Note : Please Check the Image for Circuit
Code :
const int buttonPin=2;
const int ledPin=13;
int buttonState=LOW;
pinMode(ledPin,OUTPUT);
pinMode(buttonPin,INPUT);
buttonState=digitalRead(buttonPin);
if(buttonState==HIGH)
digitalWrite(ledPin,HIGH);
delay(5000);
digitalWrite(ledPin,LOW);
delay(50);
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Do you have a question ?
xfpd
3
Place yours between code tags represented by the </> icon when editing your post to make it formatted and readable.
const int buttonPin = 2;
const int ledPin = 13;
int buttonState = LOW;
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH)
digitalWrite(ledPin, HIGH);
delay(5000);
digitalWrite(ledPin, LOW);
delay(50);
Is your project not making your RED LED turn on? That LED should do the same as the Arduino's LED.
Maybe check that your button conducts the signals in the correct direction (vertical in your drawing).
*** and you need to ground the breadboard ground rail (for the LED path)
red_car
4
Do you have a question?
The other side of the LED (green wire) appears to be connected to nothing on the breadboard?
Maybe it should connected to GND?
system
Closed
5
