Power Arduino nano with the same power supply as the LED's with DC-Stepdown
Hello,
My goal is to power the arduino nano with the same power supply as the LED-stripe.
Current setup and wiring with USB as powersource:
Imgur
My plan is to wire the DC-Stepdown between the power supply and the VIN-Pin on the board:
Imgur
Then I configure the stepdown-module to output 5V.
Will this work or will it fry my board ?
in general, this should work if you connect the positive output of the step down module to the 5V pin of the Arduino. (in case the regulator is set to 5V) :+1:.
But actually there is a voltage regulator built in the Arduino board which should be able to handle 7 - 12V on the VIN pin....
Thank you for your answer, it did work :slight_smile:
I hooked the step down module to the VIN Pin and also regulated it down to 5 Volts, just to be safe.
vin needs to be a volt or two higher than +5. But if you wire the 5v from the step down directly to the 5v pin you should be fine
