Arduino: 1.8.19 (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None, Disabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\20035286\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\20035286\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\20035286\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\20035286\AppData\Local\Temp\arduino_build_170957 -warnings=none -build-cache C:\Users\20035286\AppData\Local\Temp\arduino_cache_431957 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esp-x32.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405 -prefs=runtime.tools.esp-x32-2405.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405 -prefs=runtime.tools.openocd-esp32.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20241016 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20241016.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20241016 -prefs=runtime.tools.dfu-util.path=C:\Users\20035286\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\20035286\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1 -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.3-cfea4f7c-v1.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1 -prefs=runtime.tools.mklittlefs.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.esp-rv32.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2405 -prefs=runtime.tools.esp-rv32-2405.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2405 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\14.2_20240403 -prefs=runtime.tools.xtensa-esp-elf-gdb-14.2_20240403.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\14.2_20240403 -prefs=runtime.tools.esptool_py.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.9.dev3 -prefs=runtime.tools.esptool_py-4.9.dev3.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.9.dev3 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\14.2_20240403 -prefs=runtime.tools.riscv32-esp-elf-gdb-14.2_20240403.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\14.2_20240403 -prefs=runtime.tools.mkspiffs.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\20035286\Downloads\DHT11_to_Firebase_IOT\DHT11_to_Firebase_IOT.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\20035286\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\20035286\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\20035286\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\20035286\AppData\Local\Temp\arduino_build_170957 -warnings=none -build-cache C:\Users\20035286\AppData\Local\Temp\arduino_cache_431957 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esp-x32.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405 -prefs=runtime.tools.esp-x32-2405.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405 -prefs=runtime.tools.openocd-esp32.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20241016 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20241016.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20241016 -prefs=runtime.tools.dfu-util.path=C:\Users\20035286\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\20035286\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1 -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.3-cfea4f7c-v1.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1 -prefs=runtime.tools.mklittlefs.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.esp-rv32.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2405 -prefs=runtime.tools.esp-rv32-2405.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2405 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\14.2_20240403 -prefs=runtime.tools.xtensa-esp-elf-gdb-14.2_20240403.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\14.2_20240403 -prefs=runtime.tools.esptool_py.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.9.dev3 -prefs=runtime.tools.esptool_py-4.9.dev3.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.9.dev3 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\14.2_20240403 -prefs=runtime.tools.riscv32-esp-elf-gdb-14.2_20240403.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\14.2_20240403 -prefs=runtime.tools.mkspiffs.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\20035286\Downloads\DHT11_to_Firebase_IOT\DHT11_to_Firebase_IOT.ino
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1
Using core 'esp32' from platform in folder: C:\Users\20035286\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1
cmd /c if exist "C:\\Users\\20035286\\Downloads\\DHT11_to_Firebase_IOT\\partitions.csv" COPY /y "C:\\Users\\20035286\\Downloads\\DHT11_to_Firebase_IOT\\partitions.csv" "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\partitions.csv"
cmd /c if not exist "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\partitions.csv" if exist "C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\doitESP32devkitV1\\partitions.csv" COPY "C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\doitESP32devkitV1\\partitions.csv" "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\partitions.csv"
cmd /c if not exist "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\partitions.csv" COPY "C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\tools\\partitions\\default.csv" "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\partitions.csv"
1 file(s) copied.
cmd /c IF EXIST "C:\\Users\\20035286\\Downloads\\DHT11_to_Firebase_IOT\\bootloader.bin" ( COPY /y "C:\\Users\\20035286\\Downloads\\DHT11_to_Firebase_IOT\\bootloader.bin" "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\DHT11_to_Firebase_IOT.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\doitESP32devkitV1\\bootloader.bin" ( COPY "C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\doitESP32devkitV1\\bootloader.bin" "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\DHT11_to_Firebase_IOT.ino.bootloader.bin" ) ELSE ( "C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\DHT11_to_Firebase_IOT.ino.bootloader.bin" "C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32\\bin\\bootloader_dio_80m.elf" ) )
esptool.py v4.8.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\20035286\\Downloads\\DHT11_to_Firebase_IOT\\build_opt.h" COPY /y "C:\\Users\\20035286\\Downloads\\DHT11_to_Firebase_IOT\\build_opt.h" "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\build_opt.h"
cmd /c if not exist "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\build_opt.h" type nul > "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\build_opt.h"
cmd /c type nul > "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957/file_opts"
cmd /c COPY /y "C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32\\sdkconfig" "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\sdkconfig"
1 file(s) copied.
Detecting libraries used...
"C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2405/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/cpp_flags" -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"doitESP32devkitV1\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/defines" "-IC:\\Users\\20035286\\Downloads\\DHT11_to_Firebase_IOT" -iprefix "C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/include/" "@C:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/includes" "-IC:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/dio_qspi/include" "-IC:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\cores\\esp32" "-IC:\\Users\\20035286\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\doitESP32devkitV1" "@C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957/build_opt.h" "@C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957/file_opts" "C:\\Users\\20035286\\AppData\\Local\\Temp\\arduino_build_170957\\sketch\\DHT11_to_Firebase_IOT.ino.cpp" -o nul
Alternatives for 'XTENSA_GNU_CONFIG' is defined but could not be loaded: []
cc1plus.exe: fatal error: 'XTENSA_GNU_CONFIG' is defined but could not be loaded: Unable to load DLL.ResolveLibrary('XTENSA_GNU_CONFIG' is defined but could not be loaded)
-> candidates: []compilation terminated.
exit status 1
Error compiling for board DOIT ESP32 DEVKIT V1.
That does not sound like a Nano33 IoT. So which board do you actually use?
BN: Unknown board
VID: 10C4
PID: EA60
SN: Upload any sketch to obtain it
Definitely not an Arduino Nano33 IoT and hence your topic has been moved.
Please post your sketch; don't forget to use code tags (you did it right in the opening post
Please provide links to any libraries that you use that are not available though library manager.
