Hey
So recently, i've bought an arduino pro mini 3.3v. For the first time i connected it to my pc using PL2303 USB-TO-TTL Adapater and uploaded an blink sketch to it.
Right after that, i wanted to upload something else and i was getting "avrdude: stk500_getsync(): not in sync: resp=0x00"
I did some search on the internet and tried to program it using USBASP programmer or an arduino uno as ISP. Using both way, i got no result because apparently the chip signature was changing every time i applied voltage to the board (which was either 5v or 9v to the raw pin).
So i used the "ProgISP" program and tried to write the default fuse bits in case that solves the problem. Suddenly i noticed the fuse bits change constantly (every time i pressed "Read" i was getting a new set of fuse bits!) and after a few tries i was getting "Chip enable program error" which i guess is because change of CKSEL fuse bits.
Now i cant burn the bootloader, or upload using programmer because i am getting :
Arduino: 1.8.9 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (3.3V, 8 MHz)"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbasp
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
Error while burning bootloader.
option enabled in File -> Preferences.
Since Arduino Pro Mini's ATMEGA328P is not dip, is there anyway i can connect external crystal OR HV program it to reset fuse bits or should i buy a new arduino? ![]()
Regards
