Dziubym:
My question is where in this setup should be the GND Output from the boost converter be connected. Should it be connected with GND of the Arduino
All grounds must be connected - Arduino, boost converter and 74141. And probably other bits as well not mentioned.
I already connected Nixie to the boost converter and I can succesfully lightup the tube connecting anode of the tube to High voltage out and individual tube pins to Boos converter GND out pin (one at a time).
And I thought this setup would stay with the only difference that I will connect tube digit pins to the ten oins of the chip.
Where in this setup would that resistor be and what value roughly.
Now that you have mentioned it I found the following diagram in which they is 20k Ohm resistor. Would this be sufficient
This diagram also answers my question , if it is correct.
Here GND from the 12V power source is connected to Arduino nad to boost converter. Then via arduino it is connected to the chip.
Also now I have question about significance of SHDN on the boost convertor. I found the datasheet https://pan.baidu.com/share/link?shareid=942813807&uk=1057088184
But being electronic illiterate not sure what is the difference between the connection where I float SHDN and when I ground it.
The Nixie datasheet will tell you about appropriate resistor values. The anode resistor goes in series with the anode, oddly enough! It limits the current to a few milliamps and thus allows only glow-discharge (not arcing) and limits the voltage the 74141 gets to see to about 80V or so.
At higher currents arcing happens, which means the nixie's resistance falls close to zero and the 74141 will
be destroyed (and the nixie will degrade rapidly).
