I am new to ESP32 and I am trying to make a project that is supposed to use an external power source. I am using an ESP32-WROOM-32 from Az-Delivery and a 380mah 3.7v LiPo battery to power the board. I know there are solutions like attaching it to the 5v pin or using a voltage regulator but in the end I am still very skeptical. Like I said this is my first time and I don't want my ESP32 to go up in flames so I just want to get all my facts checked before diving in.
Thanks.
Edit: OK so I have tried connecting the battery to the board using the 5v pin and ground and so far nothing has gone wrong... for now. I know what I just did was unreliable and could be hazardous for me and my board and this method is also impractical as I also need to use the 5v pin for other components later on. Please if you can suggest much more efficient methods.
The ESP32-WROOM-32 from Az-Delivery has a 3.3V pin. If the manufacturer states that it is OK to use this as input for 3.3V power, then an energy efficient solution is to use a 3.7V LiPo battery, and this stepdown regulator:
You can also use a linear voltage regulator, but make sure that it has very low dropout voltage (<100 mV) and can support at least 300 mA current draw.
Sorry not the boost converter but the actual circuit like why should I use 5v and not 3.7v?
Am I getting full potential from 5v? Does the board get damaged from 3.7v? Something like that.
I actually tried and it worked but I just wanna check before pursuing and also the fact that I need to reuse the 5v pin for other components and not just for power
My recommendation is to use the boost converter, It's safe, reliable, won't damage the board and will always work.
I don't recommend any other way to power a 5V esp32 even if it 'looks" like it's working.
It might
It might have a screw terminal that will accept more than on wire,
If not, you can solders everal wites together or use a breadboard/protoboard
