Project code and circuit help
Hello everyone!
In my project I need to have two 360 degree servo motors and one 5 pin stepper motor on one Arduino Uno Red Board and one sketch. I'm still very new to Arduino so please attach images of a potential circuit and code that may work. Thanks in Advance.
Links to their datasheets, please. "5 pin" doesn't tell anything useful.
That's not how this forum works.
It's not a free, give away code and schematics institution. All helpers work her for free, on their free time.
Please read and use this link: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
This indicates you will be doing the work.
You will create a wiring diagram showing the devices you mentioned. Each device requires power, ground and communication. The stepper motor needs a motor control board. Start with drawing the Arduino in the center with pin numbers as you see on every Arduino. A few cm away, draw the peripheral devices with one "power" wire and one "ground" wire going to the power supply. Next, from each peripheral, draw the communication wire to the Arduino. The stepper motor will receive power, ground and communications from the motor control board. The motor control board will receive power from the power supply and communications from the Arduino. Your turn. After you complete this, do it a second time, but make the boxes and lines neat. What is a Red Board?
Interesting project but we are not a free design or code writing service. We will be happy help out with your design and or code but first you have to make an attempt to design it, write it, post it and explain what is not working properly.
If there is hardware it is always best to post links to technical information as there are many versions of the same or different items. Since we cannot see your project, my eyes are to weak, you need to post using the language of electronics, an annotated schematic (best) or a clear picture of a drawing. Pictures never hurt. Frizzing diagrams are not considered schematics here.
