Start by taking readings, printing those on the Serial monitor so you have an idea of the values that come out of it, and at what distance you start to see an effect. Based on that, set a series of if statements switching on/off the LEDs. That's about all there is to the sketch part.
The hardest part is probably stability of your sensor, to get consistent values for distances.
groundFungus:
What does control mean in this context? On-off, brightness?
Possible? Maybe. How hard is it to test with a short sketch? Experimenting is allowed.
Thanks for replying.
When i write a sketch and i try to check to see if the code is good it comes back with red lines and{ " etc...
and i think i dont want to blow up the uno ?
the closer i get to the sensor i want the led,s to switch on:
Led 1 on at 50-100 then off
Led 2 on at 150-200 then off
led 3 on at 250-300 then off
led 4 on at 350-400 then off
led 5 on at 450-500 then off
likewise when i get further away the above happens in reverse !
I tried something similar a while back and was not real successful. The correlation between distance from the sensor and the voltage (capacitance) measured was very inconsistent. That is why I suggested experimenting.
Post the sketch and the compile errors in accordance with the guidelines in the "how to use the forum-please read" stickies (see #7) and we can try to get your sketch working. Then you can see if you can make the project work the way you want.
pandmairconltd:
But are you sure about those values? if you have a reading of say 422 no LEDs will be on. Make the ranges consecutive, or even overlapping a bit. Also you'll have to set the values based on experimenting.
