Programming a 4X4 Trellis keypad to act as a midi pad?
Well for my first project I hooked up an arduino uno to a trellis keypad from adafruit( Adafruit Trellis Monochrome Driver PCB for 4x4 Keypad & 3mm LEDs : ID 1616 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits ). Since this is my first project, I really have no knowledge of how to program something of this manner. My goal is to use each of the buttons to control a midi sound via the computer. Ill probably be using Ableton Live, or someother software similar. I would just like some help on how to code a program to send keystroke data or button data to the computer. Currently the keypad is hooked up the the +5V, GND, A5, and A4 pins on the arduino.
I was wondering if I could modify the example code to work as a midi controller.
  This is a test example for the Adafruit Trellis w/HT16K33
  Designed specifically to work with the Adafruit Trellis
  ----> https://www.adafruit.com/products/1616
  ----> https://www.adafruit.com/products/1611
  These displays use I2C to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include <Wire.h>
#include "Adafruit_Trellis.h"
  This example shows reading buttons and setting/clearing buttons in a loop
  "momentary" mode has the LED light up only when a button is pressed
  "latching" mode lets you turn the LED on/off when pressed
  Up to 8 matrices can be used but this example will show 4 or 1
#define MOMENTARY 0
#define LATCHING 1
// set the mode here
#define MODE LATCHING
Adafruit_Trellis matrix0 = Adafruit_Trellis();
// uncomment the below to add 3 more matrices
Adafruit_Trellis matrix1 = Adafruit_Trellis();
Adafruit_Trellis matrix2 = Adafruit_Trellis();
Adafruit_Trellis matrix3 = Adafruit_Trellis();
// you can add another 4, up to 8
// Just one
Adafruit_TrellisSet trellis =  Adafruit_TrellisSet(&matrix0);
// or use the below to select 4, up to 8 can be passed in
//Adafruit_TrellisSet trellis =  Adafruit_TrellisSet(&matrix0, &matrix1, &matrix2, &matrix3);
// set to however many you're working with here, up to 8
#define NUMTRELLIS 1
#define numKeys (NUMTRELLIS * 16)
// Connect Trellis Vin to 5V and Ground to ground.
// Connect the INT wire to pin #A2 (can change later!)
#define INTPIN A2
// Connect I2C SDA pin to your Arduino SDA line
// Connect I2C SCL pin to your Arduino SCL line
// All Trellises share the SDA, SCL and INT pin!
// Even 8 tiles use only 3 wires max
  Serial.println("Trellis Demo");
  // INT pin requires a pullup
  pinMode(INTPIN, INPUT);
  digitalWrite(INTPIN, HIGH);
  // begin() with the addresses of each panel in order
  // I find it easiest if the addresses are in order
  trellis.begin(0x70);  // only one
  // trellis.begin(0x70, 0x71, 0x72, 0x73);  // or four!
  // light up all the LEDs in order
  for (uint8_t i=0; i<numKeys; i++) {
    trellis.setLED(i);
    trellis.writeDisplay();
    delay(50);
  // then turn them off
    trellis.clrLED(i);
    delay(50);
  delay(30); // 30ms delay is required, dont remove me!
  if (MODE == MOMENTARY) {
    // If a button was just pressed or released...
    if (trellis.readSwitches()) {
      // go through every button
	// if it was pressed, turn it on
	if (trellis.justPressed(i)) {
	  Serial.print("v"); Serial.println(i);
	  trellis.setLED(i);
	// if it was released, turn it off
	if (trellis.justReleased(i)) {
	  Serial.print("^"); Serial.println(i);
	  trellis.clrLED(i);
      // tell the trellis to set the LEDs we requested
  if (MODE == LATCHING) {
        // if it was pressed...
	  // Alternate the LED
	  if (trellis.isLED(i))
	    trellis.clrLED(i);
	    trellis.setLED(i);
