so my motor will only spin when i write 255 in analog to the enable pins, it will not spin using values from 0-254
i tested it with this code, the motor indeed only spins when the value is 255
also sorry for writing the code in indonesian, its for a competition
You need to post ALL your code.
How are we supposed to know what PIN numbers you have assigned to these pins?
It could be a pin that is incapable of producing a PWM signal.
What sort of Arduino are you using?
How is it wired up?
#include <Servo.h>
#include <IRremote.h>
const int recv_pin = 2;
const int motor1pin1 = 3;
const int motor1pin2 = 4;
const int motor1pinENA = 9;
const int motor2pin1 = 5;
const int motor2pin2 = 6;
const int motor2pinENA = 10;
const int pinServo = 11;
Servo tangan;
IrReceiver.begin(recv_pin);
tangan.attach(pinServo);
pinMode(pinServo, OUTPUT);
pinMode(recv_pin, INPUT);
pinMode(motor1pin1, OUTPUT);
pinMode(motor1pin2, OUTPUT);
pinMode(motor1pinENA, OUTPUT);
pinMode(motor2pin1, OUTPUT);
pinMode(motor2pin2, OUTPUT);
pinMode(motor2pinENA, OUTPUT);
tangan.write(155);
if(IrReceiver.decode())
Serial.println(IrReceiver.decodedIRData.decodedRawData , HEX);
switch(IrReceiver.decodedIRData.decodedRawData)
case 0xFF00DB24: //maju
maju(255);
case 0xE619DB24: //maju pelan
maju(254);
case 0xFE01DB24: //mundur
mundur(255);
case 0xEF10DB24: //mundur pelan
mundur(200);
case 0xFD02DB24: // kanan
kanan(255);
case 0xE31CDB24: // kanan pelan
kanan(200);
case 0xFC03DB24: // kiri
kiri(255);
case 0xF20DDB24: // kiri pelan
kiri(200);
case 0xF40BDB24: // buka tangan
Serial.println("buka tangan");
tangan.write(155);
case 0xBC43DB24: // tutup tangan
Serial.println("tutup tangan");
tangan.write(25);
default:
digitalWrite(motor1pin1, LOW);
digitalWrite(motor1pin2, LOW);
digitalWrite(motor2pin1, LOW);
digitalWrite(motor2pin2, LOW);
delay(300);
IrReceiver.resume();
void maju(int kecepatan){
Serial.println("maju");
digitalWrite(motor1pin1, HIGH); //motor kanan maju
digitalWrite(motor2pin1, HIGH); //motor kiri maju
for(int i = 0; i <= 255; i++)
analogWrite(motor1pinENA, i);
analogWrite(motor2pinENA, i);
delay(20);
for(int i = 255; i >= 0; i--)
delay(20);
void mundur(int kecepatan){
Serial.println("mundur");
digitalWrite(motor1pin1, LOW); //motor kanan mundur
digitalWrite(motor1pin2, HIGH);
analogWrite(motor1pinENA, kecepatan);
digitalWrite(motor2pin1, LOW); //motor kiri mundur
digitalWrite(motor2pin2, HIGH);
analogWrite(motor2pinENA, kecepatan);
void kanan(int kecepatan){
Serial.println("kanan");
digitalWrite(motor1pin1, LOW); // motor kanan mundur
void kiri(int kecepatan){
Serial.println("kiri");
JCA34F
November 19, 2022, 4:43pm
5
Using the servo library disables PWM on pins 9 and 10, try using pins 3 and 11 for ena1 and ena2, use 9 or 10 for the servo(s).
Why are there no servos in the diagram but lots of them in the code?
Is this a true diagram?
Why is the IR sensor connected to the 3V3 line? This means you can only get 3V3 signals out of it which is insufficient to drive a 5V input. Why is there no supply decoupling around the IR sensor like it shows in the sensor's data sheet?
And also, the IRremote library uses a timer which will prevent PWM on two other pins. By default, Servo and IRremote try to use the SAME timer (Timer1) so you will need to tell IRremote to use a different timer (Timer2). That leaves the two PWM pins (Pins 5 and 6) from Timer0 for your enable pins:
how do you tell IRremote to do that?
peiwastaken:
how?
#define IR_USE_AVR_TIMER 2
#include <IRremote.hpp>
johnwasser:
oh i was also wondering what the diffrence is between .h and .hpp
that works!! thank you so much
All I know is the IRremote.h contains nothing but:
I think that '.hpp' files are somehow "for C++, not C".
update, i need to controll another servo and i think ive run out of pins
i cant seem to use the pins 10 - 13
what are all the pins that are disabled by the servo and IRremote library?
peiwastaken:
You should not address this problem in two different threads. You asked about this already here .
