Then I looked in the datasheet of the controller and I saw that it needs to be sourced with 3.3V and I was sourcing the TFT Screen with 5V :o
After that I tested the TFT with the 3.3v with no updates, nothing happens. I checked if I have short circuits on the TFT boards but it doesn't have, at least.
So now I don't know if I had damaged the TFT Screen or is just that I'm missing something on the library, wiring connection or code
If somebody could provide me a wire connection to test it with the Arduino Uno
and a Library to make work the TFT, it would be great!
So according to that, I have to wire the QVGA 2.2 Inch TFT Spi board like this picture? I draw it with Eagle to make easier to understand.
I had noticed about the wiring connections in the instructables:
UNO +5V to display pin 1 (VCC) and pin 8 (LED)
UNO 0V (GND) to display pin 2 (GND)
UNO digital pin 7 through a 1K2 resistor to display pin 4 (RESET), add a 1K8 resistor from display pin 4 to GND
UNO digital pin 9 through a 1K2 resistor to display pin 5 (DC/RS), add a 1K8 resistor from display pin 5 to GND
UNO digital pin 10 through a 1K2 resistor to display pin 3 (CS), add a 1K8 resistor from display pin 3 to GND
UNO digital pin 11 through a 1K2 resistor to display pin 6 (SDI/MOSI), add a 1K8 resistor from display pin 6 to GND
UNO digital pin 13 through a 1K2 resistor to display pin 7 (SCK), add a 1K8 resistor from display pin 7 to GND
You can connect VCC to 5V (if J1 is open). The onboard LDO will provide 3.3V for the ILI9341.
Your voltage-dividers ensure that the ILI9341 sees 3.3V logic.
The Adafruit example should read registers and display on Serial Terminal.
What do you get?
Have you used the full-fat constructor() ? i.e. with PIN8
Adafruit examples use a short form without the LCD_RESET argument.
I will try in that way, currently from my voltage-dividers I get 3.2V and I think that's not going to be a problem to see 3.3v logic
What do you get?
From Serial Terminal I receive a response, I will attach here
I presume they do this on purpose. So that they can crash every Red Display and possibly sell more of their own Displays. (which have an external pullup on TFT_RST)
Incidentally, I tried the Adafruit example with "their" constructor. I get a White Screen.
I will suggest to follow this steps ILI9341 TFT
This comes from the graphictest from adafruit ILI9341:
// For the Adafruit shield, these are the default.
#define TFT_RST 8 // You have to add this
#define TFT_DC 9
#define TFT_CS 10
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST); // also TFT_RST has to be included to make it work
One thing that I notice is that I maybe have to change the voltage-divider resistors:
5V_Signal-----1k----(Approx 3.2V)----1.8k----GND
Because sometimes the Screen get freeze and I have to reboot the system, also sometimes is showing whitescreen again, is like noise issue. But at the moment is working great!
