Hello!
I want to create motion detecting light with PIR sensor and Relay using arduino
and was using this guide to do so: https://howtomechatronics.com/tutorials/arduino/how-pir-sensor-works-and-how-to-use-it-with-arduino/
But the relay turns on and off randomly and sometimes it stays on...
I tried replacing both the Relay and PIR sensor but did not help
I also tried replacing the Relay with led and it worked!
But still did not have any success with relay...
I guess there might be an power issue because I have connected both relay and PIR power pins to Arduino's 5v.
Any help regarding this would be appreciated.
Thanks.
6v6gt
2
Using this code? :
/* Arduini PIR Motion Sensor Tutorial
* by Dejan Nedelkovski, www.HowToMechatronics.com
int pirSensor = 8;
int relayInput = 7;
pinMode(pirSensor, INPUT);
pinMode(relayInput, OUTPUT);
int sensorValue = digitalRead(pirSensor);
if (sensorValue == 1) {
digitalWrite(relayInput, LOW); // The Relay Input works Inversly
maybe try replacing the loop() with this :
else {
digitalWrite(relayInput, HIGH);
Or a bit shorter
digitalWrite(relayInput, ! digitalRead(pirSensor) ) ; // The Relay Input works Inversly
