Quick Question - Best Way for Switches
Hello all,
Even though I am new to the Arduino platform, Im both fairly good at programming and electronics in general. Have a project to help a friend with a Halloween prop setup/mad scientist setup, Frankenstein control panel etc. He's wanting the following:
-Rocker switches (SPST) that play different WAVs when pushed one direction or another - possibly even a round robin playlist
-Standard push button switches that turn LEDs on and off
-Reed switch that again possibly play different sound effects when sticking in prop punch cards like an old analog computer
-Series of flashing LEDs
Thinking of using an Arduino MEGA for the large number of pinouts with a Music Maker shield.
-LEDs look pretty straightforward as Pinout commands
-Push buttons pretty much the same for turning on LED or playing a single sound file
For the rockers and reed switches, I'm thinking a push/pull 10k resistor in line with the switches and changing the value to 1 or 0 each time, and then performing an action when the value changes? Am I on the right track there? Thanks for any feedback.
There are optional internal pull-up resistors that can be enabled. Then you wire the switch to ground so when the switch is off the input is pulled-high and when it's on, the input is forced low.
With a double-throw rocker switch you can ground the common pin and use two input-pins. If the rocker has center-off, you have 3 possible "states".
For the LEDs, note that there are some current limits. The "absolute maximum" for an I/O pin is 40mA, with 20mA or less "recommended". And the combined total is 200mA. So if you need lots of LEDs on at once, or if you're driving high-power LEDs, you'll transistor or MOSFET drivers.
You could cut your I/O needs with a keypad to handle some of the inputs. Consider ancillary ICs like shift registers for input or output, or an I2C-controlled MCP23017, or similar, which has sixteen individually configurable digital I/O.
Arduino TypicalOutputs with warning
Thanks - hadn't known that. Interesting. Since it varies between 20-50pohms, how much wear and tear does that put on the mega chip over time, or is it negligible?
In the case of a push button/reed switch, using Super Bright 10mm white LEDs, so 20ma per. Only turning on one-three at a time, so probably not going to be an issue - we'll see what happens at breadboard. Other than that, have a separate bank of about 10 LEDs flash on and off randomly each LED on a separate printout not tied to any switches at all - they are just background look-nice.
Also interesting. Had thought about ICs - its just such a nightmare these days with the supply chains issues, I almost feel like Forrest Gump - "you never know what you're gonna ge"t. Been waiting on a Raspberry Pi Zero W for 6 months now for another project - off-topic, but if Broadcom wants to be the chip supplier to every IoT device in the world, they need to step up their production game (sorry rant over).
I did something similar last year (but it was dragons) using a Wemos D1 Mini. I had six buttons that started a different "scene" all wired to A0. Each button had a different size resistor and A0 had a 1K resistor to ground. This way each button presented a different voltage on A0 which was easy to discriminate.
I only needed a single pair of wires on a button bus.
Chips do not wear out from use. As long as they are used within specifications they will happily switch forever(ish).
Yes.
Great, thanks!
