Hi!
I am making a project using the Adafruit AMG8833 Thermal Camera Sensor. I set up the wiring according to the Adafruit instructions (I tried using A4 and A5 for I2C communication as well):
I was having trouble with the sensor so I tried running the example test codes from the Adafruit library and I'm still having the same problem.
It prints:
"AMGxx test
Could not find a vaid AMG88xx sensor, check wiring!
Here is the code:
#include <Wire.h>
#include <Adafruit_AMG88xx.h>
Adafruit_AMG88xx amg;
Serial.println(F("AMG88xx test"));
bool status;
// default settings
status = amg.begin();
if (!status) {
Serial.println("Could not find a valid AMG88xx sensor, check wiring!");
while (1);
Serial.println("-- Thermistor Test --");
delay(100); // let sensor boot up
Serial.print("Thermistor Temperature = ");
Serial.print(amg.readThermistor());
Serial.println(" *C");
//delay a second
Again, this is the example code from Adafruit and using the wiring from Adafruit so i'm not sure what the problem is.
Any ideas or suggestions?
Thanks!
