I'm trying to recover a Chinese Pro Micro clone (ATmega32U4, 5V/16MHz) that became unusable after I flashed SimHub firmware to it.
What happened
- The board originally worked fine.
- I uploaded sketches from Arduino IDE without issues.
- Later I flashed SimHub firmware.
- After that I tried to upload my own sketch again from Arduino IDE.
- Since then I have been unable to upload anything.
Current behavior
The board is normally not detected by Windows.
If I short RST to GND, Windows plays the USB connection sound and the board enters what appears to be the Caterina bootloader for about 8 seconds.
During those 8 seconds, Device Manager shows:
Ports (COM & LPT)
└─ Arduino Leonardo bootloader (COM4)
After approximately 8 seconds:
- the entire Ports (COM & LPT) category (including Arduino Leonardo bootloader (COM4)) disappears from Device Manager
- Windows plays the USB disconnect sound
This happens every time.
What I have already tried
I have tried every timing variation I can think of regarding Upload and Reset in A-IDE:
- Click Upload and press Reset at roughly the same time.
- Press Reset first, then click Upload.
- Click Upload first, then press Reset.
- Hold Reset during upload and release later.
- Release Reset when "Uploading..." appears.
- Release Reset before "Uploading..." appears.
- Double-reset.
- Repeated resets during upload.
- Every possible timing and variation of the above.
The bootloader always appears for a few seconds, then disappears before the upload succeeds.
Typical errors
Sometimes:
Error: unable to write: sorry no info avail
Error: butterfly_send(pgm, cmd, sizeof(cmd)) failed
Other times:
Error: cannot open port \\.\COM4: The system cannot find the file specified.
Error: unable to open port COM4 for programmer avr109
Failed uploading: uploading error: exit status 1
Additional troubleshooting
I also tried restoring the bootloader using another known-good Pro Micro clone as ISP.
I uploaded ArduinoISP to the good board and connected:
VCC -> VCC
GND -> GND
14 -> 14
15 -> 15
16 -> 16
10 -> RST
(using the pin numbers printed on both boards)
Then:
Board: Arduino Leonardo
Programmer: Arduino as ISP
Tools -> Burn Bootloader
Result:
Error: programmer is not responding
Warning: attempt 1 of 10: not in sync: resp=0x00
The programmer board can still upload and run sketches normally, so Arduino IDE, drivers and USB communication appear to be working.
Question
Has anyone seen a Pro Micro clone get into this state after flashing SimHub firmware?
The fact that:
- the bootloader appears correctly as Arduino Leonardo bootloader (COM4)
- stays alive for about 8 seconds
- then completely disconnects from Windows
makes me wonder whether:
- the main firmware is crashing USB immediately after bootloader timeout,
- the bootloader itself is corrupted,
- the ATmega32U4 flash contents are damaged,
- or my ISP recovery attempt is missing something obvious.
Any suggestions would be appreciated.
