Problem with Accelerometer-Readings
Hi everyone. I hope that i write everything correct as this is my first time in this forum, but im currently in dispair. For a project i need to get roll/pitch/jaw. I'm using an mpu6050 accelerometer and a QMC5883L magnetometer. I display the angles on my laptop using vpython.
Im using a complimentary filter for sensorfusion.
The math is from the following website: Link
Here is my arduino code:
#include <QMC5883LCompass.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
QMC5883LCompass compass;
Adafruit_MPU6050 mpu;
int compass_x, compass_y, compass_z, compass_a, compass_b;
double accX, accY, accZ, wx, wy, wz;
double thetax, thetay, thetaz, thetaxt, thetayt, thetazt;
double time0, time1, dt;
double anglex, angley, anglez;
double alpha = 0.98;
double acc_off_x, acc_off_y, acc_off_z, w_off_x, w_off_y, w_off_z;
char myArray[3];
  while (!Serial)
    delay(10);  // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit MPU6050 test!");
  // Try to initialize!
  if (!mpu.begin()) {
    Serial.println("Failed to find MPU6050 chip");
    while (1) {
      delay(10);
  Serial.println("MPU6050 Found!");
  mpu.setAccelerometerRange(MPU6050_RANGE_16_G);
  mpu.setGyroRange(MPU6050_RANGE_2000_DEG);
  mpu.setFilterBandwidth(MPU6050_BAND_260_HZ);
  Serial.println("");
  delay(100);
  compass.init();
  // zero accelerometer
  Serial.println("Initializing Gyroscope and Accelerometer...");
  int iteration = 0;
  time0 = micros();
  time1 = micros();
  sensors_event_t a, g, temp;
  while (time0 < time1+10000000) {
    iteration++;
    mpu.getEvent(&a, &g, &temp);
    acc_off_x -= a.acceleration.x;
    acc_off_y -= a.acceleration.y;
    acc_off_z -= a.acceleration.z-9.81;
    w_off_x -= g.gyro.x;
    w_off_y -= g.gyro.y;
    w_off_z -= g.gyro.z;
    time0 = micros();
  acc_off_x /= iteration;
  acc_off_y /= iteration;
  acc_off_z /= iteration;
  w_off_x /= iteration;
  w_off_y /= iteration;
  w_off_z /= iteration;
  Serial.println("Initializing done...");
  Serial.print("Values: ");
  Serial.print("acc_off_x: ");
  Serial.print(acc_off_x, 4);
  Serial.print("  acc_off_y: ");
  Serial.print(acc_off_y, 4);
  Serial.print("  acc_off_z: ");
  Serial.print(acc_off_z, 4);
  Serial.print("  w_off_x: ");
  Serial.print(w_off_x, 4);
  Serial.print("  w_off_y: ");
  Serial.print(w_off_y, 4);
  Serial.print("  w_off_z: ");
  Serial.println(w_off_z, 4);
  Serial.println("Starting measurements...");
  delay(2000);
  // Documentation: https://ahrs.readthedocs.io/en/latest/filters/complementary.html
  compass.read();
  compass_x = compass.getX();
  compass_y = compass.getY();
  compass_z = compass.getZ();
  compass_a = compass.getAzimuth();
  compass_b = compass.getBearing(compass_a);
  compass.getDirection(myArray, compass_a);
  accX = a.acceleration.x + acc_off_x;
  accY = a.acceleration.y + acc_off_y;
  accZ = a.acceleration.z + acc_off_z;
  wx = g.gyro.x + w_off_x;
  wy = g.gyro.y + w_off_y;
  wz = g.gyro.z + w_off_z;
  thetax = atan2(accY, accZ);
  thetay = atan2(-accX, sqrt(accY*accY + accZ*accZ));
  thetaz = atan2(compass_z*sin(thetay)-compass_y*cos(thetay), compass_x*cos(thetax)+sin(thetax)*(compass_y*sin(thetay)+compass_z*cos(thetay)));
  time1 = time0;
  time0 = micros();
  dt = (time0 - time1) / 1000000;
  thetaxt = thetaxt + wx * dt;
  thetayt = thetayt + wy * dt;
  thetazt = thetazt + wz * dt;
  anglex = alpha * thetaxt + (1 - alpha) * thetax;
  angley = alpha * thetayt + (1 - alpha) * thetay;
  anglez = alpha * thetazt + (1 - alpha) * thetaz;
  Serial.print(anglex, 4);
  Serial.print(",");
  Serial.print(angley, 4);
  Serial.print(",");
  Serial.println(anglez, 4);
and the python code:
from time import *
import numpy as np
from vpython import *
import math
import serial
serial_con = serial.Serial
def multiprint(a,b):
    for i in range(0,b):
        print(a)
scene.range=5
toRad=2*np.pi/360
toDeg=1/toRad
scene.forward=vector(-1,-1,-1)
scene.width=1420
scene.height=800
xarrow=arrow(lenght=2, shaftwidth=.1, color=color.red,axis=vector(1,0,0))
yarrow=arrow(lenght=2, shaftwidth=.1, color=color.green,axis=vector(0,1,0))
zarrow=arrow(lenght=4, shaftwidth=.1, color=color.blue,axis=vector(0,0,1))
frontArrow=arrow(length=4,shaftwidth=.1,color=color.purple,axis=vector(1,0,0))
upArrow=arrow(length=1,shaftwidth=.1,color=color.magenta,axis=vector(0,1,0))
sideArrow=arrow(length=2,shaftwidth=.1,color=color.orange,axis=vector(0,0,1))
bBoard=box(length=6,width=2,height=.2,opacity=.8,pos=vector(0,0,0,))
#bn=box(length=1,width=.75,height=.1, pos=vector(-.5,.1+.05,0),color=color.blue)
#nano=box(lenght=1.75,width=.6,height=.1,pos=vector(-2,.1+.05,0),color=color.green)
myObj=compound([bBoard])
multiprint(" ",2)
print("Initializing...")
multiprint(" ",2)
while True:
    try:
        serial_con=serial.Serial('/dev/cu.usbmodem139968001',115200)
        print("Serial port opend...")
        multiprint(" ",2)
        sleep(1)
        break
    except:
        pass
while True:
    while serial_con.inWaiting()==0:
        pass
    dataPacket=serial_con.readline()
    dataPacket=str(dataPacket,'utf-8')
    print(dataPacket)
    if "Starting measurements..." in dataPacket:
        break
while True:
    splitPacket=dataPacket.split(",")
    roll=-float(splitPacket[1])
    pitch=-float(splitPacket[0])
    yaw=-float(splitPacket[2])+np.pi
    print("Roll=",roll*toDeg," Pitch=",pitch*toDeg,"Yaw=",yaw*toDeg)
    rate(1000)
    k=vector(cos(yaw)*cos(pitch), sin(pitch),sin(yaw)*cos(pitch))
    y=vector(0,1,0)
    s=cross(k,y)
    v=cross(s,k)
    vrot=v*cos(roll)+cross(k,v)*sin(roll)
    frontArrow.axis=k
    sideArrow.axis=cross(k,vrot)
    upArrow.axis=vrot
    myObj.axis=k
    myObj.up=vrot
    sideArrow.length=2
    frontArrow.length=4
    upArrow.length=1
If i tilt it around a single axis, everything works perfectly. Even if i do that really fast. But as soon as i start tilting it arround 2 or more axis, it doesn't return to the starting-position even closely. It just points into a random direction. Does anyone have an idea? I tried everithing inclueding switching sensorfusion off completly, and even then it didn't work. Am i just stupid and the mistake is obvious? Thank you very much for any advice.
For sensor fusion to work at all, the coordinate axes of the magnetometer and accelerometer must be almost perfectly aligned (X, Y and Z axes on mag. parallel to those on acc.), and both must be right handed coordinate systems.
It is very difficult for a hobbyist to accomplish this with independent sensor modules, so start with a modern 9DOF sensor, and you will have much better luck.
Finally, the complementary filter is outdated and not recommended, especially since many popular Arduino implementations are completely wrong, or at best, work only for approximately level flight. Most people use the Mahony or Madgwick filters.
BTW the following line of code is wrong. Do not subtract the acceleration due to gravity.
The up/down direction or gravity vector defines Z for calculation of tilt and roll angles. See How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing-DFRobot
Edit: I forgot to mention that magnetometers aren't useful "out of the box" as compasses, and need to be calibrated. The best overview and tutorial is this one: Tutorial: How to calibrate a compass (and accelerometer) with Arduino | Underwater Arduino Data Loggers
Hi
thank you very much for reply, i'll try it with a 9dof sensor. I get that the axis of the coordinate system have to be aligned perfectly. But what i dont get is why this line is wrong:
This is performed when it is lying flat on the table for claibration, so the only force that acts on the z-axis is the gravitational force. As i want the average offset, i need to subtract the gravitation from my offset reading. Or am i wrong?
What i also dont get is that it didnt't work even with no sensorfusion and no magnetometer. Every axis on its own worked perfectly (apart from the little drift which was minimal with the offset correction) but when combyning them strange things started to happen as described earlyer. Is this the falut of the mpu6050? It's a very cheap chip so i wouldn't be surprised. Any idea?
Kind Regards
Yes. See this tutorial: Tutorial: How to calibrate a compass (and accelerometer) with Arduino | Underwater Arduino Data Loggers
Or this one, scroll down to "Six point calibration": Accelerometer Calibration II: Simple Methods | Chionotech
I have no idea what you mean by this:
Ok thank you. What i meant was that if i only use the gyroscope with sipmle integration, each axis worked fine on its own. But when combining them, after returning to the initial position, the measurements were extremly far off. That was not caused by the drift.
You probably combined them incorrectly. If you have questions about code, post the minimum code that reproduces the issue, and give examples of the output.
The "gyro only" code posted here works as expected: GitHub - jremington/MPU-6050-Fusion: Mahony 3D filter for accel/gyro and gyro-only integration
If you try it, be sure to hold the sensor still while the gyro is being calibrated.
Thank you so much, i'll try that
Thank you, it worked much better. The only problem is that my whole environment is heavily exalerated. To be specific, i want to use it to determine the orientation of my model rocket. How would you accomplish the sensorfusion? Because the model behaves strange as my acceleration changes.
The accelerometer won't help to determine orientation in a model rocket. Sensor fusion approaches generally assume that the only acceleration being measured is that due to gravity.
Should i do it gyro only or is there any other method?
There are a number of model rocketry forums and clubs. What do the members usually use?
