hi,
have got some Nano's from ali. they have an usb-jack what i have no
cable for.
is it possible to supply power by a certain group of pins ?
Let's start by clarifying exactly which Nano boards you have
You have posted the forum category got Nano 33 BLE boards. Are they the ones that you have ?
How do you intend to upload code to them >
oh, i'm sorry, have forgotten : yes , would like upload sketch and in one case,
transmit data to a pc-application.
at least, substitute usb-jack..
the category is not especially for that, didnt know which to chosse, sorry !
on the nano, i dont find any text about nthat..
The USB cable is essential. How else are you going to program them.
Try a USB cable from your cellphone.
Note that there can be several versions of the Nano, with different types of USB sockets.
Post a link to the Ali page.
Leo..
thanks wawa,
send you a screenshot from alis website, where i had ordered.
guess, i failed to look at the connection type ![]()
my fault, i know..
for my smartphone i have a connector with 3 cables, but nothing of that fits for
my nano
think, i'll look at our media market to find any, if not availoable, will sell the nano's by ebay , and buy new ones Not from ali..
If the Nano is the classic version you can program it without using the USB connector but if you do not have a USB lead for it (probably a USB Mini connector) then you are unlikely to have the hardware to program it without one anyway
The Mino connector looks like this
Post the Ali link here so that we can all help
Your linke shows a (clone) classic nano and hence your topic has been moved.
You can use a so-called FTDI adapter (make sure it has the DTR pin broken out). This cable will also do: FTDI Cable 5V - SparkFun Electronics.
But if you have to invest money I suggest that you buy a proper USB-C cable.
The Ali page shows 3 different USB connectors available, miniB, microB and type C, Which did you buy?
I think the OP should just buy at least two cables of each type. That gives a spare if something fails. It will also allow the OP to work on communications between them with two IDEs open.
thank you all for your tipps !
meanwhile i've found two fitting cables in my fiddle box, bought 2 years before with nano's..
have good time !
