Problem with Temperature Sensor/Motor code
I am trying to build a fan that senses the temperature in the room and turns on a motor after the temperature sensor surpasses the room temperature. However, the temperature sensor continues to give fluctuating readings and often times the arduino serial monitor reads temperature values even when the temperature sensor is not present in the circuit. Here is the code, any assistance helpful
int led = 13; //led attached to pin 13
int motorPin = 9; //motor attached to pin 9
const int tempPin = A0; //temperature sensor attached to pin A0
float baselineTemp = 0; //Base temperature is 21 degrees celsius
int CaltempVal;
int sensorVal;
int tempVal;
float temp;
pinMode(led,OUTPUT); //voltage coming out of pin 13
pinMode(motorPin, OUTPUT);//votlage coming out of pin 9
Serial.begin(9600); //open serial connection to display values
Serial.println("begin");
while(millis() < 5000) { // calibrate for 5 secs
CaltempVal= analogRead(A0);
if (CaltempVal > baselineTemp){ //if the temp in the room is higher than baseline temp than temp value is new baseline temp
baselineTemp = CaltempVal;
float volt = (baselineTemp / 1024.0)* 5.0; //convert the ADC reading to voltage
float temp = (volt - .5)* 100;
Serial.print("finished, roomtemp is:");
Serial.println(temp);
int tempVal = analogRead(tempPin);
Serial.print("sensor Value:"); //print out the name serial print
Serial.print(tempVal); //send out the voltage
float voltage = (tempVal / 1024.0)* 5.0; //convert the ADC reading to voltage
Serial.print(", Volts: ");
Serial.print(voltage); //send the voltage level tout the Serial port
Serial.print(",degrees C:");
float temperature = (voltage - .5)* 100;
Serial.println(temperature); //convert the voltage in to temperature in degrees C
if (temperature <= temp +4){ // if temperature is lower or equal to room temp, the fan is off
digitalWrite(led, LOW);
digitalWrite(motorPin, LOW);
else if (temperature > temp + 4) { //if temperature is higher than room temp, the fan will turn on
digitalWrite(led, HIGH);
digitalWrite(motorPin,HIGH);
//end of loop
Please edit your post and add code tags ("</>" button).
You are reading the voltage on an analog pin. That pin will have a voltage value, regardless of whether a temperature sensor is attached to it.
paulinom99:
int CaltempVal;
int sensorVal;
int tempVal;
float temp;
//end of loop
Your code has a few problems:
First, you have a global variable named temp, then you create a local variable in setup() also named temp. Then you use the the uninitialized global temp to decide wheither or not to turn on the fan.
Remove the local declaration of temp in setup(). Just use the global temp, like this:
// origional code in setup()
  float temp = (volt - .5)* 100; // declaring a local float variable named temp
// corrected Code
  temp = (volt - .5)* 100;  // using the globally defined variable named temp
Also, we could give you more specific answers if you included a schematic of your circuit, and actually identified which Arduino you are using (Uno,Mega,mini, Pro Mini, ... etc).
Please use the [code] and [/code] markup tags before and after your code, it makes it easier to read.
Chuck.
