Problems with r4 wifi
Hi, I’m having a problem with my Arduino R4 WiFi today; it won't update or accept code—it's locked up. Does anyone know how I can get it back to its normal state?
Welcome to the forum
How and where are you seeing this problem ?
Is the COM port of the board created when you plug it in ?
Have you tried double tapping the reset button on the board before uploading a sketch ?
i tried all but the com port doesn't recognize the Arduino
Is the COM port created when you plug in the board ?
yes is created but the arduino ido app it doesn't recognize the Arduino and the pc doesn't recognize too
So, a COM port is created when the board is plugged in, you choose the board and that COM port in the IDE but uploading fails
Is that correct ?
yes is correct but the board is kinda blocked
Have you tried the double tap trick ?
I tried, but it didn't work.
Maybe this: https://support.arduino.cc/hc/en-us/articles/9670986058780-Update-the-connectivity-module-firmware-on-UNO-R4-WiFi#espflash
or: https://support.arduino.cc/hc/en-us/articles/16379769332892-Restore-the-USB-connectivity-firmware-on-UNO-R4-WiFi-with-espflash
here it says that the computer will send a mensage that it detect the arduino but it dosent
Which COM port is created when you plug in teh board ?
Is the Com 10
Does anything connected to the board?
no only the board
Hi @santy_114.
These statements are all quite vague. I'm not sure I understand the exact nature of the problem you are experiencing. Please provide a more detailed description of what you mean in a reply on this forum topic to help us to understand it.
Make sure to include the following information:
  • What did you do?
  • What were the results you expected from doing that thing?
  • What were the results you observed that did not match your expectations?
If you encountered any errors or warnings, please provide the full and exact text of those messages.
OK,
I tried to update the Arduino firmware, but the Arduino IDE reported an error while installing the update.
Expected result:
The Arduino should continue working correctly, as it always has.
Actual result:
After the failed firmware update, the Arduino was no longer recognized by either my computer or the Arduino IDE.
It is essential to power cycle the board after performing a firmware update. The board is placed in a special mode in order to update the firmware on the connectivity module, and it remains in that mode at the conclusion of the update. The power cycle restores the board to its normal operating mode.
Please disconnect the USB cable and any other power sources from the board, then connect it to your computer with the USB cable once again. Do you now see the port of the UNO R4 WiFi board listed in Arduino IDE's Tools > Port menu?
No the problem continues
Please try the following experiment, then report the results in a reply here on the forum topic:
  1. Connect the UNO R4 WiFi board to your computer with the USB cable.
  2. Press and release the button marked "RESET" on your UNO R4 WiFi board quickly twice.
Do you now see the on-board LED that is marked "L" pulsing?
