Powering motors
My arduino is yet to arrive, but I want to get things in place before it does. I have 4 brushless motors each requiring upto 18A. I have a battery that can supply the motors. Can someone advise how the circuit should be to supply the motors and and the arduino from the battery?
I assume the motors and arduino should be isolated from each other in some way, but what is the recommended approach? I guess this is a fairly standard thing to want to do, so is there a circuit diagram somewhere that might help?
Thanks,
Slicc
Here is some reading to get you started:
http://bildr.org/2012/03/rfp30n06le-arduino/
Slicc:
Alas that could mean several things. Which motors exactly? Datasheet or other
detailed description is needed. Perhaps they are RC brushless sensorless motors
(in which case you need 4 ESCs to match) perhaps not?
I have ordered ESCs to go with them, the motors are specced below. I'll read through the links provided, but just thought this was a fairly common thing to do.
Thanks,
Slicc
Kv (rpm/v) 1100
Weight (g) 57
Max Current (A) 20
Resistance (mh) 0
Max Voltage (V) 15
Power(W) 290
Shaft A (mm) -
Length B (mm) 28
Diameter C (mm) 28
Can Length D (mm) 15
