I am trying to save an int to the EEPROM. This is a calibration number which I am hoping to read on any future power-ups.
From what I gathered, it is not possible to write an into to one EEPROM address. Is there a way that I can split this int into two bytes and save in two addresses?
Note: The int is generated from analogRead() of a pin.
Depending on the precision you need, I often divide ints to fit into a byte then write the byte to eeprom. Go the other way to retrieve data from eeprom. Just a thought.
The EERPOM library can read and write int's. You provide the starting address for where you want to store/read the data. It will automatically use two EEPROM bytes to store the int.
