Programming the Bootloader on a Custom Board
I have custom board that is quite simple. It has an atmega328p with an external crystal at 16Mhz. It is tied into the SPI bus such that it can be successfully programmed using an Arduino as ISP programmer. I can set the fuse bits using avrdude and can program it with the Arduino IDE 2.3 using Sketch -> Upload Using Programmer. The Uno has the Arduino ISP software running on it. In the IDE I have the Arduino Uno as the selected board.
So all seems to be working perfectly. My theory is that because I am using a standard atmega328p with the external oscillator and can successfully upload code and execute code normally, I should be able to burn the bootloader without changing any wiring or selecting a different board, etc.
Here are my tool settings before trying to burn the bootloader.
And here is the error I get when doing Tools -> Burn Bootloader
"/Users/username/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/username/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem2101 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/username/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/username/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem2101
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
         Hardware Version: 68584763
         Firmware Version: 208537744.3
         Topcard         : STK502
         Vtarget         : 1.8 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done.  Thank you.
Failed chip erase: uploading error: exit status 1
Hi @iitgrad. This problem can be caused by the Uno board you are using as the "Arduino as ISP" programmer being unexpectedly reset during the "Burn Bootloader" operation. This can be fixed by disabling the auto-reset circuit on the "Arduino as ISP" programmer board. To do that, connect a ~10 uF capacitor between the GND and RST pins on the "Arduino as ISP" programmer board and then try the "Burn Bootloader" operation again.
Hopefully it will work this time.
Make sure to remove the capacitor from the Uno board after you are done using it as an "Arduino as ISP" programmer, since the "auto-reset" circuit is used to activate the bootloader on that board when uploading new sketches.
Gotcha. Now I have to go find a 10uF capacitor. haha :slight_smile:
As usual with capacitors, I think there is a good bit of leeway on the exact value in this application. So if you don't have a 10 uF on hand, you can try anything around that ballpark and hope it will still do the trick.
Yep, unfortunately the biggest I have is from a kit of caps but the largest is 100nf so I'll have to wait for amazon until tomorrow. Fingers crossed :slight_smile:
OK, found some 1uF capacitors, tied 5 in parallel to get 5uF and it appears to work. Here is what I got. However, I'm wondering if there is something else I am missing to get the bootloader to work. I was thinking it would do the right thing just monitor UART0 but the Arduino IDE doesn't seem to be able to talk to it.
First here is my success message on the bootloader
"/Users/kevinmcquown/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/kevinmcquown/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem2101 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
         System wide configuration file is "/Users/kevinmcquown/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/kevinmcquown/.avrduderc"
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xFD"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFD:
avrdude: load data efuse data from input file 0xFD:
avrdude: input file 0xFD contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xDE"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xDE:
avrdude: load data hfuse data from input file 0xDE:
avrdude: input file 0xDE contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
Reading | "/Users/kevinmcquown/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/kevinmcquown/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem2101 -b19200 "-Uflash:w:/Users/kevinmcquown/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/bootloaders/optiboot/optiboot_atmega328.hex:i" -Ulock:w:0x0F:m
avrdude: 1 bytes of lfuse verified
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: reading input file "/Users/kevinmcquown/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/bootloaders/optiboot/optiboot_atmega328.hex"
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against /Users/kevinmcquown/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: load data flash data from input file /Users/kevinmcquown/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: input file /Users/kevinmcquown/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x0F"
Writing | ################################################## | 100% 0.02s
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
It appears to start the process but this is what I get repeatedly
        Using Port                    : /dev/cu.usbserial-110
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
Note that I have confirmed that I have rx and tx correct. I'm using an FTDI cable from my usb with just the four wires, vcc, gnd, rx and tx
Note that I have read on line that since I don't have a DTR coming from my ftdi cable and it doesn't tigger a reset with my hardware (maybe I should change that) i apparently can just be ready for the download to happen, click reset and then hit upload. I have tried this several times but without any success.
Congratulations! That is definitely a success at performing a "Burn Bootloader" operation.
I think this is the cause. On a standard Arduino board, there is an auto-reset circuit that causes the microcontroller to automatically reset when the upload process starts. That reset activates the bootloader.
The upload error you got can be caused by the bootloader not being activated while the upload process starts, which happens if the microcontroller is not reset.
You need to get the timing right. If you press the reset button too early, the bootloader will have already timed out by the time the upload starts. The tricky thing is that when you press the "Upload" button in Arduino IDE, it first compiles your sketch before starting the actual upload. So you need to wait until after the compilation finishes before pressing the reset button.
The way to get the timing right is to watch the black console window at the bottom of the Arduino IDE window. As soon as you see something like this:
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
press and release the reset button.
The upload should now finish successfully.
wow, thanks @ptillisch. I am wondering if it is possible to increase the wait time on the bootloader as my application does not need to immediately run. I'll give this all another try in the morning when I get back in the lab.
That's what I use on Nanos, works fine.
Only by modifying the source code and then building a new bootloader binary from the source code (using the makefile-based build system):
But I'm confident you'll find you don't need a longer wait time. I never have a problem getting the timing right for a manual reset.
Hooray, it worked! Now I just need some practice. :-). Thanks @ptillisch for all your great help!
Thanks @JCA34F Good to know
You are welcome. I'm glad it is working now.
Regards,
Per
