Hi there!
I'm currently stuck in Arduino Projects book on the Project 10 called "Crystall ball".
The problem which I'm facing is that characters don't seem to show up on the LCD screen.
I tried working through some suggestions, like here:
Backlight and contrast work just well, however, when the contrast is set to the max it shows this instead of just squares, I don't know if it's supposed to be this way
Now, I reassembled my circuit two times, making sure pin 2-5 connect to DB7-DB4. I tried using pins 7-10 but it resulted in no success.
I followed the tutorial thoroughly, but my implementation fails.
For debugging purposes, I used a simpler code and simpler circuit, without using a tilt sensor, and currently my circuit looks as follows:
One difference that I noticed with a tutorial is that I have VDD instead of VCC, E instead of E/N and DB pins instead of D, which seems to be identical, just different names according to my google search.
All connections are stable.
Please, help me debugging it.
If you need anymore details, I will happily share it.
Thank you, that's really useful
One thing, I think I might be able to just break this bridge with some knife, it's a tiny bridge.
Let me know please if you are sure it's a defect and it shouldn't be this way, I see on other images it's indeed not supposed to be connected, is it the case?
To be sure, I would measure DB4 to DB5... with a DMM... if no resistance, it's a short. All the other solder joints look just as poorly done. That's all I can guess looking at a picture.
If you will be using a knife, be careful not to slip and damage other connections.
Are you in a school with electronics course? Maybe you can bring it to a phone repair, where they solder every day. Maybe they will let you watch so you can learn? That would be nice for you learn to solder.
I got it, thank you!
I will use a knife, if I damage it I will just buy a new one, it seems to be defected any way
Will buy DMM too, thank you for this advice. I will need it in the future, no doubt
No, I actually doing it on my own, so I really appreciate your advice
I will bring it to the phone service in case breaking a bridge doesn't help
Super helpful post, I appreciate it!
Will post again if I manage to fix it or not!
