Hey im making a braille alphabet with servos and 3 buttons the first is to change the letters upwards for example a,b,c and the second one is to do it backwards e.g. c,b,a etc. and the third one is the enter you can view the letters on the lcd but i have some problems with it
one of which is that it shows a little of gibberish and when i click the buttons it cycles thru the letters and i cant think of a way to make the enter work here is the code please help me!
// Добавя се библиотеката на серво моторите
#include <Servo.h>
// Даваме индентифиционен номер/име на серво моторите
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
const int buttonPin1 = 2;
const int buttonPin2 = 4;
const int buttonPin3 = 7;
char str[] = "abcdefghijklmnopqrstuvwxyz";
LiquidCrystal_I2C lcd(0x27, 16, 2);
int buttonState1 = 0;
int buttonState2 = 0;
int buttonState3 = 0;
char val;
int letter = 0;
bool print = false;
//Позиция на сервотата в градуси
int down = 0;
int up = 90;
lcd.begin();
lcd.backlight();
lcd.clear();
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
pinMode(buttonPin3, INPUT);
/// Serial.begin(9600); // Serial comm begin at 9600bps
//Казваме къде са включени сервотата (3-5-6-9-10-11)
servo1.attach (3);
servo2.attach (5);
servo3.attach (6);
servo4.attach (9);
servo5.attach (10);
servo6.attach (11);
servo1.write(down);
servo2.write(down);
servo3.write(down);
servo4.write(down);
servo5.write(down);
servo6.write(down);
lcd.setCursor(0, 0);
lcd.print("Choose a letter:");
lcd.setCursor(0, 1);
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
buttonState2 = digitalRead(buttonPin3);
if (buttonState1 == HIGH) {
letter=letter+1;
buttonState1 == LOW;
if (buttonState2 == HIGH) {
letter=letter-1;
buttonState2 == LOW;
// lcd.setCursor(0, 0);
// lcd.setCursor(0,1);
// lcd.print(val);
if (buttonState3 == HIGH) {
print=true;
lcd.print("A letter has been entered!");
switch (letter){
case 1:
lcd.print('a');
val = 'a';
case 2:
lcd.print('b');
val = 'b';
case 3:
lcd.print('c');
val = 'c';
case 4:
lcd.print('d');
val = 'd';
case 5:
lcd.print('e');
val = 'e';
case 6:
lcd.print('f');
val = 'f';
case 7:
lcd.print('g');
val = 'g';
case 8:
lcd.print('h');
val = 'h';
case 9:
lcd.print('i');
val = 'i';
case 10:
lcd.print('j');
val = 'j';
case 11:
lcd.print('k');
val = 'k';
case 12:
lcd.print('l');
val = 'l';
case 13:
lcd.print('m');
val = 'm';
case 14:
lcd.print('n');
val = 'n';
case 15:
lcd.print('o');
val = 'o';
case 16:
lcd.print('p');
val = 'p';
case 17:
lcd.print('q');
val = 'q';
case 18:
lcd.print('r');
val = 'r';
case 19:
lcd.print('s');
val = 's';
case 20:
lcd.print('t');
val = 't';
case 21:
lcd.print('u');
val = 'u';
case 22:
lcd.print('v');
val = 'v';
case 23:
lcd.print('w');
val = 'w';
case 24:
lcd.print('x');
val = 'x';
case 25:
lcd.print('y');
val = 'y';
case 26:
lcd.print('z');
val = 'z';
if (letter ==27)
letter =0;
if (letter ==-1)
letter =26;
//val=letter
///if (Serial.available()) // if serial value is available
///{ val = Serial.read(); // then read the serial value
if(print == true)
if (val == 'a' or val == 'b' or val == 'c' or val == 'd' or val == 'e' or val == 'f' or val == 'g' or val == 'h' or val == 'k' or val == 'l' or val == 'm' or val == 'n' or val == 'o' or val == 'p' or val == 'q' or val == 'r' or val == 'u' or val == 'v' or val == 'x' or val == 'y' or val == 'z')
servo1.write(up);
if (val == 'b' or val == 'f' or val == 'g' or val == 'h' or val == 'i' or val == 'j' or val == 'l' or val == 'p' or val == 'q' or val == 'r' or val == 's' or val == 't' or val == 'v' or val == 'w')
servo2.write(up);
if (val == 'k' or val == 'l' or val == 'm' or val == 'n' or val == 'o' or val == 'p' or val == 'q' or val == 'r' or val == 's' or val == 't' or val == 'u' or val == 'v' or val == 'x' or val == 'y' or val == 'z')
servo3.write(up);
if (val == 'c' or val == 'd' or val == 'f' or val == 'g' or val == 'i' or val == 'j' or val == 'm' or val == 'n' or val == 'p' or val == 'q' or val == 's' or val == 't' or val == 'w' or val == 'x' or val == 'y')
servo4.write(up);
if (val == 'd' or val == 'e' or val == 'g' or val == 'h' or val == 'j' or val == 'n' or val == 'o' or val == 'q' or val == 'r' or val == 't' or val == 'w' or val == 'y' or val == 'z')
servo5.write(up);
if (val == 'u' or val == 'v' or val == 'w' or val == 'x' or val == 'y' or val == 'z')
servo6.write(up);
delay(5000);
servo1.write(down);
servo2.write(down);
servo3.write(down);
servo4.write(down);
servo5.write(down);
servo6.write(down);
print = false;
