RC522 Authentication failed
So I was trying to get started with the RC522 and Arduino. It works when using the example code to read and write the RFID card. But when I try to change the blocks to write on in the example, It writes for the first time and then shows an authentication error and timeout when I try to read them.
I am using the MFRC522 library.
I have already tried all the types of fixes available on different forums online but can't find the solution.
I am pasting the example code below to write the data.
The other thing is, how do I do a complete factory reset on the card?
Thanks.
 * Write personal data of a MIFARE RFID card using a RFID-RC522 reader
 * Uses MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
 * More pin layouts for other boards can be found here: https://github.com/miguelbalboa/rfid#pin-layout
 * Hardware required:
 * Arduino
 * PCD (Proximity Coupling Device): NXP MFRC522 Contactless Reader IC
 * PICC (Proximity Integrated Circuit Card): A card or tag using the ISO 14443A interface, eg Mifare or NTAG203.
 * The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         5           // Configurable, see typical pin layout above
#define SS_PIN          53          // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance
  Serial.begin(115200);        // Initialize serial communications with the PC
  SPI.begin();               // Init SPI bus
  mfrc522.PCD_Init();        // Init MFRC522 card
  Serial.println(F("Write personal data on a MIFARE PICC "));
  // Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
  MFRC522::MIFARE_Key key;
  for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
  // Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial()) {
    return;
  Serial.print(F("Card UID:"));    //Dump UID
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
    Serial.print(mfrc522.uid.uidByte[i], HEX);
  Serial.print(F(" PICC type: "));   // Dump PICC type
  MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
  Serial.println(mfrc522.PICC_GetTypeName(piccType));
  byte buffer[34];
  byte block;
  MFRC522::StatusCode status;
  byte len;
  Serial.setTimeout(20000L) ;     // wait until 20 seconds for input from serial
  // Ask personal data: Family name
  Serial.println(F("Type Family name, ending with #"));
  len = Serial.readBytesUntil('#', (char *) buffer, 30) ; // read family name from serial
  for (byte i = len; i < 30; i++) buffer[i] = ' ';     // pad with spaces
  block = 1;
  //Serial.println(F("Authenticating using key A..."));
  status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
  if (status != MFRC522::STATUS_OK) {
    Serial.print(F("PCD_Authenticate() failed: "));
    Serial.println(mfrc522.GetStatusCodeName(status));
    return;
  else Serial.println(F("PCD_Authenticate() success: "));
  // Write block
  status = mfrc522.MIFARE_Write(block, buffer, 16);
    Serial.print(F("MIFARE_Write() failed: "));
    return;
  else Serial.println(F("MIFARE_Write() success: "));
  block = 2;
    return;
  // Write block
  status = mfrc522.MIFARE_Write(block, &buffer[16], 16);
    return;
  // Ask personal data: First name
  Serial.println(F("Type First name, ending with #"));
  len = Serial.readBytesUntil('#', (char *) buffer, 20) ; // read first name from serial
  for (byte i = len; i < 20; i++) buffer[i] = ' ';     // pad with spaces
  block = 4;
    return;
  // Write block
    return;
  block = 5;
    return;
  // Write block
    return;
  Serial.println(" ");
  mfrc522.PICC_HaltA(); // Halt PICC
  mfrc522.PCD_StopCrypto1();  // Stop encryption on PCD
I moved your topic to an appropriate forum category @Mayur_Y.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
So after a lot of research and wasted cards, I found the reason for that.
Apparently, I am not supposed to write on certain Blocks of the card, and then it will work fine.
If we analyze the dump from the card, we can see that the last line of each Sector has the same data.
For, eg:
0 3 00 00 00 00 00 00 FF 07 80 69 FF FF FF FF FF FF [ 0 0 1 ]
1 7 00 00 00 00 00 00 FF 07 80 69 FF FF FF FF FF FF [ 0 0 1 ]
2 11 00 00 00 00 00 00 FF 07 80 69 FF FF FF FF FF FF [ 0 0 1 ]
etc.
So it looks like the last 6 bytes are the Authentication bytes, and if you rewrite over it, then you can mess up the card.
I didn't know that cus I am working with RFID for the first time. I saw that a lot of people online have the same issue but cannot find a solution.
This solution might help someone in the future who faces a similar problem.
Thanks.
