Problems with apple silicon
good morning,
I recently bought the MKR1300 card but when I go to the board manager to install everything I need this error message:
Errore durante lo scaricamento di http://downloads.arduino.cc/tools/openocd-0.10.0-arduino7-static-x86_64-apple-darwin13.tar.bz2
java.lang.RuntimeException: java.lang.Exception: Errore durante lo scaricamento di http://downloads.arduino.cc/tools/openocd-0.10.0-arduino7-static-x86_64-apple-darwin13.tar.bz2
	at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$2(ContributionManagerUI.java:179)
	at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Errore durante lo scaricamento di http://downloads.arduino.cc/tools/openocd-0.10.0-arduino7-static-x86_64-apple-darwin13.tar.bz2
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:145)
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:79)
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:56)
	at cc.arduino.contributions.packages.ContributionInstaller.install(ContributionInstaller.java:108)
	at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$2(ContributionManagerUI.java:172)
	... 1 more
Caused by: java.net.SocketTimeoutException: connect timed out
	at java.net.PlainSocketImpl.socketConnect(Native Method)
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
	at java.net.Socket.connect(Socket.java:607)
	at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
	at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
	at sun.net.www.http.HttpClient.New(HttpClient.java:339)
	at sun.net.www.http.HttpClient.New(HttpClient.java:357)
	at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1226)
	at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1205)
	at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1056)
	at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:990)
	at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:138)
	at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:96)
	at cc.arduino.utils.network.FileDownloader.openConnectionAndFillTheFile(FileDownloader.java:217)
	at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:176)
	at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:125)
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:143)
	... 5 more
	... 1 more
	... 5 more
I use the latest version of macOS and Arduino.
how can i solve?
Thanks in advance!
Hi @nocentini. Does the error still occur if you try it again now? This type of error might be caused by a transient network service degradation or outage. These will normally resolve on their own after a relatively short time.
I see this when something is missed such as a brace or other punctuation and if I have two or more errors it gets worse and if the code is a few hundred lines it happens a lot. The only fix is to check what I recently did, maybe comment it out and run the compiler again. When I get this it appears the compiler gets stuck and I Have to reload the IDE. My compiler is running on several versions of Linux. currently 1.8.18 but on earlier versions as well.
@gilshultz are you saying that you have observed a missing brace in your code to cause a timeout while installing a platform via the Arduino IDE Boards Manager?
I have no clue but replacing a missing brace, comma, etc solved the problem. The error looked similar with all the java.lang.Exception: errors. If I get a screen full of java errors I do not bother looking any more, sometimes it will not let me scroll in the windows. This has happened without any hardware or libraries involved. I use the compiler without uploading as a syntax check on the code. Sometimes I can change the code and try again but the only mode that works is to upload. If that fails generally I have to restart the IDE as nothing appears to work in it including saving code so I now exclusively use an external editor generally Geany or Xed.
A huge number of completely unrelated problems can cause the Arduino IDE 1.x to produce a Java stack trace that looks vaguely like this. You have to carefully examine the content, which is not always so easy or pleasant for those of us who don't have a familiarity with the IDE code base.
These stack traces are ideal for use by a developer to troubleshoot an error that should never occur if the code was working as intended. They are horrible as a way to communicate to the user when a problem occurs under expected conditions that are not related to a defect in the code, as is likely the case here.
now it seems that the problem has changed, I tried to change internet connection and the error message is this:
java.lang.RuntimeException: java.lang.Exception: The CRC does not match, the file is corrupt. This may be a temporary problem, please try again later	at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$2(ContributionManagerUI.java:179)
Caused by: java.lang.Exception: Il CRC non corrisponde, il file è rovinato. Potrebbe essere un problema temporaneo, riprova dopo
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:101)
	... 1 more
java.lang.RuntimeException: java.lang.Exception: Il CRC non corrisponde, il file è rovinato. Potrebbe essere un problema temporaneo, riprova dopo
	... 1 more
the error lines you read in Italian are just a repetition of the first sentence, I didn't translate everything into English
