set variable soil
volatile int val;//set variable val
volatile int value_led2;//set variable value_led2
volatile int water;//set variable water
int length;
int tonepin = 3; //set the signal end of passive buzzer to digital 3
//define name of every sound frequency
#define D0 -1
#define D1 262
#define D2 293
#define D3 329
#define D4 349
#define D5 392
#define D6 440
#define D7 494
#define M1 523
#define M2 586
#define M3 658
#define M4 697
#define M5 783
#define M6 879
#define M7 987
#define H1 1045
#define H2 1171
#define H3 1316
#define H4 1393
#define H5 1563
#define H6 1755
#define H7 1971
#define WHOLE 1
#define HALF 0.5
#define QUARTER 0.25
#define EIGHTH 0.25
#define SIXTEENTH 0.625
//set sound play frequency
int tune[] =
  M3, M3, M4, M5,
  M5, M4, M3, M2,
  M1, M1, M2, M3,
  M3, M2, M2,
  M3, M3, M4, M5,
  M5, M4, M3, M2,
  M1, M1, M2, M3,
  M2, M1, M1,
  M2, M2, M3, M1,
  M2, M3, M4, M3, M1,
  M2, M3, M4, M3, M2,
  M1, M2, D5, D0,
  M3, M3, M4, M5,
  M5, M4, M3, M4, M2,
  M1, M1, M2, M3,
  M2, M1, M1
//set music beat
float durt[] =
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1 + 0.5, 0.5, 1 + 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 0.5, 0.5, 1, 1,
  1, 0.5, 0.5, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 0.5, 0.5,
  1, 1, 1, 1,
  Serial.begin(9600);//set baud rate to 9600
  mylcd.init();
  mylcd.backlight();//initialize LCD
  //LCD shows "passcord:" at first row and column
  mylcd.setCursor(1 - 1, 1 - 1);
  mylcd.print("passcord:");
  servo_9.attach(9);//make servo connect to digital 9
  servo_10.attach(10);//make servo connect to digital 10
  servo_9.write(0);//set servo connected digital 9 to 0°
  servo_10.write(0);//set servo connected digital 10 to 0°
  delay(300);
  pinMode(7, OUTPUT);//set digital 7 to output
  pinMode(6, OUTPUT);//set digital 6 to output
  digitalWrite(7, HIGH); //set digital 7 to high level
  digitalWrite(6, HIGH); //set digital 6 to high level
  pinMode(4, INPUT);//set digital 4 to input
  pinMode(8, INPUT);//set digital 8 to input
  pinMode(2, INPUT);//set digital 2 to input
  pinMode(3, OUTPUT);//set digital 3 to output
  pinMode(A0, INPUT);//set A0 to input
  pinMode(A1, INPUT);//set A1 to input
  pinMode(13, OUTPUT);//set digital 13 to input
  pinMode(A3, INPUT);//set A3 to input
  pinMode(A2, INPUT);//set A2 to input
  pinMode(12, OUTPUT);//set digital 12 to output
  pinMode(5, OUTPUT);//set digital 5 to output
  length = sizeof(tune) / sizeof(tune[0]); //set the value of length
  auto_sensor();
  if (Serial.available() > 0) //serial reads the characters
    val = Serial.read();//set val to character read by serial    Serial.println(val);//output val character in new lines
    pwm_control();
  switch (val) {
    case 'a'://if val is character 'a',program will circulate
      digitalWrite(13, HIGH); //set digital 13 to high level,LED 	lights up
      break;//exit loop
    case 'b'://if val is character 'b',program will circulate
      digitalWrite(13, LOW); //Set digital 13 to low level, LED is off
      break;//exit loop
    case 'c'://if val is character 'c',program will circulate
      digitalWrite(12, HIGH); //set digital 12 to high level,NO of relay is connected to COM
      break;//exit loop
    case 'd'://if val is character 'd',program will circulate
      digitalWrite(12, LOW); //set digital 12 to low level,NO of relay is disconnected to COM
      break;//exit loop
    case 'e'://if val is character 'e',program will circulate
      music1();//play birthday song
      break;//exit loop
    case 'f'://if val is character 'f',program will circulate
      music2();//play ode to joy song
      break;//exit loop
    case 'g'://if val is character 'g',program will circulate
      noTone(3);//set digital 3 to stop playing music
      break;//exit loop
    case 'h'://if val is character 'h',program will circulate
      Serial.println(light);//output the value of variable light in new lines
      delay(100);
      break;//exit loop
    case 'i'://if val is character 'i',program will circulate
      Serial.println(gas);//output the value of variable gas in new lines
      delay(100);
      break;//exit loop
    case 'j'://if val is character 'j',program will circulate
      Serial.println(soil);//output the value of variable soil in new lines
      delay(100);
      break;//exit loop
    case 'k'://if val is character 'k',program will circulate
      Serial.println(water);//output the value of variable water in new lines
      delay(100);
      break;//exit loop
    case 'l'://if val is character 'l',program will circulate
      servo_9.write(180);//set servo connected to digital 9 to 180°
      break;//exit loop
    case 'm'://if val is character 'm',program will circulate
      servo_9.write(0);;//set servo connected to digital 9 to 0°
      break;//exit loop
    case 'n'://if val is character 'n',program will circulate
      servo_10.write(180);//set servo connected to digital 10 to 180°
      break;//exit loop
    case 'o'://if val is character 'o',program will circulate
      servo_10.write(0);//set servo connected to digital 10 to 0°
      break;//exit loop
    case 'p'://if val is character 'p',program will circulate
      digitalWrite(5, HIGH); //set digital 5 to high level, LED is on
      break;//exit loop
    case 'q'://if val is character 'q',program will circulate
      digitalWrite(5, LOW); // set digital 5 to low level, LED is off
      break;//exit loop
    case 'r'://if val is character 'r',program will circulate
      digitalWrite(7, LOW);
      digitalWrite(6, HIGH); //fan rotates anticlockwise at the fastest speed
      break;//exit loop
    case 's'://if val is character 's',program will circulate
      digitalWrite(6, LOW); //fan stops rotating
      break;//exit loop
////////////////////////set birthday song//////////////////////////////////
void birthday()
  tone(3, 294); //digital 3 outputs 294HZ sound
  delay(250);//delay in 250ms
  tone(3, 440);
  delay(250);
  tone(3, 392);
  delay(250);
  tone(3, 532);
  delay(250);
  tone(3, 494);
  tone(3, 392);
  delay(250);
  tone(3, 440);
  delay(250);
  tone(3, 392);
  delay(250);
  tone(3, 587);
  delay(250);
  tone(3, 532);
  tone(3, 392);
  delay(250);
  tone(3, 784);
  delay(250);
  tone(3, 659);
  delay(250);
  tone(3, 532);
  delay(250);
  tone(3, 494);
  delay(250);
  tone(3, 440);
  delay(250);
  tone(3, 698);
  delay(375);
  tone(3, 659);
  delay(250);
  tone(3, 532);
  delay(250);
  tone(3, 587);
  delay(250);
  tone(3, 532);
//detect gas
void auto_sensor() {
  gas = analogRead(A0);//assign the analog value of A0 to gas
  if (gas > 700) {
//if variable gas>700
    flag = 1;//set variable flag to 1
    while (flag == 1)
      //if flag is 1, program will circulate
      Serial.println("danger");//output "danger" in new lines
      tone(3, 440);
      delay(125);
      delay(100);
      noTone(3);
      delay(100);
      tone(3, 440);
      delay(125);
      delay(100);
      noTone(3);
      delay(300);
      gas = analogRead(A0);//gas analog the value of A0 to gas
      if (gas < 100)  //if variable gas is less than 100
        flag = 0;//set variable flag to 0
        break;//exit loop exist to loop
  } else
    //otherwise
    noTone(3);// digital 3 stops playing music
  light = analogRead(A1);////Assign the analog value of A1 to light
  if (light < 300)//if variable light is less than 300
    infrar = digitalRead(2);//assign the value of digital 2 to infrar
    Serial.println(infrar);//output the value of variable infrar in new lines
    if (infrar == 1)
      // if variable infra is 1
      digitalWrite(13, HIGH); //set digital 13 to high level, LED is on
    } else//Otherwise
      digitalWrite(13, LOW); //set digital 13 to low level, LED is off
  water = analogRead(A3);//assign the analog value of A3 to variable water
  if (water > 800)
    // if variable water is larger than 800
    flag2 = 1;//if variable flag 2 to 1
    while (flag2 == 1)
      // if flag2 is 1, program will circulate
      Serial.println("rain");//output "rain" in new lines
      servo_10.write(180);// set the servo connected to digital 10 to 180°
      delay(300);//delay in 300ms
      delay(100);
      water = analogRead(A3);;//assign the analog value of A3 to variable water
      if (water < 30)// if variable water is less than 30
        flag2 = 0;// set flag2 to 0
        break;//exit loop
  } else//Otherwise
    if (val != 'u' && val != 'n')
      //if val is not equivalent 'u' either 'n'
      delay(10);
  soil = analogRead(A2);//assign the analog value of A2 to variable soil
  if (soil > 50)
    // if variable soil is greater than 50
    flag3 = 1;//set flag3 to 1
    while (flag3 == 1)
      //If set flag3 to 1, program will circulate
      Serial.println("hydropenia ");//output "hydropenia " in new lines
      tone(3, 440);
      delay(125);
      delay(100);
      noTone(3);
      delay(100);
      tone(3, 440);
      delay(125);
      delay(100);
      noTone(3);//digital 3 stops playing sound
      delay(300);
      soil = analogRead(A2);//Assign the analog value of A2 to variable soil
      if (soil < 10)//If variable soil<10
        flag3 = 0;//set flag3 to 0
        break;//exit loop
  } else//Otherwise
  door();//run subroutine
void door() {
  button1 = digitalRead(4);// assign the value of digital 4 to button1
  button2 = digitalRead(8);//assign the value of digital 8 to button2
  if (button1 == 0)//if variablebutton1 is 0
    delay(10);//delay in 10ms
    while (button1 == 0) //if variablebutton1 is 0,program will circulate
      btn1_num = btn1_num + 1;//variable btn1_num plus 1
      delay(100);// delay in 100ms
  if (btn1_num >= 1 && btn1_num < 5) //1≤if variablebtn1_num<5
    Serial.print(".");
    Serial.print("");
    passwd = String(passwd) + String(".");//set passwd
pass = String(pass) + String(".");//set pass
    //LCD shows pass at the first row and column
    mylcd.setCursor(1 - 1, 2 - 1);
    mylcd.print(pass);
  if (btn1_num >= 5)
    //if variablebtn1_num ≥5
    Serial.print("-");
    passwd = String(passwd) + String("-");//Set passwd
    pass = String(pass) + String("-");//set pass
    mylcd.print(pass);
  if (button2 == 0) //if variablebutton2 is 0
    delay(10);
    if (button2 == 0)//if variablebutton2 is 0
      if (passwd == ".--.-.")//if passwd is ".--.-."
        mylcd.clear();//clear LCD screen
        //LCD shows "open!" at first character on second row
        mylcd.print("open!");
        servo_9.write(100);//set servo connected to digital 9 to 100°
        delay(300);
        delay(5000);
        passwd = "";
        pass = "";
        //LCD shows "password:"at first character on first row
        mylcd.print("password:");
      } else //Otherwise
        //LCD shows "error!"at first character on first row
        mylcd.print("error!");
        passwd = "";
        pass = "";
        delay(2000);
        //LCD shows "again" at first character on first row
        mylcd.print("again");
  if (infrar == 0 && (val != 'l' && val != 't'))
    //if variable infrar is 0 and val is not 'l' either 't'
    servo_9.write(0);//set servo connected to digital 9 to 0°
    delay(50);
    delay(10);
    while (button2 == 0) //if variablebutton2 is 0,program will circulate
      btn2_num = btn2_num + 1;//variable btn2_num plus 1
      delay(100);
      if (btn2_num >= 15)//if variablebtn2_num ≥15
        tone(3, 532);
        delay(125);
        //LCD shows "password:" at the first character on first row
        //LCD shows "wait" at the first character on first row
        mylcd.print("wait");
      } else//Otherwise
        noTone(3);//digital 3 stops playing music
  btn1_num = 0;//set btn1_num to 0
  btn2_num = 0;//set btn2_num to 0
// Birthday song
void music1() {
  birthday();
//Ode to joy
void music2() {
  Ode_to_Joy();
void Ode_to_Joy()//play Ode to joy song
  for (int x = 0; x < length; x++)
    tone(tonepin, tune[x]);
    delay(300 * durt[x]);
//PWM control
void pwm_control() {
  switch (val)
    case 't'://if val is 't',program will circulate
      servo1 = Serial.readStringUntil('#');
      servo1_angle = String(servo1).toInt();
      servo_9.write(servo1_angle);//set the angle of servo connected to digital 9 to servo1_angle
      delay(300);
      break;//exit loop
    case 'u'://if val is 'u',program will circulate
      servo2 = Serial.readStringUntil('#');
      servo2_angle = String(servo2).toInt();
      servo_10.write(servo2_angle);//set the angle of servo connected to digital 10 to servo2_angle
      delay(300);
      break;//exit loop
    case 'v'://if val is 'v',program will circulate
      led2 = Serial.readStringUntil('#');
      value_led2 = String(led2).toInt();
      analogWrite(5, value_led2); //PWM value of digital 5 is value_led2
      break;//exit loop
    case 'w'://if val is 'w',program will circulate
      fans_char = Serial.readStringUntil('#');
      fans_val = String(fans_char).toInt();
      analogWrite(6, fans_val); //set PWM value of digital 6 to fans_val,the larger the value, the faster the fan
      break;//exit loop
Im englischen Teil des Forum müssen die Beiträge und Diskussionen in englischer Sprache verfasst werden. Deswegen wurde diese Diskussion in den deutschen Teil des Forums verschoben.
mfg ein Moderator.
int mylcd
Missing semicolon
fehlendes Semikolon
but what is with the error message?
It is telling you that the initialisation of the mylcd variable is not complete
why moved to german part of forum? I can not see a german word (except yours).
I am knowing "SC" as "schanderl":
Now I see "SC" as "nelirix", I am confused!
Best for You in 2025!
Should be int mylcd;
Compiler sees int mylcdServo servo_10; and can not handle this.
Why were all int variables defined as volatile? What's the point?
Because @nelirix originally posted his question in German and has subsequently edited it
ich habe einen error bei dem code hier:
error message: exit status 1 expected initializer before 'Servo'
As he/she seems to want to continue in English I have moved the topic to the Programming category of the forum
If you have a complier error, always look to the code before the error...
It says expected... that indicates that it expects something and instead finds something else (Servo in this case).
It takes a while to get familiar with interpretation of compiler errors...
...gets even worse with linker errors...
Code:
#include <Servo.h>
#include <Wire.h>
Servo servo_10;
Servo servo_9;
int length;
#define D0 -1
#define D1 262
#define D2 293
#define D3 329
#define D4 349
#define D5 392
#define D6 440
#define D7 494
#define M1 523
#define M2 586
#define M3 658
#define M4 697
#define M5 783
#define M6 879
#define M7 987
#define H1 1045
#define H2 1171
#define H3 1316
#define H4 1393
#define H5 1563
#define H6 1755
#define H7 1971
#define WHOLE 1
#define HALF 0.5
#define EIGHTH 0.25
int tune[] =
  M3, M3, M4, M5,
  M5, M4, M3, M2,
  M1, M1, M2, M3,
  M3, M2, M2,
  M3, M3, M4, M5,
  M5, M4, M3, M2,
  M1, M1, M2, M3,
  M2, M1, M1,
  M2, M2, M3, M1,
  M2, M3, M4, M3, M1,
  M2, M3, M4, M3, M2,
  M1, M2, D5, D0,
  M3, M3, M4, M5,
  M5, M4, M3, M4, M2,
  M1, M1, M2, M3,
  M2, M1, M1
//set music beat
float durt[] =
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 0.5, 0.5, 1, 1,
  1, 0.5, 0.5, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 1,
  1, 1, 1, 0.5, 0.5,
  1, 1, 1, 1,
  mylcd.init();
  delay(300);
  auto_sensor();
    pwm_control();
  switch (val) {
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
      delay(100);
      break;//exit loop
      delay(100);
      break;//exit loop
      delay(100);
      break;//exit loop
      delay(100);
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
      break;//exit loop
void birthday()
  tone(3, 440);
  delay(250);
  tone(3, 392);
  delay(250);
  tone(3, 532);
  delay(250);
  tone(3, 494);
  tone(3, 392);
  delay(250);
  tone(3, 440);
  delay(250);
  tone(3, 392);
  delay(250);
  tone(3, 587);
  delay(250);
  tone(3, 532);
  tone(3, 392);
  delay(250);
  tone(3, 784);
  delay(250);
  tone(3, 659);
  delay(250);
  tone(3, 532);
  delay(250);
  tone(3, 494);
  delay(250);
  tone(3, 440);
  delay(250);
  tone(3, 698);
  delay(375);
  tone(3, 659);
  delay(250);
  tone(3, 532);
  delay(250);
  tone(3, 587);
  delay(250);
  tone(3, 532);
//detect gas
  if (gas > 700) {
    while (flag == 1)
      tone(3, 440);
      delay(125);
      delay(100);
      noTone(3);
      delay(100);
      tone(3, 440);
      delay(125);
      delay(100);
      noTone(3);
      delay(300);
  } else
    //otherwise
    if (infrar == 1)
    } else//Otherwise
  if (water > 800)
    while (flag2 == 1)
      delay(100);
        break;//exit loop
  } else//Otherwise
      delay(10);
  if (soil > 50)
    while (flag3 == 1)
      tone(3, 440);
      delay(125);
      delay(100);
      noTone(3);
      delay(100);
      tone(3, 440);
      delay(125);
      delay(100);
      delay(300);
        break;//exit loop
  } else//Otherwise
void door() {
    Serial.print(".");
    Serial.print("");
    mylcd.print(pass);
  if (btn1_num >= 5)
    Serial.print("-");
    mylcd.print(pass);
    delay(10);
        delay(300);
        delay(5000);
        passwd = "";
        pass = "";
      } else //Otherwise
        passwd = "";
        pass = "";
        delay(2000);
    delay(50);
    delay(10);
      delay(100);
        tone(3, 532);
        delay(125);
      } else//Otherwise
// Birthday song
void music1() {
  birthday();
//Ode to joy
void music2() {
  Ode_to_Joy();
//PWM control
  switch (val)
      delay(300);
      break;//exit loop
      delay(300);
      break;//exit loop
      break;//exit loop
      break;//exit loop
It compiles OK for me
Sketch uses 13680 bytes (44%) of program storage space. Maximum is 30720 bytes.
Global variables use 1042 bytes (50%) of dynamic memory, leaving 1006 bytes for local variables. Maximum is 2048 bytes.
Please post the full error message copied from the IDE using the button provided for the purpose. Please use code tags when you post the error message
Which Arduino board are you using ?
okay here is the error message:
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
sketch_dec31a:5:10: fatal error: LiquidCrystal_I2C.h: No such file or directory
compilation terminated.
exit status 1
arduino uno
Have you installed that library and, if so, please post the full path to its location on your PC
how do i install it?
Using the Library Manager in the IDE
Which version of the IDE are you using ?
Where did you get the code from ?
may be you need to spend a bit of time learning the basics of the IDE and arduino environment
from Arduino's getting started page
Learn Arduino
  • Read an introduction on what is Arduino and why you'd want to use it.
  • What is the Arduino Software (IDE)?
  • Libraries: Using and installing Arduino Libraries.
  • Cores: Need to add a new board to your Arduino Software? Install the related core and manage it.
  • Troubleshooting: Advice on what to do if things don't work.
For a complete list of Guides visit the Learn section, where you will find in-depth knowledge about the principles and techniques behind the Arduino platform.
Making the Arduino Starter Kit projects and reading the book 'Getting Started with Arduino' are great ways to start learning and tinkering with coding and electronics.
It wouldn't cause a compiler error, but even a non-programmer should be able to spot the two obvious errors. Here's a clue, a quarter isn't equal to an eigth, and a sixteenth isn't bigger than a half :slight_smile:
[Edit: they don't seem to be used in the code]
you was right it wasnt installet
