Does anyone have experience with the LMX PLL synthesizers? I'm trying to send the three registers (R, N and F)
with the attached code. But it somehow won't work.
Data, Clock and Le are properly connected and the values are correctly calculated with the Code Loader App.
LMX_Arduino.ino (1.5 KB)
Can you pleas give a link to this product or chip, along with a schematic of what your hardware is.
This is the link to the chip (lmx2306) I use:
https://www.google.ch/url?sa=t&source=web&rct=j&url=https://www.farnell.com/datasheets/4907.pdf&ved=2ahUKEwjngNurhuX9AhUn6LsIHfuQCEIQFnoECA0QAQ&usg=AOvVaw0RKeZNGY4Tc-jh0Od_zSBg
And attached the circuit.
Thanks for that. I am assuming you are a Radio Ham. So am I.
However, unfortunately as this is an Arduino forum I have no experience of the PIC16F870 processor.
Sorry.
Oh, no I'm not using the Pic. Im using a Arduino Nano instead of the 16F870.
And yes, I'm a Ham ![]()
Can you post a link to where you got the diagram and if there is any code or explanation with?
Thanks... Tom....
Sure! The Circuit is on this site:
https://www.rfcandy.biz/communication/fm_500.html
So can you show the Arduino wiring you have?
The wiring is according to the this sketch:
(Pin9, 10 and 11)
Your code.
LMX2330/2331/2332 "Three wire interface" control with Arduino
Source:http://www.g8ajn.tv/dlother3.html
Modified by YO4HFU
Arduino pins: LE = Pin 9, DATA = Pin 10, CLK = Pin 11
const unsigned long IF_R = 0x360028; //Calculated by Code Loader 4 software
const unsigned long IF_N = 0x107C21; //IF_N counter connected to FoLD pin. Divider 1000 P=16
const unsigned long RF_R = 0x6002A;
const unsigned long RF_N = 0x1EA3;
unsigned long DTA;
int bp;
const int LE = 9;
const int DATA = 10;
const int CLK = 11;
pinMode (LE, OUTPUT); // latch enable
pinMode (CLK, OUTPUT); // clock
pinMode (DATA, OUTPUT); // data
digitalWrite(LE,LOW);
digitalWrite(CLK,LOW);
// to loop for testing uncomment 3 lines below
// while(true) { // TEST While to loop for scope
DTA = IF_R; // Send setup parameters
SendWord();
DTA = IF_N;
SendWord();
DTA = RF_R;
SendWord();
DTA = RF_N;
SendWord();
//delayMicroseconds(2000); // TEST scope delay between groups
// } // TEST While to keep looping for testing
void loop() { // loop forever
int SendWord() {
bp = 22;
do{
bp = bp - 1; //loop through bit positions 22 to 0
digitalWrite(DATA, bitRead(DTA,bp) );
digitalWrite(CLK,HIGH);
}while(bp>0);
digitalWrite(DATA,LOW);
digitalWrite(LE,HIGH); // Set LE to latch data
delayMicroseconds(4);
To add code please click this link;
Thanks.. Tom..
In that sketch you never actually execute any of the functions you have written to talk to the PLL chip.
You need to call your functions in here. You don't call anything.
Sorrys guys, I uploaded the wrong code version. This is the correct code below. But @Grumpy_Mike, I am actually calling the funtions in setup, but just once. I don't think that I need to call them constantly in a loop, correct?
Modified by YO4HFU
const unsigned long R_Reg = 0x0000320; //Calculated by Code Loader 4 software
const unsigned long N_Reg = 0x0807911; //
const unsigned long F_Reg = 0x0000092;
unsigned long DTA;
int bp;
const int LE = 9;
const int CLK = 11;
//while(true) { // TEST While to loop for scope
DTA = R_Reg; // Send setup parameters
SendWord();
DTA = N_Reg;
SendWord();
DTA = F_Reg;
SendWord();
//} // TEST While to keep looping for testing
int SendWord() {
bp = 22;
do{
}while(bp>0);
