Receiver hardware : Arduino Pro Mini Atmega 168 3.3V 8Mhz, L298N Module, NRF24L01 and 2 DC Motors
Emmeter hardware : Arduino Pro Mini Atmega 328P 5V 16Mhz, 2 Joystick, NRF24L01 (unused : 4 button, 2 potentiometer, 2 toggle switch)
Hello everyone, i must work on a RC Car project for the school (a Amphibious Tesla Cybertruck) and I chose as a base the RC Car project of HowToMechatronics
For the propulsion i chose to use two parallel motors
I want to control each motor with a joystick.
But when I plug everything in, everything lights up but the motors don't move.
I don't know if it's related to the hardware (not the same Arduino for example) or to the code.
I tried to copy and paste the exact same code in the HowToMechatronics video but it doesn't work there either.
I don't know much about Arduino and I have to finish this before the end of this week
I hope you can help me
**Thank you **
(and sorry for my bad english )
If you are trying to drive those motors from an ancient L298N then forget it. The motors can easily take 10A or more, the L298N can supply 2A on a good day. Either use the original motors or a much better driver.
And note your chosen motors produce high revs. Unless you are using lots of gearing your car will try to go ridiculously fast and be uncontrollable.
slipstick:
Ok so according to you I have to forget the L298N because the motors are too powerful.
Unfortunately i can't use any other motors
Have you another solution so that I can control both motors with an arduino?
And which driver do you recommand me?
