Read this to know whether you are wearing your helmet in the wrong way
Every person has a different purpose to riding bikes. Some ride to work, some others take it as a sport. After quite a long time riding, I realize many people wear motorcycle helmets in the wrong way.
The helmet means to protect you. Beside making sure you ride with a lid on your head, you also need to be sure that you wear it in the right way.
In this article, I will help you justify the wrong helmet wearing and show you the correct ways. Take some of your time to visit [u]HelmetsZone[/u] to read more useful information about motorcycle helmets. The motorcycle helmets buying guide and review category is where you can buy a new quality motorcycle riding headgear.
First of all, make sure the helmet fits your head. If it is too tight it will cause more discomfort. You will feel hard to move your head, get a headache after a long ride, and your head can’t “breathe”. The most advisable way is to buy the headgear in person, therefore, you can try it on to see if it fits.
Buying helmets online is time-saving, but you have to check the size carefully before making a purchase. Size choosing includes measuring head and sizes comparing. To measure your head, you can use a measuring tape, or a string or cloth. Or you can use the same size of your cap. Once you have your head size, compare it with the size chart. Most shops will send you the size table if you ask for it.
Next is to check the safety stickers. These are usually stuck on the outer shell (if it is a DOT and Snell sticker). If you don’t see it on the shell, then try to look for it on the inner shell.
Don’t wear your helmet backward. I know this may sound a little weird, but it does happen, especially among half-shell helmet wearers. Assuming you don't know how to wear a helmet, at least you will know which end should be in front, so you can easily see the road. Even a kid knows that.
Modern helmets now incorporate additional features to distinguish the front and rear of the helmet quite obviously such as the knob to adjust the fit or LED lighting. But I don't think you need to pay extra for those features, if you are confused then you can learn how to distinguish between the two sides of the lid yourself.
At this point, you’ve almost done. Check again by looking at yourself in the mirror. You must see the helmet sits level across your head and cover most of your forehead. Don't think wearing a helmet the wrong way will make you look different and cooler, it just gives you danger. The helmet is meant for protection rather than for beauty. And if you want to look cool on your motorcycle, buy a cool motorcycle helmets here: [u]https://helmetszone.com/coolest-motorcycle-helmets.html[/u]
High-end motorcycle helmets nowaday usually have an adjustment knob which allows you to adjust the size of the helmet. You can either tighten or loosen the knob. Shake your head to make sure the lid doesn’t twist around.
When you wear the helmet long enough, it will automatically change itselfs to fit your head perfectly. And once it fits, it's very difficult for it to fit in someone else's head. This is a great feature of motorcycle helmets.
There are many types of helmets out there, and each has different features. Get to know more details, please visit HelmetsZone. Its contacts will be put below:
Phone: (1) 610-386-5943
Address: 10236 Zenith Ln, Bloomington, MN 55431
Anh HelmetsZone on Diigo: [u]https://www.diigo.com/profile/helmetszone[/u]
Can you please post the code, and what the 'little problem' is.
caesarwatsica:
Hello I'm making smart glasses. I had a little problem with the code. Help me.
A definition of smart glasses and a sketch would be very helpful. You might even want to throw in a wiring diagram.
Help us to help you by please reading one of the "how to post" sticky threads....
caesarwatsica:
Sure!
  // read and write things to the pins
  // to initialise your smart glasses into an initial state
  // read some pins and maybe examine the millis() clock
  // to determine if you need to write other things to the pins
  // if you do, then write those other things to the pins.
Not only code please post if you're using links of any display or sensors you're using...Thanks!
