Poolmaster with Opta?
Hi All, looking at options for my pool automation and came across this project>
Has anyone used the Opta for this?
Not that I know of, but it surely could be a good candidate for a future platform, provided the appropriate I/Os are exposed.
FYI one person ported the project to ESP32: https://github.com/Gixy31/ESP32-PoolMaster
And also I just completed an additional project which will shortly be linked to the PoolMaster code: GitHub - Loic74650/pH_Orp_Board: A 16 bits, two-channels, analog to digital convertion board with galavnic isolation to measure pH and Orp levels in pools and similar environments
Finally make sure to check the French Arduino thread on PoolMaster, which has loads of infos and discussions on that project
Cheers
Loic
Thanks LouLou, I managed to get my hands on a mega2560 board and have been thoroughly checking out the French discussion translating the best I can however I am stuck at the ethernet connection to my LAN. I have updated the MAC etc within the code however it is not connecting. I have tried a generic Arduino code for the ethernet shield and it works fine. Any ideas?
After starting the Ethernet connection, the Arduion will try to connect to the MQTT broker located on your LAN. Is it there?
Hi LouLou the MQTT broker is on the same LAN and is detected by my router, the ethernet shield is unfortunately not being detected by my router and unable to load the poolmaster.local page? Can you confirm what settings need to be manually changed in the config and poolmaster files? Thanks
Check out what needs be changed in the compatibility paragraph
What is the local IP address of your Broker and the local IP address of your Arduino?
