I have mounted an ambilight on a monitor, with 4 LED strips (w2812b) cut and joined by L connectors (top, bottom, left and right). When I turn on the Arduino, put the program, put the number of LEDs (122), only the bottom strip lights up, the rest do not light up, I have tried with another strip and the same thing happens. Do you know the reason?
it's likely in the code you did not provide or in the circuit / power you did not document....
we can't help much as our proverbial crystal ball is still in the dishwasher...
ā Please do yourself a favor and read How to get the best out of this forum. Post accordingly, including code with code tags, necessary documentation for your request such as your exact circuit and power supply details, links to components, etc.
Bad connection between first and second strip would be too obvious?
Can you share a picture and schematic of your setup?
solved. they were the L connectors
