So basically I am trying to make PIR Sensor alarm with IR remote control.
On my remote control I have two buttons - ON and OFF to turn alarm on and off. When alarm is activated and PIR sensor detects motion - it blinks LED for 3 seconds and then turns on siren. I managed to program this far and run into problem - I cannot deactivate my alarm with remote. I can deactivate it with remote when PIR sensor does not detect motion, but when it does - it just keeps ringing the siren. Probably there is an easy fix that I am not aware of.
Thank you in advance.
/* YourDuino.com Example Software Sketch
IR Remote Kit Test
Uses YourDuino.com IR Infrared Remote Control Kit 2
http://arduino-direct.com/sunshop/index.php?l=product_detail&p=153
based on code by Ken Shirriff - http://arcfn.com
Get Library at: https://github.com/shirriff/Arduino-IRremote
Unzip folder into Libraries. RENAME folder IRremote
terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include "IRremote.h"
/*-----( Declare Constants )-----*/
int receiver = 2; // pin 1 of IR receiver to Arduino digital pin 11
int ledPin = 12; // choose the pin for the LED
int inputPIR = 6; // choose the input pin (for PIR sensor)
int val = 0; // variable for reading the pin status
int pinSpeaker = 11; //Set up a speaker on a PWM pin (digital 9, 10, or 11)
int time = 10;
int var = 0;
/*-----( Declare objects )-----*/
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
/*-----( Declare Variables )-----*/
void setup() /*----( SETUP: RUNS ONCE )----*/
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPIR, INPUT); // declare PIR sensor as input
pinMode(pinSpeaker, OUTPUT);
Serial.println("IR Receiver Raw Data + Button Decode Test");
irrecv.enableIRIn(); // Start the receiver
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
val = digitalRead(inputPIR); // read PIR input value
if (irrecv.decode(&results)) // have we received an IR signal?
//Serial.println(results.value, HEX);// UN Comment to see raw values
if (results.value == 0xFF22DD)
Serial.println(" ON ");
var = 1; // alarm is on
if (results.value == 0xFFA25D)
Serial.println(" OFF ");
var = 0; // alarm is off
translateIR();
irrecv.resume(); // receive the next value
if (val == HIGH && var==1) { // check if the input is HIGH and alarm is on
digitalWrite(ledPin, HIGH); // turn LED ON
digitalWrite(ledPin, LOW); // turn LED OFF
for(int i=0; i<time ; i++) {
tone(300, 160);
delay(100);
if (var == 1 && val==HIGH){
Serial.println(" SIGNALS ");
digitalWrite(ledPin, LOW); // turn LED ON
tone(300, 160);
delay(100);
}/* --(end main loop )-- */
/*-----( Declare User-written Functions )-----*/
void tone(long duration, int freq) {
duration *= 1000;
int period = (1.0 / freq) * 10000;
long elapsed_time = 0;
while (elapsed_time < duration) {
digitalWrite(pinSpeaker,HIGH);
delayMicroseconds(period / 2);
digitalWrite(pinSpeaker, LOW);
elapsed_time += (period);
void translateIR() // takes action based on IR code received
// describing Car MP3 IR codes
} //END translateIR
/* ( THE END ) */
