I am looking at a module that has a serial interface (rs232 type) that has two modes available for the Tx and Rx pins:
"Can be configured as open-drain or pull-up input."
I want it to communicate with an Arduino so, are either of these modes compatible with an input or output of the Arduino or do they require additional circuitry?
If you go to eBay and search for: "arduino rs232" I got over 600 hits. There are some that are less then a buck using a Maxim chip. The best thing is to look at them and determine (you may have to read data sheets) to get the output you want. The Max chip is comparable with the Arduino. Also Rx goes to Tx and Tx goes to Rx.
Thanks guys but I didn't meant rs232 literally, I was only trying to distinguish the serial communication from say SPI which some also call "serial".
The input/output of these modules are at 3.3 and 5 volt levels (but otherwise rs232 like as in characters at various baud rates) but have the option of push-pull or open drain.
How would I connect these modules to an Arduino (either 3.3v or 5v as required) pins so that I can communicate with these modules using push-pull or open drain?
lemming:
Why don't you post a link to the product? Makes it easier for everyone to advise.
The manual states RX is an input and can be open-drain or pullup input. That's wrong, its an input, it means it
can be an input or an input with pullup.
The TX is push-pull or open-drain.
However the manual says nothing about how to configure them...
You'll have to experiment. Try a 2k2 resistor in series with the connections to limit current and probe with 'scope or multimeter to see what voltages are present.
The manual is inexcusably vague about voltages of the logic signals.
In general push-pull outputs are better if both devices share supply voltage. Open drain is simpler in mixed environment. Both are easy to use with Arduino.
I was more interested in how, rather than how easy it is. Please would you provide a sketch of how you would connect between the Arduino Rx pin and the Tx pin of the transceiver using the transceivers open drain or push-pull output and the wiring between the Tx pin of the Arduino and the Rx pin of the transceiver using open drain or pullup of the transceivers input.
lemming:
Normally I'd use a wire for that.
If needed a voltage divider for level shifting from high to low; the other direction normally doesn't need level shifting.
