Problem with NRF24L01+Arduino
I am trying to communicate between two arduino using nrf24L01. I am using nrf24L01 first time. its not working. i am not getting what may be the problem.
the transmitter module shows in serial monitor:
packet delivery failed
the receiver module shows in serial monitor:
No Radio
No Radio
No Radio
Transmitter Code:
 //*****************************Arduino Code for Transmitter***********************
//This sketch is from a tutorial video on the ForceTronics YouTube Channel. The tutorial discusses how to build a
//shield and a prototyping board for the nRF24L01 Transceiver Module.
//the code was leverage from Ping pair example at http://tmrh20.github.io/RF24/pingpair_ack_8ino-example.html
//This sketch is free to the public to use and modify at your own risk
#include <SPI.h> //Call SPI library so you can communicate with the nRF24L01+
#include <nRF24L01.h> //nRF2401 libarary found at https://github.com/tmrh20/RF24/
#include <RF24.h> //nRF2401 libarary found at https://github.com/tmrh20/RF24/
const int pinCE = 9; //This pin is used to set the nRF24 to standby (0) or active mode (1)
const int pinCSN = 10; //This pin is used to tell the nRF24 whether the SPI communication is a command or message to send out
RF24 wirelessSPI(pinCE, pinCSN); // Create your nRF24 object or wireless SPI connection
const uint64_t pAddress = 0xB00B1E5000LL;   // Radio pipe addresses for the 2 nodes to communicate.
  Serial.begin(57600);   //start serial to communicate process
  wirelessSPI.begin();            //Start the nRF24 module
  wirelessSPI.setAutoAck(1);                    // Ensure autoACK is enabled so rec sends ack packet to let you know it got the transmit packet payload
  wirelessSPI.setRetries(5,15);                 // Sets up retries and timing for packets that were not ack'd, current settings: smallest time between retries, max no. of retries
  wirelessSPI.openWritingPipe(pAddress);        // pipe address that we will communicate over, must be the same for each nRF24 module
  wirelessSPI.stopListening();
   byte t = 145; //analogRead(0);//note that we can cast the ADC value to a byte because we know the temp sensor is not going to return a value higher than 255
   if (!wirelessSPI.write(&t, 1 )){  //if the send fails let the user know over serial monitor
       Serial.println("packet delivery failed");
Receiver Code:
byte bVal; //used to store ADC value payload from transmit module, the ADC value will be < 256 so it will fit in a byte
RF24 wirelessSPI(pinCE, pinCSN); // Declare object from nRF24 library (Create your wireless SPI)
const uint64_t pAddress = 0xB00B1E5000LL;  //Create a pipe addresses for the 2 nodes to communicate over, the "LL" is for LongLong type
  wirelessSPI.setAutoAck(1);                    // Ensure autoACK is enabled, this means rec send acknowledge packet to tell xmit that it got the packet with no problems
  wirelessSPI.openReadingPipe(1,pAddress);      //open pipe o for recieving meassages with pipe address
  wirelessSPI.startListening();                 // Start listening for messages
   //loop until all of the payload data is recieved, for this example loop should only run once
if (!wirelessSPI.available())
  Serial.println("No Radio");
    while(wirelessSPI.available()){
     wirelessSPI.read( &bVal, 1 ); //read one byte of data and store it in bVal variable
     Serial.print("Temperature at transmitter is ");
     Serial.print(calculateTempF(calculateArduinoVolt(bVal))); //convert the ADC value to a voltage value and than to a temperature value in F
     Serial.println(" F");
  delay(200);
//this function calculates temp in F from TMP36 temp sensor
float calculateTempF(float v1) {
 float temp = 0;
 //calculate temp in C, .75 volts is 25 C. 10mV per degree
 if (v1 < .75) { temp = 25 - ((.75-v1)/.01); } //if below 25 C
 else if (v1 == .75) {temp = 25; }
 else { temp = 25 + ((v1 -.75)/.01); } //if above 25
 //convert to F
 temp =((temp*9)/5) + 32;
 return temp;
//This function takes an Arduino analog pin reading and converts it to a voltage value
float calculateArduinoVolt(int val) {
 float volt = (float)val * (5.0 / 1023.0); //convert ADC value to voltage
 return volt;
wiring in both side is as attachement
I have use arduino uno in receiver side and neno in transmitter side but wiring in both are same
Try the examples in this Simple nRF24L01+ Tutorial
They are simple, so they should be easy to understand and they do work.
...R
I've not read through your code or tried it but I had issues transmitting and receiving even with the sample codes spent ages trying to find out why and did lots of research. Thinking everyone else has got them working from the samples from the Tutorial posted above. I was using a uno has the transmitter and a nano as the receiver. The uno was uploaded via usb and the nano was programmed by the ISCP with usbasp programmer . After it was doing my head I found out that the error was caused by me leaving the ISCP connector still been connected through the usbasp programmer. Removed and it started working perfectly. How are your units connected ?
Your Original Post did not mention that you were using ICSP to upload code and my crystal ball is broken.
I have had the same problem using ICSP to upload code to an Attiny. Sometimes it works even with the programmer connected. Mostly it doesn't.
...R
Yeah I did not think that would be the coarse of it and forgot to mention it but we all learn from our mistakes
Try a different supply for the xmitr than the arduino 3.3v supply. Then go to Terry's site "http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo". Lots of good stuff! great tutorials.
I have uploaded code from arduino ide 1.6.12 on both uno and neno. i also have tried so many samples from the net but yet not get success. i used the RF library from GitHub - nRF24/RF24: OSI Layer 2 driver for nRF24L01 on Arduino & Raspberry Pi/Linux Devices, https://github.com/maniacbug/RF24 and from other also one by one. i thought it may be due to library error.
i don't think its power supply problem as nrf power consuption is max 15ma and arduino 3.3v has 150ma output.
If you go to the web site 123splat posted you will find your answer there here is a little quote from there
These instability problems are particularly noticeable when 3.3V power comes from a UNO, MEGA, Nano etc. that has only 50 ma of 3.3V power available.
Yes they only draw 13ma but the spike current can be a lot higher on Tx if you don't put a 10uF across the power pins like that mentioned on that website you will never get them working. You could have a faulty unit may be
vijaysurat:
I have uploaded code from arduino ide 1.6.12 on both uno and neno. i also have tried so many samples from the net but yet not get success. i used the RF library from GitHub - nRF24/RF24: OSI Layer 2 driver for nRF24L01 on Arduino & Raspberry Pi/Linux Devices, GitHub - maniacbug/RF24: Arduino driver for nRF24L01 and from other also one by one. i thought it may be due to library error.
I have only just now realized that you did not write Reply #2.
Have you tried the examples in the link I gave in Reply #1.
...R
Robin2:
...R
OK i will try.. and i am not using external programmer. i am programming neno directly via usb cable. using arduino ide
vijaysurat:
That makes life simpler.
...R
Thank you robin. :slight_smile: that works for me. :slight_smile: :slight_smile:
First it worked but it shows data sometime and sometime not. then i used buckconverter to supply nrf from arduino 5v by converting it to 3.3v. now its working perfectly. i have also used 10mfd direcly soldered on nrf module. Thank you once again
one thing i also marked that nrf should be supplied with good quality wire, bad quality wire drop voltage at end and should be soldered to pin directly, connector in supply may cause problems and confusions too
This simple code is working fine. Now i want both unit works as transmitter and receiver also. how can i merge both code in a single arduino, in which it stay in receiver mode and can be made transmitter whenever i need.
SimpleTx.ino
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
    Serial.println("SimpleTx Starting");
    radio.begin();
    radio.setDataRate( RF24_250KBPS );
    radio.setRetries(3,5); // delay, count
    radio.openWritingPipe(slaveAddress);
    currentMillis = millis();
    if (currentMillis - prevMillis >= txIntervalMillis) {
        send();
        prevMillis = millis();
void send() {
    bool rslt;
    rslt = radio.write( &dataToSend, sizeof(dataToSend) );
        // Always use sizeof() as it gives the size as the number of bytes.
        // For example if dataToSend was an int sizeof() would correctly return 2
    Serial.print("Data Sent ");
    Serial.print(dataToSend);
    if (rslt) {
        Serial.println("  Acknowledge received");
        updateMessage();
    else {
        Serial.println("  Tx failed");
void updateMessage() {
        // so you can see that new data is being sent
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
    dataToSend[8] = txNum;
SimpleRx.ino
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
    Serial.println("SimpleRx Starting");
    radio.begin();
    radio.openReadingPipe(1, thisSlaveAddress);
    radio.startListening();
    getData();
    showData();
void getData() {
    if ( radio.available() ) {
        radio.read( &dataReceived, sizeof(dataReceived) );
        newData = true;
void showData() {
    if (newData == true) {
        Serial.print("Data received ");
        Serial.println(dataReceived);
        newData = false;
vijaysurat:
Have a look at the other examples in my Tutorial that I linked to in Reply #1
...R
